Upgraded to 2.9 and stuck on 4.6. Add PlasmaC To Base Machine
03 Sep 2019 05:15 #144035 by phillc54
Yet it doesn't when it hits the material?
Just try setting you MIN_LIMITS to -0.251
03 Sep 2019 05:20 #144036 by TexasCNC
Is there a way to reset the touch off I entered the max limit of the z and now it wont go back to normal it gives me the error of linear move on line 10 would exceed the z limit it wouldnt give me this error before I entered something on the touch button.
03 Sep 2019 05:23 #144037 by phillc54
There shouldn't be any Z motion move in the GCode file, what does line 10 say in the display.
What is the amount of float switch travel you have and what value have you put in the Config panel for the float travel.
03 Sep 2019 05:27 #144038 by TexasCNC
I am using the same gcode file that i was before but I clicked on the touch off button and and entered the max limit of the z axis not sure why I was just trying things and now it gives me error for exceeding the the limit of the z every time i try to start the job.
I measure the flaot switch travel before i have it at .30 on the config tab
03 Sep 2019 05:29 - 03 Sep 2019 05:30 #144039 by phillc54
If you had jogged Z down then touched off you should enter 0.00, then jog back to the top.
Edit what thickness is the material you are probing down to.
Last edit: 03 Sep 2019 05:30 by phillc54.
03 Sep 2019 05:31 #144040 by TexasCNC
Yeah I dont know what the touch off did how does that work and how do I return it back to default cause I am getting a bunch of errors now about exceeding limits and all?
03 Sep 2019 05:35 - 03 Sep 2019 05:36 #144041 by phillc54
Did you have the Z axis at the correct height when you homed the machine, it is critical that you do.
Then you jog Z down to roughly level with the slats and touch off with a value of 0.00 You should never need to touch off again as long as you home the machine correctly.
Edit: if you have 0.3 of travel you will need to set your MIN_LIMIT to about -0.4
Last edit: 03 Sep 2019 05:36 by phillc54.
03 Sep 2019 05:38 #144042 by TexasCNC
no i didnt home correctly I entered a value on there I dont recall what it was but its way off now I get errors now it moves the axis when I hit run and it probes but then get all the erros about limits.
Is there a way to default the touch off sorry i wasnt aware of the feature just saw it in your steps and i didnt see what to do there.
03 Sep 2019 05:42 #144043 by phillc54
Homing is VERY important.
Because you don't have home switches you need to ensure that ALL three axes are in the correct position BEFORE you press the home button.
03 Sep 2019 05:45 #144047 by TexasCNC
Ok so how do i reset it to start fresh again?
Time to create page: 0.228 seconds
