- Thank you received: 486
rodw wrote: And Arc Fail timeout of at least 2 seconds due to laggy torch start.
That doesn't make sense to me, so in the first of Clive's Halscopes the sawtooth is 5Hz and the arc voltage is around 1400V or am I missing something?rodw wrote:
Thats not 100 ms! Its one second.
The division is the minor tick. 10 minor ticks per vertical line.
That is my reading of the plot as well.tommylight wrote: Then there is the instant torch off after an arcok, normally assumed to be from to much voltage, but it looks more like failure due to a spike in voltage, and not just the torch voltage.
Rod I do thank you for looking into this. But I am not sure what you are asking me to do, and how to do it.
Is the code aimed at me or Phil ?
I don't want to meddle in the dark and break the system.
