Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
02 Sep 2019 04:04 #143863 by TexasCNC
got the error again
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./torch_height.hal
twopass:found ./plasmac.hal
twopass:found ./torch_height_connections.hal
twopass: Error in file ./torch_height_connections.hal:
Pin 'parport.0.pin-15-in' was already linked to signal 'probe-in'
02 Sep 2019 04:06 #143864 by phillc54
Can you post ALL the .HAL files from your configuration directory
02 Sep 2019 04:10 #143866 by phillc54
You could try running Configurator again using your INI file and the HAL file I posted and use the pin names from the connections.hal file I posted in the Configurator.
02 Sep 2019 04:19 #143869 by TexasCNC
ok here are the files
02 Sep 2019 04:24 #143872 by phillc54
Replace your torch_height.hal with this one.
I would recommend that you comment out the same lines in your original hal file as well in case you want to rebuild.
02 Sep 2019 04:32 #143874 by TexasCNC
I rebuild the through configurator and I paste the torch connections you gave me and it finally worked it opened up the axis gui
Thanks alot the only thing is that is my torch on relay is switching on or clicking cause I dont have the plasma on how do i invert the pin I had done that to my original working config?
02 Sep 2019 06:44 - 02 Sep 2019 06:46 #143885 by phillc54
Edit your torch_height_connections.hal
find this line:
net plasmac:torch-on => parport.0.pin-14-out
and insert this line above it:
setp parport.0.pin-14-out-invert 1
Last edit: 02 Sep 2019 06:46 by phillc54. Reason: put setp in...
02 Sep 2019 15:07 #143899 by TexasCNC
Thanks it worked...Does this go for any other port that needs to be inverted I can use the same command and just insert it above the existing command?
02 Sep 2019 17:40 #143911 by TexasCNC
I have Arc ok light on on my GUI and float switch on also. I wanted to invert this pins as well I tried adding that same command but switching the pin but that doesn’t work is there another command I need to use to invert the arc ok and float switch pins?
02 Sep 2019 20:13 #143931 by TexasCNC
OK i was able to find the command to invert the input pins. But how do I home the Z axis it wont let me do anything on the axis gui cause it says to home the axis in which I did but keeps giving me the error on the bottom right corner that the axis need to be homed. i see the Z axis values on the screen that they are moving up and down but nothing it still dosnt let me start the anything.
Time to create page: 0.385 seconds
