Machine has been working great but my Proma THC is responding slow when cutting
20 Apr 2020 00:06 #164744 by phillc54
OK when the machine is at home the DRO is 0.000, is that correct?
Set the jog increment to 1" and jog down 1" and measure that it went 1" then jog up 1" and make sure it got back to where it started.
20 Apr 2020 00:16 #164745 by TexasCNC
No the machine when it’s homed the dro reads 2.2639
20 Apr 2020 00:19 #164747 by phillc54
If you followed this:
Jog X and Y to their home positions
Jog Z so the torch tip is 2" above the slats
"Home" all the axes
"Touchoff" the Z axis
then Z should be 0 at home position
20 Apr 2020 00:26 #164749 by TexasCNC
It doesn’t to be honest I never seen those ever go to 0.000 on any axis cause I manually homed the machine. Is there a way to change this so that all axis got to 0.0000 when I hit the home button?
20 Apr 2020 00:27 #164750 by phillc54
You need to use the "Touchoff" button to do that.
20 Apr 2020 00:31 #164751 by TexasCNC
It doesn’t change the value on the dro reading when I hit the touch off. To have it at 0.000
20 Apr 2020 00:34 #164752 by TexasCNC
I am seeing that on the touch button when I hit it it has a window but it says X coordinate? Does it have to say Z?
20 Apr 2020 00:35 #164753 by phillc54
You need to select the axis you want before you touchoff, click on the axis letter.
20 Apr 2020 00:36 #164754 by TexasCNC
It has PO through P9 with g54 through g59.3
20 Apr 2020 00:38 #164755 by TexasCNC
Oh ok I got it I need to choose the z axis on top of axis and then hit touch off. Ok I did that now it changes the dro to 0. Now I do a probe test and it goes down but doesn’t come close to material dro reading shows -1.5510
Time to create page: 0.184 seconds
