- Thank you received: 502
- meister
2 months 2 weeks ago #348701
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Sorry for my poor English – enjoy it; it’s the first and probably the last video in which I’ll try to speak English.
www.youtube.com/shorts/u9xUOXN080M
Well, yes, blue is a 3.3V level, as I measured it directly at the FPGA pin
The following user(s) said Thank You: viewsat
- tuxcnc
- Thank you received: 56
2 months 2 weeks ago #348705
by tuxcnc
I wrote that modifying Chinese electronics is a bad idea, which is true for several reasons.
Cheap PCBs do not tolerate re-soldering very well, the copper peels off from the substrate, even if something works well immediately after such an operation, there is no guarantee that it will work after a month or a year.
Is there any prohibition against writing about it?
PC817 is a strange chip that works in a strange way.
First of all, it is an analog circuit, not a digital one.
Secondly, the input is controlled by current, not voltage, and the output forces current, not voltage.
In addition, the frequency response strongly depends on the input current, a small current means a small propagation time, but also a small output current.
The chip can work really fast (several dozen kilohertz), but then it may not drive the next stage with a small current.
However, when driven by high current, it may have problems already at a few kHz.
There must always be some compromise, assuming that the designer knew what he was doing and did not assume that if the PC817 withstands 50 mA, 20 will be fine...
Replied by tuxcnc on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
I have never written anywhere that I forbid anyone to do anything.
The following user(s) said Thank You: viewsat, tommylight
- Thank you received: 5334
2 months 2 weeks ago #348708
Replied by PCW on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Not really strange at all, almost all transistor/Darlington output optocouplers function this way
and this type optocoupler is by far the most common.
Logic optocouplers also typically have current inputs (since the input of most optocouplers is simply a bare LED)
but differ in having a voltage output.
- viewsat
- Thank you received: 10
2 months 2 weeks ago - 2 months 1 week ago #348714
by viewsat
Replied by viewsat on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
DIR/PULSE issue resolved, thank you!! (2026-08-19)
I used this inexpensive DM542 only for testing RioCore, not for an actual CNC machine tool. The circuit modifications are for technical discussion only, please don't mind. I'm showing four sets of drivers in the photos, but only this inexpensive DM542 has a problem, hence this discussion. Strangely, increasing the dirhold value doesn't solve the problem; I really can't understand this. However, this inexpensive DM542, when used with the same settings on a MESA7I92, shows no positioning error. This inexpensive DM542 was taken from my existing engraving machine for testing.
Last edit: 2 months 1 week ago by viewsat.
- viewsat
2 months 2 weeks ago - 2 months 1 week ago #348717
by viewsat
DIR use pc817 Error!
DIR modified 6N137 ok!!
- tuxcnc
2 months 2 weeks ago #348721
by tuxcnc
There, PC817 supported not only dir inputs, but also step inputs. There were problems with this, but the chips were in sockets and it was easy to replace them with selected ones and it worked somehow.
So there are only two options:
1. Your driver is faulty.
2. This type of driver is poorly designed.
Either way, the cause is not to be found in riocore.
A long time ago, 3xTB6560 drivers were popular and I had them too.I'm showing four sets of drivers in the photos, but only this inexpensive DM542 has a problem
Time to create page: 0.385 seconds
