scurve trajectory planner
1 year 8 months ago - 1 year 8 months ago #322016 by Grotius
Replied by Grotius on topic scurve trajectory planner
Hi Arciera,
use libgsl example. Remove all libdogleg related files and deps.
Last edit: 1 year 8 months ago by Grotius.
1 year 8 months ago #322032 by Aciera
Replied by Aciera on topic scurve trajectory planner
yes that looks much better and compiles for me too.
1 year 8 months ago #322047 by Grotius
@Arciera,
Today i started coding the clothoid compound fit using the gsl solver. It worked right away.
I think because yesterday we did it succesfully for just one clothoid.
This is really a milestone for us !!!
What we see here is a 3d clothoid spline, build from 4 individual clothoids, given start, end posture.
Given the abstract :
"Space corner smoothing of CNC machine tools through developing 3D general clothoid"
by Qun-Bao Xiao, Min Wan, Yang Liu, Xue-Bin Qin, and Wei-Hong Zhang.
Published in Robotics and Computer Integrated Manufacturing, Volume 64, 2020.
However if you look closely at the individual clothoid curve transitions there is a tiny change in curvature.
Somewhere in the code is a buggybug.    and or alien obstruction.
I think in eq45 where the constrains of the joints are calculated must be something signed to "-" ?
// Start point. double xs = 0.0; double ys = 0.0; double zs = 0.0; // Target point. double xe = 520.05; double ye = 266.50; double ze = 125.50; // Start angles, end angles. double degrees_xy_start = 45.0; double degrees_xy_end = 0.0; double degrees_z_start = 0.0; double degrees_z_end = -45.0;
Converged after 315 iterations Solution found: gamma10 = 0.000000, gamma20 = -0.000000, s1 = 198.587624 endpoint x: 520.050004 y: 266.500006 z: 125.499999
The following user(s) said Thank You: akb1212
1 year 8 months ago #322050 by Aciera
Indeed! Congratulations.
Is eq 45 in the loop yet?
1 year 8 months ago #322051 by Aciera
I can't quite tell from your repo so you may already have but just in case:
Remember that we need to run eq 45 with the gamma11, gamma21 and s1 values found with dogleg. With the 6 resulting gamma values it should then satisfy G1, G2 and G3 continuity.
The following user(s) said Thank You: akb1212, Grotius
1 year 8 months ago #322053 by Aciera
I don't think these gamma values look right:
yi1: 0.000000 yi2: -0.000001 yi3: 0.000001 yi4: -0.000000 yi1: -0.000000 yi2: -0.000000 yi3: 0.000000 yi4: -0.000000
