- Thank you received: 2100
The plasma source should have no effect, the Retry Delay is the amount of time from a failed arc until it attempts to restart the torch. Arc Fail is the time from when the torch was turned on until a failure is reported if the arc is not within the set parameters.Clive S wrote: Phill I have tried the arc retry delay to 20 secs with no joy. But thinking about it does the retry delay work for pilot arc.
That seemw odd, I will take a look later today.Trying to test the above I made 3 small circles with shapes and array I saved the gcode to the standard folder and then edited it with G4 P15 after the first cut to see if the 15 sec delay (ie long enough for the air to stop and volts get to zero) but when this was reloaded it purged the g4p15 out of the code. So how can I get a pause in the code between the cuts to test ?
Seems to me that is pretty normal, while the compressed air is passing through the conductivity is higher and the THCAD is sensitive enough to count for that.Clive S wrote: I am beginning to think this is a problem with the plasma cutter as until the air stops the volts float around anything between 0 to 18 then when the air stops it then holds steady at zero.
Check the ARCOK light while that is going on, if it is ON while the air is still running and the Torch Volts show 0 to 18V, there is most probably your problem, so raise the MIN arcok voltage to something like 60 to 80V.
Yup, that should be it.Clive S wrote: Thanks for the feedback Tom. I have already tried setting the "OK low volts" to 90v I take it that OK low volt IS the same as min arcok
