Machine has been working great but my Proma THC is responding slow when cutting
23 Mar 2020 01:06 #161188 by TexasCNC
I edited mine and copy and paste yours on there. now the tool file is just a cheat sheet for me to have to use for future stuff? So now I need to copy my tools on sheetcam and import them to linuxcnc. You said that I can manually do it by inputting the seetings on the run panel right? And I see that you can add the voltage for the THC that would not be for the proma right?
23 Mar 2020 01:12 #161189 by phillc54
You may need to change some tool numbers
Yes, you can use the Materialverter that Rod linked to earlier.
Yes, you could also do it this way.
Correct, the Proma has it own settings.
23 Mar 2020 01:13 #161190 by TexasCNC
Also is there a way for the the THC not to turn off when I move the feed rate below 70ipm when I manually reduce the speed? When I am cutting 1/4 and I usually cut it at 45IPM the THC urns off and my table is not 100% flat so I get where my torch tip drags on the material.
23 Mar 2020 01:18 #161191 by phillc54
That is set by the VAD Threshold % in the Config Panel.
That is the percentage of the velocity in Cut Feed Rate in the Run Panel.
23 Mar 2020 01:20 #161192 by TexasCNC
oh ok got it so I just need to lower it down to 70% cause I think its set at 98%
23 Mar 2020 01:23 #161193 by phillc54
Yep, whatever percentage suits your requirements.
The following user(s) said Thank You: TexasCNC
23 Mar 2020 22:14 #161308 by TexasCNC
I am trying to figure out the converter what file am I importing on here? Am I labeling it the size of material I want to create?
23 Mar 2020 22:19 #161309 by phillc54
This is the file that does the conversion linuxcnc.org/docs/devel/html/plasma/plas...html#_materialverter
When you are happy with your SheetCam tool file then that is the file to be converted into a PlasmaC material file.
23 Mar 2020 22:42 #161311 by TexasCNC
I have sheetcam in another laptop not on where i have linuxcnc on I am confuse as far what file I need to use?
23 Mar 2020 22:44 #161312 by TexasCNC
Do i save my tool set on sheetcam and then import that to the converter?
Time to create page: 0.218 seconds
