Optimum Optimill MH50V CNC conversion
1 month 2 weeks ago #349729 by tommylight
AWESOME !!!
1 month 2 weeks ago #349730 by Unlogic
Thanks Tommy, it's been a long journey getting here.
Hopefully the new spindle will allow me to mill parts significantly faster than before.
1 month 1 week ago #349765 by dbtayl
I don't usually clutter up threads like this just to say it looks great, but... looks great! I still need to get the spindle motor cooling shroud finished and installed on my machine... really easy to leave things unfinished once you can make chips, so good on you.
The following user(s) said Thank You: Unlogic
1 month 1 week ago #349843 by Unlogic
Thanks for the feedback dbtayl. Don't worry about clutter, forum threads like this are all about dialog and sharing experiences.
For some reason the final bits always take longer than expected to get sorted. I've managed to get the spindle liquid cooling installed and to somewhat button up the build for now.
The first challenge with the spindle cooling was the location of the inlet which is located at the back of the spindle flange.
I didn't want any hoses down there as the hot chips when milling steel could easily damage them. So I did a little workaround using an angled fitting and a bit of pipe originally meant for a grease based central lubrication system.
Next up I tackled the the cheap PC water cooling radiator I had purchased of Amazon. I 3D printed some wall mounts for it along with two fan grills for the Noctua fans.
Here it is mounted on the wall together with the pump/reservoir unit which I also purchased of Amazon. The yellow color is from the special type of antifreeze I use together with deionized water.
1 month 1 week ago #349844 by Unlogic
Since the both the pump and fans are meant to be used in PC's they are rated for 12 volts so I added a separate Meanwell 12V/2A power supply for them.
The power supply is constantly powered but I switch the output side using a solid state relay so that the cooling only runs when the spindle is on.
However the pump proved to be a bit noisy and way too powerful give the small diameter hose I'm running. So added a 7.5Ω resistor in series with the pump to bring the voltage down to 8V which made it much quieter and brought the flow down to a more suitable level.
With that done I tackled the cable chain along with all the wires and hoses.
With that in order I turned my attention to the stainless cover I had laser cut and CNC bent a while back. I had to manually make a cut out for the connector of the spindle servo which I had forgotten to take into account. But I think it came out okay anyway.
Fitted it with a rubber strip to cover the sharp edges.
Here is how the machine looks with the cover installed.
1 month 1 week ago #349856 by Unlogic
And here is how it looks with the enclosure mounted on the table.
With all the mechanical bits in place I wrote a short spindle run-in program that increased the spindle rpm in increments of 500 up to 6000 and ran for 10 minutes at each increment.
Everything worked well until I reached 5000 rpm when the spindle servo threw a fault. Turned out I had the max allowed rpm set to 4500 in the servo drive since my old spindle couldn't go that high.
Fixed that and immediately ran into the next issue, the default rpm limit for the encoder speed in the servo drive also had to be increased. In the end I had to bump up quite a few parameters including tweaking the inertia to get the full 6000 rpm range enabled in the drive.
The next issue I ran into was that the rpm would not go above 5610 when commanded from LinuxCNC. Turned out that I had to adjust the settings in LinuxCNC regarding how many steps (pulses) per seconds that could be sent to the spindle. Just as with the drive I had set these value quite low for my old spindle when I did the configuration years ago.
With all that sorted I could finally finish the run-in program. But when the program stopped after running the final increment at 6000 rpm I ran into the next issue. The drive threw a fault regarding an overheated regenerative braking resistor.
Going from 3500 to 6000 rpm along with the increased the inertia from the larger spindle overwhelmed the built in regenerative braking resistor in the spindle drive when coming to a full stop from 6000 rpm. I managed to get it somewhat working for now by increasing the time for the spindle ramp down by a few seconds.
But if I stop the spindle a few times in successions from full rpm I still get the fault. So I ended up ordering an external 800W braking resistor which should be here early next week.
If I managed to follow the formulas in the Delta B3 manual correctly a 550W resistor should be enough for my setup. So hopefully 800W will give me plenty of headroom.
However after all the troubleshooting I was still very satisfied at the end of the day when I removed the BT40 tool holder which had been in the spindle all day running at various rpm's. It was essentially the same temperature as when I had picked it up from the tool shelf in the morning.
The new spindle is running significantly cooler compared to the old one. This can also be seen on the idle load.
With the old spindle I would have an idle load of 17-20% on the 2kw spindle servo just running idle at 3500 rpm. The new spindle sits between 1-6% depending on rpm, at 6000 the load is just 1-2% which is very promising.
Time to create page: 0.681 seconds
