- Thank you received: 2181
Error in tool_offsetview.py
2 months 1 week ago #348908
Replied by cmorley on topic Error in tool_offsetview.py
The voice can be helpful with testing HAL stuff. Qtvcp has a test_led component that can speak on hal pin state changes.
Maybe the problem is a race condition that doesn't effect me. I'll get looking.
I wonder if adding a m5 to the abort script would help?
- MarkoPolo
- Thank you received: 90
2 months 1 week ago #348910
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
I did a few more tests, and with a short Gcode file of ~1500 lines, it works fine, disabling the spindle on the first try. If the file is already ~2000 lines long, there's a problem. This value may vary on different machines, but you can try shortening or extending the number of lines. The beginning and end of the file remain the same. Try test.ngc.
2 months 1 week ago #348965
I did finally get this problem to show in a sim, with your test program.
It didn't show with 3d_chips.ngc though.
I actually can see the spindle (by the spindle speed display) stops then starts again.
If I put an m5 in the on_abort.ngc file I could get it to always kill the spindle.
That is masking the problem, but would help in the mean time.
I am testing master, which I think you are using too.
2 months 1 week ago #348974
Made an issue:
github.com/LinuxCNC/linuxcnc/issues/4465
Found some things in testing:
-I can see the spindle speed display go to 0 on first abort then immediately return to previous speed.
-The sim uses on_abort.ngc but removing it doesn't make a difference, but adding an m5 to the script will stop the spindle reliably. I think this is just masking the problem.
-I also note in the test program the initial line that starts the spindle is silently ignored.
I am not sure this is related.
-If I abort close to the beginning of the program - always restarts the spindle.
If I abort near line 500, 1000, or 1500 spindle stops.
Do you see the same?
- MarkoPolo
2 months 1 week ago #348978
by MarkoPolo
Yes, I'm seeing exactly the same issues you're describing.
Adding M5 to on_abort.ngc does indeed work well in this case, although, as you say, it only masks the problem.
Nevertheless, it won't hurt to leave M5 in permanently.
2 months 6 days ago #349018
This should be fixed in master now.
Another Dev figured it out quick!
Time to create page: 1.170 seconds
