PlasmaC torch starting problem (Solved with help from the famous three)
6 years 7 months ago #160236 by phillc54
Clive S wrote: I made 3 small circles with shapes and array I saved the gcode to the standard folder and then edited it with G4 P15 after the first cut to see if the 15 sec delay (ie long enough for the air to stop and volts get to zero) but when this was reloaded it purged the g4p15 out of the code. So how can I get a pause in the code between the cuts to test ?
I "think" this is a workflow thing.
When you save an array it creates a new file with the name you gave it. It keeps the original array which is a temporary file loaded in LinuxCNC so if you go Reload it will only reload the temporary file. If you want to use the file you created you will have to Open that file.
6 years 7 months ago #160237 by phillc54
tommylight wrote: Oh BTW, my dog died a few days ago.
Sorry to hear that Tom.
6 years 7 months ago #160243 by tommylight
Clive S wrote: Very sorry to hear that Tom as I know you was very fond of it .
I never had to worry about leaving the house or the workshop alone, just the sight of a 100 pound Rottweiler is enough to make most humans have bad dreams, for a long time! :)
It just did not get better, despite many visits to the Vet, it had lost weight by the time you visited, by the end it was pitiful to look at.
6 years 7 months ago #160265 by Clive S
If I understand correctly the array is saved to a different folder than the standard NGC one. I saved the file under a different name to the desktop and edited that, I then shut the PC down and restarted and checked that the G4P15 was in the file on the desktop and opened that file.
Does the PlasmaC purge the G4P15 from the code?
6 years 7 months ago #160266 by phillc54
Clive S wrote: If I understand correctly the array is saved to a different folder than the standard NGC one. I saved the file under a different name to the desktop and edited that, I then shut the PC down and restarted and checked that the G4P15 was in the file on the desktop and opened that file.
I didn't think it did and I have just tested it here and it works OK.
Time to create page: 0.456 seconds
