Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
- phillc54
- Thank you received: 2100
05 Sep 2019 03:01 #144186
by phillc54
Replied by phillc54 on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
I just noticed a scaling error in the gcode you sent.
I normally use metric.
Try this one and could you send me a copy of the gcode it produces so I can compare it.
- TexasCNC
- Thank you received: 10
05 Sep 2019 03:12 #144188
by TexasCNC
Replied by TexasCNC on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
ok let me get to my laptop with windows that has sheetcam on it
- TexasCNC
05 Sep 2019 03:51 #144192
by TexasCNC
Man I forgot to change the file I had done earlier today fromt .txt to .scpost
- TexasCNC
05 Sep 2019 03:56 #144193
by TexasCNC
ok here with new post processor
- phillc54
05 Sep 2019 04:07 #144194
by phillc54
The tracking tolerance is fixed meaning it won't cut sharp corners off now.
I think it is reporting cut length wrong but I can't check because my computer has decided to update itself. That won't cause cut problems though.
- phillc54
05 Sep 2019 04:17 - 05 Sep 2019 04:17 #144195
by phillc54
This will fix it, I left out a zero...
Edit: oops, I left out the attachment...
Last edit: 05 Sep 2019 04:17 by phillc54.
- TexasCNC
05 Sep 2019 04:19 #144196
by TexasCNC
oh ok i see
I did notice I was cutting the same design but bigger last one one was 6 inch circle and the new one was 8 inch circle and when it was doing the last cut which is the outside half way through the circle the z axis moved up like about an inch above material which didn't cut the material just scored it so i checked the proma and the voltage was set the same as the previous one 82V and it did it again half through the Z axis moved up but these time the score was enough to make cut through. Would it be something with the gcode?
- TexasCNC
05 Sep 2019 04:20 #144197
by TexasCNC
And it doesnt like the lead out either I am guessing the axis doesnt. Cause I changed the the code just to lead in only no lead out and I didnt have the arc error anymore.
- phillc54
05 Sep 2019 04:24 #144198
by phillc54
A quick look at the GCode doesn't show anything that would cause it.
I wouln't have thought that a lead out would cause any problems, could you post some code that has a lead out and causes the problem.
- TexasCNC
05 Sep 2019 04:35 #144199
by TexasCNC
this one
Time to create page: 0.138 seconds
