- Thank you received: 90
Error in tool_offsetview.py
- MarkoPolo
1 year 4 weeks ago #335731
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
I made some adjustments to the regular expressions, and it seems to be displaying colors correctly now.
Check if everything is OK.
- Thank you received: 2181
1 year 4 weeks ago #335759
Replied by cmorley on topic Error in tool_offsetview.py
Ok I pushed the more then 10 macros work. Let me know what you think.
- MarkoPolo
1 year 4 weeks ago #335785
by MarkoPolo
Great, that's exactly what I was looking for.
It works well, but two things could be improved:
1. If I press a macro button a second time that doesn't do anything because it's already executed, e.g., "Goto Machin Zero," the LED doesn't go out; it keeps blinking. It blinks until another macro does something.
2. Button 10 has a hardcoded name of "MORE MACROS." It would be nice if it also took its name from the ini file like the other buttons.
1 year 3 weeks ago #335895
I think I pushed a fix for the leds staying on problem - at least in the tests I did it worked.
The label is a bit harder to fix satisfactorily. It's now at least translatable.
- MarkoPolo
1 year 3 weeks ago #335905
by MarkoPolo
The LEDs are working properly.
The label translation is perfectly sufficient.
Thanks for the good work.
- MarkoPolo
4 months 3 weeks ago #347002
by MarkoPolo
Hi Cmorley
For a while now, the 50/100 "max velocity override" buttons and the slider haven't been working. It turned out the connections (signals/slots) had disappeared. I fixed the problem and also tweaked some minor things. The red LEDs in the two axis buttons were red instead of pink, like the other buttons. I removed the blank pages on the 4th and 5th axis buttons.
Time to create page: 0.142 seconds
