Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
- TexasCNC
- Thank you received: 10
06 Sep 2019 13:49 #144379
by TexasCNC
Replied by TexasCNC on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
Thanks guys I will look into further down the line I was just wondering about it as I see some do both for probing ohmic primary and backup the float switch.
- TexasCNC
06 Sep 2019 14:18 #144384
by TexasCNC
I missed this
Line 190 of thc.hal:
net LimitZ parport.0.pin-15-in => or2.2.in0
expects a limit switch on parallel port pin 15, do you have that?
if not you could try changing the line to:
net LimitZ parport.0.pin-15-in-not => or2.2.in0
or even commenting it out but I have no idea what the repercussions would be...
Thanks Phill I didnt see this reply I might of skipped it but this worked thanks
- TexasCNC
12 Sep 2019 20:42 #144983
by TexasCNC
Is there any way to make the torch go back to home location after cut. Pretty much the spot where you home it before it starts cutting? I want the torch to go back to home location after my cuts.
- Thank you received: 4149
12 Sep 2019 21:43 #144990
Just add G0 X0 Y0 before the last M30 in your file but it might be prudent to also add another G0 command to lift the Z axis to a safe height before this (ask me how I know?)
Replied by rodw on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
- Thank you received: 7478
12 Sep 2019 22:38 #144994
Inkscape does that always, in that it adds a G0 X0 Y0 Z0 at the end of every gcode file.
Replied by tommylight on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
I would venture a guess at collisions !......... it might be prudent to also add another G0 command to lift the Z axis to a safe height before this (ask me how I know?)
- phillc54
- Thank you received: 2100
12 Sep 2019 23:02 - 12 Sep 2019 23:59 #144999
by phillc54
Replied by phillc54 on topic Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
You can't use Z motion as the PlasmaC GCode parser will comment them out.
You just need to ensure that your safe height is really a safe height then put a G0 Xnnn Ynnn move after your last cut.
Edit: Which has just shown up a bug in the GCode parser, it isn't commenting Z moves correctly.
Last edit: 12 Sep 2019 23:59 by phillc54.
- TexasCNC
13 Sep 2019 01:54 #145019
by TexasCNC
Sorry but I didn’t know Inkscape had a cam feature?
13 Sep 2019 09:34 #145039
Inkscape comes with gcodetools installed and ready to use, it is very useful and does pretty much everything for 2D and some things for 2.5D milling/cutting/laser/plasma.Sorry but I didn’t know Inkscape had a cam feature?
- TexasCNC
28 Sep 2019 23:42 #146517
by TexasCNC
Does changing the parameters on the plasma config tab on GUI do any difference as far as the kerf width and cut height and all?
28 Sep 2019 23:51 #146521
They should, but better wait for Phill to reply later, as he is most probably sound asleep now.
Time to create page: 0.174 seconds
