Maho MH 300 C Retrofit...?
- pl7i92
- Thank you received: 358
11 Mar 2019 13:22 #128326
by pl7i92
Replied by pl7i92 on topic Maho MH 300 C Retrofit...?
if there are sidepanels or special entry gmoccapy will not load
- Fermaq
11 Mar 2019 19:08 - 11 Mar 2019 19:09 #128372
by Fermaq
Replied by Fermaq on topic Maho MH 300 C Retrofit...?
Where I can find that? (QTpyvcp)...
there are new interfaces on the QTpyvcp tread look there to get your best choice
But I can not find gmoccapy..., and how I replace that? For me still exist more one problem, the language, and google translator (or others) is not the bestIf you replace the entry for AXIS with the following in your Ini, does it not start with Gmoccapy?
Mark
Who is sidepanels? and what I can do for i have gmoccapy?if there are sidepanels or special entry gmoccapy will not load
Last edit: 11 Mar 2019 19:09 by Fermaq.
- RotarySMP
- Thank you received: 595
11 Mar 2019 22:08 #128385
by RotarySMP
Replied by RotarySMP on topic Maho MH 300 C Retrofit...?
As I understand it, Axis, Gmoccapy etc are already compiled into the LinuxCNC live image, therefore you don't need to find or install anything, you just call it from your ini as it is already there.
Mark
Mark
- Fermaq
15 Mar 2019 18:11 #128677
by Fermaq
...I wanted to install the drives of the graphics card on the linux operating system and I do not know how to do it.
"(...) you just call it from your ini as it is already there."
How can I do that? and how I can save that for I do not have the same problem in future...?
- Thank you received: 5321
15 Mar 2019 18:42 - 15 Mar 2019 18:43 #128678
Replied by PCW on topic Maho MH 300 C Retrofit...?
In general its a bad idea to install proprietary drivers on RT OSes
Graphic performance not too important for LinuxCNC unless you have very slow hardware.
High end graphics cards are often more of a liability than an asset for LinuxCNC (they also reduce system reliability)
Last edit: 15 Mar 2019 18:43 by PCW.
- Fermaq
15 Mar 2019 22:12 #128690
by Fermaq
Ok, so I will not install. The graphics is nothing special, simply in the Windows operating system it is usually necessary to install the graphics drives. But how do I do the rest, how do I get gmoccapy and others
- RotarySMP
16 Mar 2019 08:37 #128718
by RotarySMP
You have installed LinuxCNC from thelive image right? If not do that.
Then use the LinuxCNC configuration tool to create a machine. This will create a folder on the desktop which contains your machines HAL, INI, tool table etc. Open the [your_machine_name].INI and edit the display section fro axis to gmoccapy.
Actually, I think there are already predefined gmoccapy configurations within that tool.
Mark
Mark
