Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
- TexasCNC
- Thank you received: 10
31 Aug 2019 22:03 #143748
by TexasCNC
Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine was created by TexasCNC
I cant seem to understand what is needed to get the configurator to work I created a new axis and its configured with my specs but then I also created a short cut with plasmac and tried the terminal commands and it doesn't do anything. Can some one help that done this?
- Thank you received: 4149
01 Sep 2019 00:25 #143752
Replied by rodw on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
Have you got a machine that has basix X, Y & Z movement under linuxcnc control?
If not, then its a linuxcnc issue not a Plasmac issue.
- TexasCNC
01 Sep 2019 01:31 #143754
by TexasCNC
Replied by TexasCNC on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
I got a base machine working and I ran a cut through it al worked fine but now I am moving to the next step on to 4.6 to add plasmac. I dont see the configurator any where I went back and reinstalled the 2.9 and updates and still dont see it.
01 Sep 2019 04:14 #143755
What version is reported when you run Linuxcnc from the command line? Does it show 2.9? Did you build from source? If so you need to run the rip-environment script to set all the paths up so it can find the 2.9 resources.
- phillc54
- Thank you received: 2100
01 Sep 2019 08:39 #143764
by phillc54
If you did a Run In Place installation, Configurator should be at ~/linuxcnc-dev/configs/by_machine/plasmac/configurator.py assuming you cloned with this command: git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev while you were in you home directory.
Replied by phillc54 on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
If you did a BuildBot installation, Configurator should be at /user/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.pyI got a base machine working and I ran a cut through it al worked fine but now I am moving to the next step on to 4.6 to add plasmac. I dont see the configurator any where I went back and reinstalled the 2.9 and updates and still dont see it.
- TexasCNC
01 Sep 2019 14:00 #143779
by TexasCNC
I was using buildbot to get 2.9 and I know I had 2.9 cause the axix GUI shows it being 2.9 I did like 3 updates from buildbot and I finally got the linuxcnc-dev folder before I wasn’t getting that folder only linuxcnc folder. And I was able to find the configurator.py folder let me run this and see what happens.
- TexasCNC
01 Sep 2019 15:54 #143788
by TexasCNC
Getting a error when I try to open the new created machine saying pin 12 does not exist
- TexasCNC
01 Sep 2019 19:09 #143799
by TexasCNC
its The arc ok signal pin that gives me the error of pin does not exist. I am running the mode 2 configurator and I already tried changing then signal to another pin on my working config and rerun the configurator and still gives the error I had changed to pin 15 and gives the error of pin 15 does not exist. What is the problem anybody?
- phillc54
01 Sep 2019 23:26 - 01 Sep 2019 23:53 #143821
by phillc54
Edit your connections.hal file and comment out the line that refers to that pin.
Start LinuxCNC and run HalShow and check that the name of the pin matches what you entered.
Edit: it may help if you could post your HAL and INI files.
Last edit: 01 Sep 2019 23:53 by phillc54.
- phillc54
01 Sep 2019 23:52 #143822
by phillc54
If you are using a BuildBot installation then there should not be a linuxcnc-dev directory, that is only for a Run In Place buildI was using buildbot to get 2.9 and I know I had 2.9 cause the axix GUI shows it being 2.9 I did like 3 updates from buildbot and I finally got the linuxcnc-dev folder before I wasn’t getting that folder only linuxcnc folder. And I was able to find the configurator.py folder let me run this and see what happens.
Time to create page: 0.677 seconds
