Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
03 Sep 2019 05:52 #144049 by phillc54
Post your torch_height.ini, torch_height.hal and torch_height_connections.hal
torch_height is your machine name right?
03 Sep 2019 05:58 #144050 by TexasCNC
03 Sep 2019 06:11 - 03 Sep 2019 06:20 #144052 by phillc54
change the following to these values
[AXIS_Z]
MAX_LIMIT = 3.001
[JOINT_2]
HOME = 3.0
MAX_LIMIT = 3.001
HOME_OFFSET = 3.0
set your X axis in the centre of its travel
set your Y axis in the centre of its travel
set your Z axis so the torch tip is 3" above the slats
press the home button
jog the Z axis down to approx. level with the slats
press the touch off button
enter 0 for the touch off value
jog the Z axis to the top
from now on, every time you power your machine up you need to set all the axes up as above then press home.
you won't need to touch off again.
Edit: You should be able to use the Probe Test button to test probing.
Last edit: 03 Sep 2019 06:20 by phillc54.
03 Sep 2019 06:25 #144053 by TexasCNC
OK did all that but it tells me the the bottom limit reached while probing
Was there anything you wanted to put for the min limit?
03 Sep 2019 06:28 #144054 by phillc54
No, -0.4 should be good.
What thickness is the material you are probing down to?
03 Sep 2019 06:30 #144055 by TexasCNC
1/8 or 10 gauge
03 Sep 2019 06:31 - 03 Sep 2019 06:33 #144056 by phillc54
Try some thicker stuff.
What is your probe height.
Just use probe test for the time being.
Edit: you may need to change BUTTON_2_CODE = probe-test 3 to BUTTON_2_CODE = probe-test 10
Last edit: 03 Sep 2019 06:33 by phillc54.
03 Sep 2019 06:41 #144057 by TexasCNC
gonna try it and see and go to sleep its almost 2am here
THANKS ALOT FOR THE HELP APPRECIATE IT
03 Sep 2019 06:43 #144058 by phillc54
Near 5pm here...
We will get you going
03 Sep 2019 09:07 #144062 by rodw
I just wondered....
You are not by chance using existing gcode from Mach3 that probes for the surface using gcode are you?
If you are, download the sheetcam post processor Phill uplloaded earlier today, rename it so it is a .scpost file, install the post file in sheetcam and rerun sheetcam on your part. The mach code and the plasmac code are NOT interchangeable.
Time to create page: 0.145 seconds
