3 months 1 day ago - 3 months 21 hours ago #348282 by viewsat
My settings are as follows, JSON file attached.
Last edit: 3 months 21 hours ago by viewsat.
3 months 1 day ago #348283 by meister
i only see the screenshot :)
3 months 1 day ago #348284 by viewsat
The JSON file has been uploaded.
3 months 23 hours ago - 3 months 23 hours ago #348289 by meister
ahh, sorry, you need to set the scale (signals/dty)
if your spindle max speed is 20000rpm, you need to set it to 0.005
# 100 / 20000 = 0.005
EDIT: will try to add a little helper-tool for easy setup
Last edit: 3 months 23 hours ago by meister.
The following user(s) said Thank You: viewsat
3 months 21 hours ago - 3 months 21 hours ago #348295 by viewsat
Thank you for your help. The spindle PWM pin is now working.
The following user(s) said Thank You: tommylight, meister
3 months 20 hours ago #348297 by tuxcnc
I have a question.
At github.com/multigcs/riocore/blob/main/ri...ugins/fpga/BOARDS.md TangNano1K is marked as supported.
I know 1k gates is few, but is supported.
But I can't find any stuff for this board at repository.
I wonder is it possible to use this as one axis controller.
For example in situation when somebody have got working machine and could not make any changes to it, but needs to add 4/5th axis, rotary table, tools magazine or something similar.
Time to create page: 0.162 seconds
