- LinuxCNC
- General LinuxCNC Questions
- Machine has been working great but my Proma THC is responding slow when cutting
- TexasCNC
- Thank you received: 10
20 Apr 2020 01:46 #164785
by TexasCNC
Replied by TexasCNC on topic Machine has been working great but my Proma THC is responding slow when cutting
Nope no error message.
I tried something and I changed the min limit on the ini file on z axis and joint 2 from -0.0001 to -0.7 and it probes down and hits Flor switch and comes back up with no errors. Can I leave it like that?
- phillc54
- Thank you received: 2100
20 Apr 2020 01:53 #164786
by phillc54
Replied by phillc54 on topic Machine has been working great but my Proma THC is responding slow when cutting
Yes, you have 0.3 float travel so you need the lower limit at least 0.3 lower than the lowest point of the slats
- TexasCNC
20 Apr 2020 02:02 #164789
by TexasCNC
Cool I will do that I ran test file really quick and it working now thanks a lot for the help. Your awesome man thanks a lot
- phillc54
20 Apr 2020 02:10 #164793
by phillc54
I wish I had spotted that probe speed earlier...
- TexasCNC
20 Apr 2020 02:13 #164794
by TexasCNC
No worries at least I get to learn it.
- Clive S
- Thank you received: 486
20 Apr 2020 03:23 #164805
by Clive S
Phill I think that you must have the patience of a saint .
Replied by Clive S on topic Machine has been working great but my Proma THC is responding slow when cutting
- TexasCNC
31 May 2020 13:55 #169545
by TexasCNC
Phil quick question can I wire a feather ohmnic sense in parallel with floating head pin which is the probe pin? The feather touch www.candcnc.net/store-home/ft-02-feather...h-ohmic-sensor-copy/
looks like it has its own relay and circuitry could I just wire it to the same pin I have already working? I want to say I have a open input port but I need to check. What changes when I switch to Ohmnic on the run tab would that work if it hook it up in parallel with my floating head? Do i need to switch anything on the ini file?
- Thank you received: 4156
31 May 2020 15:30 #169567
Replied by rodw on topic Machine has been working great but my Proma THC is responding slow when cutting
Why would you attempt to use a proprietary part designed for a specific THC system when you can follow the circuit in the Plasma primer and build something for half the price that everybody knows and can support?
Why would you look at a product that specifically says
It sounds like you are setting yourself up for failure to me.
We do not sell this for use on other brands of controllers and we will not provide support
(how to hook it up or troubleshooting ) for use on anything but CandCNC plasma controls with
DTHCIV/DTHC5. No refunds or warranty on units not used with CandCNC certified equipment.It sounds like you are setting yourself up for failure to me.
- Thank you received: 7509
31 May 2020 18:20 #169586
Replied by tommylight on topic Machine has been working great but my Proma THC is responding slow when cutting
I never used anything from them, but since the first time i saw their products i avoided them like the plague. At that time they were selling a THC with an arduino and a two line display for nearly 400$ ! On the cnczone forums there were also a lot of P.O. buyers as they got no replies or refunds.Why would you look at a product that specifically says
We do not sell this for use on other brands of controllers and we will not provide support (how to hook it up or troubleshooting ) for use on anything but CandCNC plasma controls with DTHCIV/DTHC5. No refunds or warranty on units not used with CandCNC certified equipment.
31 May 2020 18:26 #169590
And ask thefabricator03 how much he spent with them before throwing it out and adopting Plasmac.
- LinuxCNC
Time to create page: 0.253 seconds
