qtvcp issues
  • auto-mation-assist
  • Platinum Member
  • Platinum Member
7 years 11 months ago #120976 by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
On, "no you are missing 6 widgets in 'linuxcnc controller'"
I will need to figure out how I can get those. I have done a,
git reset --hard origin/qt5vcp_py2
That did not fix it because the picture I send was after this was done. Perhaps there is different command I can use or perhaps is there a way to pull each update individually. git pull just tells me that I'm up to date.
  • Platinum Member
  • Platinum Member
7 years 11 months ago #120977 by auto-mation-assist
Chris,
I have updated my system the two different ways and both got the same result in the end and I gained some but not fully complete.
First I used:
git clone github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
cd linuxcnc-dev
git checkout qt5vcp_py2
This kept the folder name as linuxcnc-dev which is some what confusing
Then I used:
git clone -b qt5vcp_py2 github.com/LinuxCNC/linuxcnc.git qt5vcp_py2
Both work fine to get the qt5vcp_py2 branch.
Here is the result, the left column is my original, the middle is with git checkout qt5vcp_py2, and the right is with the branch clone.
It does look like that some of the files you mentioned may not be there or may have missing parts that do not allow them to show up.
7 years 11 months ago #120979 by racedirector
Replied by racedirector on topic qtvcp issues
Thanks Chris
My thinking was to just design a new screen to sit over the top of the already coded PHP file, I would use the same control names that Torch does. I was originally going to to do this in glade but seeing as you guys are making brilliant progress with QT I thought I might give that a go instead.
Cheers
7 years 11 months ago #120991 by cmorley
Replied by cmorley on topic qtvcp issues
'git clone -b qt5vcp_py2 github.com/LinuxCNC/linuxcnc.git qt5vcp_py2'
hmm that doesn't sound right. You shouldn't have to _clone_ qt5vcp_py2...as it's a branch of linuxcnc. You clone linuxcnc the project.
Can you gitk qt5vcp_py2 and tell me what the top commit message says?
Should say 'qtvcp -versa_probe ongoing work'
Also can you tell me what 'git remote' tells you.
Chris M
7 years 11 months ago #120992 by cmorley
This shows the latest commits pushed to linuxcnc's github remote:
github.com/LinuxCNC/linuxcnc/commits/qt5vcp_py2
Chris M
  • Platinum Member
  • Platinum Member
7 years 11 months ago - 7 years 11 months ago #121017 by auto-mation-assist
Chris
gitk tells me that I'm up to date with it showing: qtvcp -versa_probe ongoing work
I have noticed a problem with: 'versa_probe_plugin.py'
This never compiles into .pyc which is likely the problem.
I usually ignore all the missing Icon error messages when the designer loads. in the middle of them there is:
[QtDesigner.QTVCP.WIDGETS.MACRO_WIDGET][DEBUG] Exception loading Macros: (macro_widget.py:307)
File "/home/cnc/linuxcncDev/lib/python/qtvcp/widgets/macro_widget.py", line 268, in _findMacros
for f in os.listdir(path):
OSError: [Errno 2] No such file or directory: 'None'
[QtDesigner.QTVCP.WIDGETS.MACRO_WIDGET][DEBUG] Macros Found: None (macro_widget.py:164)
This is likely not related to the versa_probe not showing up issue.
Last edit: 7 years 11 months ago by auto-mation-assist. Reason: Removed widgets_plugin.py note
Time to create page: 0.158 seconds
