3 months 19 hours ago - 3 months 18 hours ago #348300 by meister
You’re right, it’s actually too small for a full setup.
But you could use it, for example, as a satellite, as an extension or for a distributed setup.
www.youtube.com/shorts/2vjq0Kd5WOE
In principle, a single-axis setup would also work, though it’s always a bit tricky to have mixed setups.
I’ve done a test compile:
Resources | Usage | Utilization
Logic | 956/1152 | 83%
and it fits :)
with USB/Serial it's to slow.
EDIT: BTW, the boards in the list are just the ones that have pre-defined pin assignments and can therefore be used easily in the Flow frontend. However, it’s also quite easy to add new boards, or you can let me know which ones you’d like to see included – as long as the FPGA supports them, it’s no problem.
Last edit: 3 months 18 hours ago by meister.
2 months 4 weeks ago #348364 by babinda01
Thanks, heaps, for the info. I have a working config for Ethercat on my raspberry pi 5, So I will play around with connecting a tang 9k to the spi on the pi and see how I go. I will post more info if/when i get it working.
Thanks again.
Andrew
2 months 4 weeks ago #348366 by tuxcnc
I'm sorry I'm not kindly to you, but your very hard work will be useless, if you have important things in secret.
For example you adviced in github md "than copy a config file that is near to your setup", but there are no tangnano1k setups in github, but I see you have some setups for this board , because you show about it on YouTube...
Share your configs, please.
2 months 4 weeks ago #348378 by meister
Sorry, but I can’t exactly create a sample for each of the 100,000 possibilities.
But it’s not difficult to create a configuration from scratch.
The following user(s) said Thank You: kzali
2 months 4 weeks ago #348380 by tuxcnc
I don't ask you for all possibilities, but only for share configs you used for your tests.
2 months 3 weeks ago - 2 months 1 week ago #348476 by viewsat
DIR/PULSE is working fine, problem solved, thank you!!
I'm using the DM542 Microstep Driver shown in the photo, with a Tango Nano 9k FPGA. After executing a set of gcode in Linux CNC, there's an error in returning to the zero-point position. However, I can correctly return to the zero-point position using a Mesa7i92.
Attachment not found
Last edit: 2 months 1 week ago by viewsat.
Time to create page: 0.160 seconds
