Machine has been working great but my Proma THC is responding slow when cutting
20 Apr 2020 00:39 #164756 by phillc54
OK, do the 1" test I posted earlier.
20 Apr 2020 00:40 #164757 by TexasCNC
20 Apr 2020 00:42 #164758 by phillc54
If you do a continuous jog down what does the DRO end up at when it cannot go any further.
20 Apr 2020 00:44 #164759 by TexasCNC
20 Apr 2020 00:47 #164761 by phillc54
That doesn't make sense, the torch goes from 2" above the slats down to the slats and the DRO goes from 0 to -0.0254?
-0.0254 sounds like a metric conversion...
20 Apr 2020 00:56 #164762 by TexasCNC
What do we need to do?
20 Apr 2020 01:01 #164764 by phillc54
I don't know, you didn't answer the last question...
When the torch is home does the DRO read 0.000 and is it 2" above the slats?
When you do a continuous jog down until it stops does the DRO read -0.025 and does the torch end up just below the slats?
20 Apr 2020 01:05 #164766 by TexasCNC
Yes the torch is right on the slats.
20 Apr 2020 01:06 #164767 by phillc54
Were the DRO readings and positions as I asked?
20 Apr 2020 01:06 #164768 by TexasCNC
Ok I homed the machine and hit the touch off then I jogged the machine down to where it stops and the dro reading is -2.0510 and it’s right on the slats
Time to create page: 0.149 seconds
