- Thank you received: 4153
Clive S wrote:
rodw wrote: Why don't you try a timedelay of say 0.2 to 0.5 seconds after torch on and use that as a ArcOK? Leave it on until the cut is finished.
It seems like your machine is not a candidate for synthesised ArcOK.
Would you mind expanding how to achieve that, ie where would the time delay be put and how do I change it as ArkOK.
It would probably be worthwhile running Halscope on these pins plasmac:torch-on plasmac:arc-ok-out plasmac:arc-voltage-out
ArcOK high is set at 200What is your Arc OK High set at?
rodw wrote: Clive, there is something wrong here with that sawtooth. that is oscillating in sympathy with with your 50 Hz mains power.
There is a noise issue in your system. I feel your pain.
From memory you have a 7i96,
Have you got an EMI Filter on the mains power? If you have not got an IEC connector you can get hard wired ones.
Is your plasma cutter earthed separate to your mains inlet to power?
Is your table grounded.
Have you got a central ground point with seperate wires back to every motor on your system that bridges all your linear rails? This also needs to be extended to your floating head etc. Hypertherm have a good document on this
BUt the most effective for me was the EMI filter.
