Schaublin 125-CNC retrofit.
4 years 11 months ago #227301 by anfänger
Replied by anfänger on topic Schaublin 125-CNC retrofit.
I thin you make good progress.
My first Retrofit took me roughly four years. The second amount 9 months. It always needs more time than one thinks.
4 years 11 months ago #227306 by skunkworks
Replied by skunkworks on topic Schaublin 125-CNC retrofit.
It has become my sunday ritual.. Watch the latest RotarySMP video..
Keep them coming!
sam
The following user(s) said Thank You: RotarySMP, DoWerna
4 years 11 months ago #227809 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
The following user(s) said Thank You: piasdom, arvidb, tommylight, anfänger
4 years 10 months ago #228385 by RotarySMP
The following user(s) said Thank You: arvidb, tommylight, anfänger, spumco
4 years 10 months ago #228386 by tommylight
Replied by tommylight on topic Schaublin 125-CNC retrofit.
To late, i already watched it ! :)
4 years 10 months ago - 4 years 10 months ago #228418 by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
Mark,
Nice vid, thanks for posting.
[note - forgive me if I'm covering something you already know]
Noted a number of comments in the vid about 'filtering' the VFD to protect the motor, but none of them appeared to identify exactly what you might need/want.
What you're looking for is a load reactor (pic below).  This goes between the VFD and the motor and smooths out the harmonics produced by the VFD as it does its AC to DC to AC magic.  Also reduces motor heating (helps quite a bit if you're operating a "non-VFD-rated" motor with a VFD).
If you have a decent VFD with a load reactor, you should have no issues running that motor.
They are fairly expensive new, but ebay is littered with them if you search for 'line reactor.'  A line reactor is exactly the same thing, but is installed between the VFD and the incoming line voltage where it reduces noise than can be back-fed in to the mains wiring.
Assuming you're at 380VAC-3P and the motor is 3kw (from the vid), you should be able to find a 10a 600V line reactor pretty easily.
Ebay Austria (your location, no?) has 34 hits searching for 'line reactor' (in English), and plenty in the 7A-15A range.  Ebay Germany has around 40.
Looks like Elau, Allen-Bradley, and Siemens are the top brands available.
Pro Tip - these things can be mislabeled as 'transformers'.  They look similar to transformers - big coil of copper thing - to the uninitiated.  So you might find one for scrap value if you've got a local machinery dealer/scrapper.
Something else to consider while you're deciding if you keep the varidrive... how much spindle torque do you need? You can estimate the required torque for anticipated cuts with a decent Feeds & Speeds program, and I bet you won't need as much as you think.
I suspect the massive gear reduction on that lathe was mostly to slow down the surface speed; the increased torque was a nice by-product.  Coated carbide tooling wasn't as universal when it was built, and a large part with HSS tools would need the lower surface speed.
Keeping the vari-drive would simplify things mechanically right now... until something goes wrong or breaks or you have to replace that belt.
Food for thought.
Cheers,
Ralph
Last edit: 4 years 10 months ago by spumco. Reason: formatting
The following user(s) said Thank You: RotarySMP, arvidb, anfänger, DoWerna
Moderators: piasdom
Time to create page: 2.867 seconds
