Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
- TexasCNC
- Thank you received: 10
02 Sep 2019 02:31 #143840
by TexasCNC
Replied by TexasCNC on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.9.0-pre0-525-gead53e6
Machine configuration directory is '/home/carr/linuxcnc/configs/torch_height'
Machine configuration file is 'torch_height.ini'
INIFILE=/home/carr/linuxcnc/configs/torch_height/torch_height.ini
VERSION=1.1
PARAMETER_FILE=imperial_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./torch_height.hal
twopass:found ./plasmac.hal
twopass:found ./torch_height_connections.hal
twopass: Error in file ./torch_height_connections.hal:
Pin '15' does not exist
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
- phillc54
- Thank you received: 2100
02 Sep 2019 02:31 #143841
by phillc54
Replied by phillc54 on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
That's better...
OK, the pin names need to be parport.0.pin-nn-out or parport.0.pin-nn-in like in your HAL file
- Thank you received: 4138
02 Sep 2019 02:31 #143842
No its not.
Replied by rodw on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
here is the error
No its not.
- phillc54
02 Sep 2019 02:36 #143843
by phillc54
I just noticed that you already have those pins connected in your HAL file. You will need to comment them out there.
- TexasCNC
02 Sep 2019 02:44 #143846
by TexasCNC
Where do I comment them out? Sorry I was trying to figure why the error wasn’t pasting.
- phillc54
02 Sep 2019 03:15 #143852
by phillc54
try this one:
- TexasCNC
02 Sep 2019 03:55 #143859
by TexasCNC
Still get error for pin 15 does not exist
- phillc54
02 Sep 2019 03:56 #143860
by phillc54
Did you fix the name in your connections.hal
- TexasCNC
02 Sep 2019 03:59 #143861
by TexasCNC
here?
net plasmac:arc-ok-in 15 => plasmac.arc-ok-in
net plasmac:float-switch 10 => debounce.0.0.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => debounce.0.1.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => debounce.0.2.in
# net plasmac:ohmic-enable plasmac.ohmic-enable => {YOUR OHMIC ENABLE PIN}
net plasmac:torch-on => 14
net plasmac:move-up 13 => plasmac.move-up
net plasmac:move-down 11 => plasmac.move-down
- phillc54
02 Sep 2019 04:00 #143862
by phillc54
Yes, use this.
# Keep your plasmac i/o connections here to prevent them from
# being overwritten by updates or pncconf/stepconf changes
# Other customisations may be placed here as well
# This file is built by the configurator in your configuration directory
#***** debounce for the float switch *****
# the lower the delay here the better
# each 1 is a 0.001mm (0.00004") increase in probed height result
loadrt debounce cfg=3
setp debounce.0.delay 5
addf debounce.0 servo-thread
#***** arc voltage lowpass cutoff frequency *****
#***** change to the cutoff frequency you require *****
setp plasmac.lowpass-frequency 0
#***** the joint associated with the Z axis *****
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-position
net plasmac:arc-ok-in parport.0.pin-15-in => plasmac.arc-ok-in
net plasmac:float-switch parport.0.pin-10-in => debounce.0.0.in
net plasmac:torch-on => parport.0.pin-14-out
net plasmac:move-up parport.0.pin-13-in => plasmac.move-up
net plasmac:move-down parport.0.pin-11-in => plasmac.move-down
# a 1 here allows multiple tools to be used
# gcode M3 S1 needs to be changed to:
# M3 $0 S1 for the plasma torch
# M3 $1 S1 for the air scribe
setp plasmac.multi-tool 0
# net plasmac:air-scribe-arm plasmac.air-scribe-arm => ***YOUR_AIR_SCRIBE_ARMING_OUTPUT***
# net plasmac:air-scribe-start plasmac.air-scribe-start => ***YOUR_AIR_SCRIBE_START_OUTPUT***Please Log in or Create an account to join the conversation.
