Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
02 Sep 2019 20:36 #143938 by TexasCNC
It looks like when I trying to home the z axis it moving the z axis up away from material like its looking for a switch. I cant find it on the config is there a way to home the z axis without needing a home switch cause the x and y home as soon as i hit home axis?
02 Sep 2019 21:13 #143954 by rodw
This will solve your homing problem
linuxcnc.org/docs/devel/html/config/ini-...ml#_immediate_homing
But if you have a gantry you will need home switches on each side as that is how the gantry is squared up when homing with 2.8 and 2.9
02 Sep 2019 22:54 #143964 by phillc54
If you do it the way Rod has linked to it will work OK. You will need to have some match marks on your machine so you can line them up before homing. I have never used home or limit switches before and have not had any problems.
02 Sep 2019 23:31 #143974 by TexasCNC
What do I need to put for not to use homing my machine is a 4x2 table and never had problems I usually cut within the limit of my machine?
02 Sep 2019 23:39 #143976 by phillc54
In the [JOINT_2] section of your INI file comment out these two lines:
HOME_SEARCH_VEL = 0.050000
HOME_LATCH_VEL = 0.050000
In every [JOINT_n] section add the line:
HOME_SEQUENCE = 0
03 Sep 2019 00:24 #143979 by TexasCNC
its still picking up the z axis when i home the Z axis
03 Sep 2019 00:26 #143981 by TexasCNC
and when i try to enter a command on the MDI section it gives me a error of
Cant issue command when not homed
Position: Relative Actual
03 Sep 2019 00:27 #143982 by phillc54
You need to edit the INI file that the Configurator made, something like <machine_name>.ini
03 Sep 2019 00:56 #143992 by TexasCNC
ok got it now thanks i got the button to home all now instead of doing individually. But how do I turn on the plasma I am entering the command m3 on the MDI and I dont here the relay clicking the torch button is enabled on the axis?
03 Sep 2019 01:10 #143993 by phillc54
You need a program running to fire the torch or you can use the torch pulse button
Time to create page: 0.216 seconds
