scurve trajectory planner
1 year 8 months ago - 1 year 8 months ago #321985 by Grotius
Replied by Grotius on topic scurve trajectory planner
Hi Arciera,
I installed both off them in a hurry. I think this one :sudo apt-get install libdogleg2
apt-cache search libdogleg -> gives both :  libdogleg-dev  & libdogleg-dev
Ok,
I am a little further.
There is added a test : single_clothoid_fit();
This is a test, given a clothoid start point, end point.
It is a single clothoid, so no clothoid compound.
Last edit: 1 year 8 months ago by Grotius.
1 year 8 months ago - 1 year 8 months ago #321990 by Aciera
Replied by Aciera on topic scurve trajectory planner
I have those installed but still complains about missing 'cholmod.h':
Last edit: 1 year 8 months ago by Aciera.
1 year 8 months ago #321991 by Aciera
strange thing is that I seem to able to build 'libdogleg' git repo you linked above which also includes 'chmod.h'. Had to install 'mrbuild' though.
1 year 8 months ago - 1 year 8 months ago #322006 by Grotius
Hi Arciera,
Mr build? Huh.  Wich dep is that?
I am able to let the single clothoid finish at target position ~ 50% off the cases.
using example : single_clothoid_fit();
Dogleg fails to find solution very often. Tarpos in the range x20 is ok. x200 is failing all the time.
The good news is, it works partially.
The bad new is, is fails a lot.
Here it does the job ok:
// Start point. double xs = 0.0; double ys = 0.0; double zs = 0.0; // Target point. double xe = 11.00; double ye = 5.00; double ze = 2.2; // Guess. double s1 = 0.001; double gamma10 = 0.0001; // Z double gamma20 = 0.0001; // Xy. double degrees_xy_start = 0.0; double degrees_z_start = -20.0;
So now what to do?
Maybe try another library?
interpolation endpoint result : endpoint x: 11.000000 y: 5.000000 z: 2.000000
1 year 8 months ago #322011 by Grotius
I have tried another solver: "libgsl".     ( sudo apt-get install libgsl-dev )   Using the GPU. ..
This runs way better then libdogleg. Was a luckie shot.
In this solver bigger distances are ok.
Input :
    // Start point.     double xs = 0.0;     double ys = 0.0;     double zs = 0.0;     // Target point.     double xe = 520.05;     double ye = 266.50;     double ze = 125.50;     // Guess.     double s1 = 0.00;     double gamma10 = 0.000; // Z     double gamma20 = 0.000; // Xy.
interpolated endpoint result : x: 520.049999 y: 266.500001 z: 125.500000
Converged after 370 iterations wtf?
Now i get more convinced finally.
The following user(s) said Thank You: akb1212
1 year 8 months ago - 1 year 8 months ago #322013 by Aciera
Moved to another PC, installed 'libdogleg-dev' and I seem to get a little further but not much:
Anyway, I'm afraid there is not much I can think of to help as I'm really starting a zero with these dogleg solvers.
Time to create page: 0.138 seconds
