- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
4 years 11 months ago #226890
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks Andy, I appreciate your time here.
So far I have just been using:
halrun
loadrt hostmot2
loadrt hm2_eth board_ip=10.10.10.10
show pin
I just looked up my Minilathe HAL, and guess I need the config info.
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=1 num_stepgens=2 sserial_port_0=00xxxx"
I tried adding the Sserial_port_0=00xxxx to my loadrt eth_hm2 line. Now I have nothing show pins, so that was not the right syntax.
I will be using 3 Sserial ports, is the syntax then sserial_port_0=0000xx?
setp [HMOT](CARD0).watchdog.timeout_ns 5000000 but it returns "INI Variable 8
but it returns INI_Variable [HMOT](Card0) not found. Should I replace this with "7i92"?
I also tried PNFConf, but there is no config for the 7i92 with 7i85sc2D bitfile.
halrun
loadrt hostmot2
show pin
4 years 11 months ago - 4 years 11 months ago #226898
Replied by andypugh on topic Schaublin 125-CNC retrofit.
halrun
loadrt hostmot2
show pin
loadrt threads
addf hm2_7i92.0.read thread1
addf hm2_7i92.0.write thread1
start
Last edit: 4 years 11 months ago by andypugh.
- RotarySMP
4 years 11 months ago #226958
by RotarySMP
Thanks Andy, Sorry I didn't get to try that yesterday, as I would out visiting a very helpful viewer who did the trouble shooting of my damaged 7i84. I'll try this this evening.
- RotarySMP
4 years 11 months ago #227061
by RotarySMP
When I run the "start" I get hm2/hm2_7i92.0: watchhdog has bit! (set the .has-bit to False to resume)
But hm2_7i92.0.watchdog.has-bit is set to false when I show pins.
When I run the command
setp hm2_7i92.0.watchhdog.has_bit false
it returns
hm2/hm2_7i92.0:error recovery successful!
and the watchdog led stays lit.
Next I tried creating a config with PNFConf, and then deleted everything but the set up, (see attached HAL). This loads, but then I get the "watchdog has bit" as a Gmoccapy pop up meesage straight away.
it returns
- RotarySMP
4 years 11 months ago - 4 years 11 months ago #227063
by RotarySMP
Last edit: 4 years 11 months ago by RotarySMP.
- Thank you received: 7491
4 years 11 months ago #227065
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Looks that it is a latency issue, horrible does not do justice to explain that result!
Does it have hyperthreading?
Time to create page: 0.159 seconds
