Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
03 Sep 2019 04:48 #144024 by phillc54
You don't need any Z motion in your GCode files. If there is Z motion the PlasmaC GCode parser will remove it.
You can try the attached one, just remove the .txt from the end of the file.
03 Sep 2019 04:52 #144026 by TexasCNC
I get the bottom limit reached when its probing
this the values I came up with
MIN_LIMIT = -0.002
MAX_LIMIT = 0.555
[JOINT_2]
TYPE = LINEAR
HOME = 0.555
MIN_LIMIT = -0.002
MAX_LIMIT = 0.555
MAX_VELOCITY = 0.645380434783
MAX_ACCELERATION = 3.0
STEPGEN_MAXACCEL = 3.75
SCALE = 6400.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.555
HOME_SEQUENCE = 0
03 Sep 2019 04:55 #144027 by TexasCNC
Sorry the attached file you put was for what?
03 Sep 2019 04:56 #144028 by phillc54
I would imagine that you should have at least a couple of inches travel to allow for tip ups sheet buckling.
That is a SheetCam post processor.
03 Sep 2019 04:59 #144029 by phillc54
MIN_LIMIT = -0.001
MAX_LIMIT = 3.001
HOME = 3.0
HOME_OFFSET = 3.0
HOME_SEQUENCE = 0
If you used say a 3" block of wood and put that on you slats then jog Z so it just touches the block then home your machine.
03 Sep 2019 05:00 #144030 by TexasCNC
Oh ok I can upload that to to the axis gui to test? I keep getting reaching bottom limit reached I have adjusted the limit and I seem to not get it right SMH
03 Sep 2019 05:02 #144031 by phillc54
Is the float switch LED turning on?
03 Sep 2019 05:06 #144032 by TexasCNC
no its not.. it probes down then it get slow then it backs back out and pauses the cut and gives the error of *bottom limit reached when probing down*
The file you sent what did you want me to do with it?
03 Sep 2019 05:09 #144033 by phillc54
Can you make the LED come on by activating the float switch by hand. You don't need to be running a program, the float switch is active all the time.
I thought you said you used a SheetCam post processor for your Mach software.
03 Sep 2019 05:13 #144034 by TexasCNC
Well the design I have to test the machine I use sheetcam with post processor of mach 3 with no Z thats one of the options it has there.
Yes the LED does turn on when I activate the float switch
Time to create page: 0.520 seconds
