- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
4 years 11 months ago #227067
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
- Thank you received: 7491
4 years 11 months ago #227068
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Can you disable UEFI and secure boot?
That may require reinstalling the OS.
- RotarySMP
4 years 11 months ago #227071
by RotarySMP
Yep, look like I need to reinstall the OS. Just doing it now.
- RotarySMP
4 years 11 months ago #227072
by RotarySMP
Darn, now I get the CD-ROM could not be mounted. I remember I had issues like this on the Mini lathe PC, but cant remember how to fix it.
4 years 11 months ago #227077
Remove the USB, insert the USB, click next/continue.
That is something i read here several times, never happened to me though.
4 years 11 months ago #227080
Replied by andypugh on topic Schaublin 125-CNC retrofit.
It looks like you have 6ms of latency.
The hostmot2 manpage says:
(u32 read/write) timeout_ns
Watchdog timeout, in nanoseconds. This is initialized to 5,000,000 (5 milliseconds) at module load time. If more than this amount of time passes between calls to the hm2 write() function, the watchdog will bite.
So that all fits.
For experimenting on the bench you could set timeout_ns higher, until the watchdog stops biting, but when it comes to running the machine it needs to be sorted out.
So that all fits.
Time to create page: 1.414 seconds
