Optimum Optimill MH50V CNC conversion
1 year 10 months ago - 1 year 10 months ago #316456 by timo
 The machine looks very good. Does more than one vise add a lot to a hobby machine?
I change setups a lot and sometimes clamp direct on the table or use a 3-jaw chuck.
How rigid is that optimum mill? I would have thought you can push it a little more:-). Chips will fly everywhere.... next up! "Full enclosure"
Table is from a carbide endmill catalougue.
Greetings
Last edit: 1 year 10 months ago by timo.
1 year 10 months ago - 1 year 10 months ago #316461 by Unlogic
As I don't have an automatic tool changer so adding more vices helps a lot when doing larges batches of parts as it reduces the amount of tool changes I have to do.
You simple setup the program to do the same operation with one tool on all of vices and then change tool and make the next operation on all vices and so on.
With three vices and I can usually hold 3 or 6 parts at the same time depending on the size of the parts.
The mill is fairly rigid and can take pretty heavy cuts as can be seen here:
However the limiting factor when milling the v-band chill/purge block is the long skinny tools I used and the slow spindle speed of this machine.
The long tool stickout leads to tool deflection which greatly reduces the width of cut that can be used.
Small tools require higher RPM and the spindle of this machine is only designed for a max rpm of 3000 which leads to very slow feed rates when using small tools. As you see in the image you attached it doesn't even have a feed rate listed for a spindle speed as low as 3000 rpm when milling aluminum.
Last edit: 1 year 10 months ago by Unlogic. Reason: Fixed typo
The following user(s) said Thank You: tommylight, besriworld, timo
1 year 10 months ago - 1 year 10 months ago #316465 by timo
3000 rpm is not all that high for Al, but still better than no torque :-).
( don*t ask! ; 1000 W, no gearbox and max. 6000 rpm )
Makes an 8mm cutter a good choice for my old benchtop machine.
The 16 mm endmill would be "happy" at approx. 3000 rpm :-), but some machines are not happy with a 16 mm endmill.
1 year 9 months ago #319702 by leglaive
hello,
I would like to know if it is possible for you to send me a complet list of all product that you use with references. Because for exemple i have a lot of problem to find a Servomotor and Servodriver Delta B3 750W X/Y, Delta B3 1000W Z and Bosch Rexroth C5 ballscrews with preloaded nuts.
1 year 9 months ago #319706 by Unlogic
I feel you pain, buying this kind of hardware as hobbyist through the big reseller in Europe was a challenge for me too. Many reseller aren't really interested in hobbyists.
I ended up purchasing my X/Y/Z servos from this store on AliExpress (seems to be no longer active): topstock.aliexpress.com/store/1155094
The spindle servo which I purchased later is a special high RPM version which nobody had listed online. After asking many sellers I finally got one to add it to their store (ignore the photo in the listing as it's showing the wrong servo): www.aliexpress.com/item/1005007120864062.html
The balls screws where the same story eventually however I was able to make a special order from L-system here in Sweden ( l-system.se/ ) who sold me the ball screws and machined them for me.
Most of the smaller electronic stuff was bought from www.tme.eu which had the best prices and lot's of items in stock.
1 year 9 months ago #319710 by leglaive
hello,
i would like to know if it is possible to send me a complet list of a material that you use with refenrences. Because for exemple, i have a lot of difficulty to find a sensormotor and sensordriver Delta B3 750W X/Y, Delta B3 1000W Z and Bosch Rexroth C5 ballscrews with preloaded nuts. If you have a websites to order all materials i'm interessed.
Thank's
Time to create page: 0.196 seconds
