- Thank you received: 2100
I would look at your pierce height. Its possible with the air flowing the arc does not have sufficient force to transfer to the material. Its clear that there is no current sensed through the work ground cable. Was your plasma designed to accpet a pilot arc torch? IS the new torch compatible?rodw wrote:
.[="tommylight" post=160819]Clive, i am sorry for the mess we have created for you, and also sorry for having to ask you this, but several posts back i asked you to check the torch distance from the material after the first and the second probe, now Rod has mentioned the same thing, so please do check that.
.So to recap:
-Please do not lower the low voltage threshold ever again, it did cause us some head scratching, and some stray answers .....,
-PlasmaC is configured and working correctly,
-Wiring is all good,
-The noise is present while the inverter power stage is on, so nothing to worry about, most probably,
-Please oh please lower the pierce height and the cut height !![]()
Pierce at 2mm and cut to 1mm, test and report back
.If you can find a reed relay, you can get the arcok signal that never fails and gives no false starts ever, but you do have to remove one of the thick cables on the plasma and replace it with a longer one, with 3 turns made out of it and the reed relay located inside those turns. Use a piece of old pen or similar to prevent the reed relay from braking, they usually are made out of thin glass.
:blush:Clive S wrote: I probably have a reed switch (not relay) as they are in a lot of alarm contacts.
Yes, I believe this is correct. PlasmaC will only continue if both are true even though Arc OK is capable of being displayed without a Torch On signal.islander261 wrote: I may be missing something here. It seems to me that the PlasmaC generated Ark Ok signal should only be true when the plasmac torch on signal is true
Clive S wrote: I have noticed that when the button is pressed it stops the air purge briefly
