Rods "Spaceship" Scratch built Plasma Cutter build
- phillc54
- Thank you received: 2100
24 Jun 2019 00:05 #137683
by phillc54
Replied by phillc54 on topic Rods "Spaceship" Scratch built Plasma Cutter build
I think you should bite the bullet and replace them all for PNP.
Cheers, Phill.
Cheers, Phill.
- Thank you received: 4152
24 Jun 2019 01:48 #137690
Thats not really advice I want to hear! Anyway, now I've replaced both of the home switches so the limit switches should never be needed
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
Cheers, Phill.
- phillc54
24 Jun 2019 01:54 #137691
by phillc54
Don't forget about that dude named Murphy...
- pl7i92
- Thank you received: 358
24 Jun 2019 07:18 #137712
by pl7i92
Replied by pl7i92 on topic Rods "Spaceship" Scratch built Plasma Cutter build
is the laserpointer on both sides of axis
i put mine in one axis here it is X to the torch so i got only one ofsett
and your crosshair is then the point to start actuly it is the negative to the Torch
G10 L20 P1 x0 y-35 (in my case )
then as i got this done by a Button press
i go
M112 reload the Graphics axis−remote −−reload
G54 G0 X0 Y0
to be on the start point XY
i go
G54 G0 X0 Y0
24 Jun 2019 08:13 #137717
I deliberately offset it on both axes so it could reach 0,0 plus it was easier to mount that way!
Gmoccappy supports macro buttons so I've put it there for now. I think I'll try and move it to one of the buttons Phill has added to the Plasmac front screen. He has one that opens halshow but it can also be opened from the settings page So I was hoping to put it there.
i go
G54 G0 X0 Y0
- phillc54
24 Jun 2019 08:15 #137718
by phillc54
24 Jun 2019 08:17 #137719
Phill, thanks what about an example to call a g code subroutine file? I seem to remember the first version of plasmac I installed had one but you changed it!
- phillc54
24 Jun 2019 08:21 - 24 Jun 2019 08:33 #137720
by phillc54
Have you triedI'm kinda thinking it should work...
Cheers, Phill.
EDIT: Yes it does work, I added it to the docs.
o<my_sub_routine> callCheers, Phill.
Last edit: 24 Jun 2019 08:33 by phillc54.
24 Jun 2019 09:25 #137722
Sweet, that will be easy then (Famous last words)
Have you tried
I'm kinda thinking it should work...o<my_sub_routine> call
Cheers, Phill.
- Thank you received: 7490
25 Jun 2019 00:49 #137766
He was right, kinda painful now thinking about it, should have just trusted the guy !! !
Replied by tommylight on topic Rods "Spaceship" Scratch built Plasma Cutter build
Wasted a lot of time checking this dudes theories when i was young !Don't forget about that dude named Murphy...
Time to create page: 0.190 seconds
