scurve trajectory planner
1 year 8 months ago - 1 year 8 months ago #322065 by Aciera
Replied by Aciera on topic scurve trajectory planner
We also might want to call it a fail if max_iterations have been reached:
Solution found after 1000000 iterations: gamma10 = -0.000148, gamma20 = 0.000011, s1 = 66.624893
Strange that it thinks it has succeeded when the residual is still way off (looks like its happy to have found a local minimum or something):
Last edit: 1 year 8 months ago by Aciera.
1 year 8 months ago #322070 by Aciera
Is there a particular reason for using 'Multidimensional Minimization' instead of 'Nonlinear Least-Squares Fitting' which would contain the dogleg method?
// Set up the Nelder-Mead solver
const gsl_multimin_fminimizer_type *T = gsl_multimin_fminimizer_nmsimplex2;
gsl_multimin_fminimizer *s = gsl_multimin_fminimizer_alloc(T, 3);
1 year 8 months ago #322071 by Aciera
reading this might explain why it is returning a local minimum:
www.gnu.org/software/gsl/doc/html/multimin.html
So in my opinion we are using the wrong solver.
The following user(s) said Thank You: akb1212, Grotius
1 year 8 months ago #322073 by Aciera
I'm way out of my depth here but this may help:
www.gnu.org/software/gsl/doc/html/nls.ht...east-squares-example
1 year 8 months ago #322075 by Grotius
Replied by Grotius on topic scurve trajectory planner
Hi Arciera,
Haha yes indeed we now use : Nelder-Mead simplex method
For now this solver prooved our codebase works ok.
Maybe we can switch solvers with a flag.
Then we can also measure different solvers performance time and choose the best one.
We will add a new dogleg solver soon, as libdogleg was kind of problematic. Github repository
also say's better to use seres solver.
The gauss now works without junction flaws, error solved in eq14_gauss.
It was kind off trickie error. It needed the theta, kappa, sharpness at the given distance.
This in combination with the gauss method, is tricky.
Result:
The drift vs gauss function in the example without fit method:
github updated
The following user(s) said Thank You: akb1212, Aciera
1 year 8 months ago #322076 by Aciera
Why not try the dogleg solver in the GSL library?
Playing around with one of the examples linked above, it looks like we could possibly run 'levenberg-marquard', 'dogleg' and 'double dogleg' and '2D subspace' methods with our function and the Jacobian:
/* define function to be minimized */ fdf.f = func_f; fdf.df = func_df; //fdf.fvv = func_fvv; fdf.n = n; fdf.p = p; fdf.params = &params; /* starting point */ gsl_vector_set(x, 0, 6.0); gsl_vector_set(x, 1, 14.5); fprintf(stderr, "%-25s %-6s %-5s %-5s %-13s %-12s %-13s %-15s\n", "Method", "NITER", "NFEV", "NJEV", "Initial Cost", "Final cost", "Final cond(J)", "Final x"); fdf_params.trs = gsl_multifit_nlinear_trs_lm; solve_system(x, &fdf, &fdf_params); //fdf_params.trs = gsl_multifit_nlinear_trs_lmaccel; //solve_system(x, &fdf, &fdf_params); fdf_params.trs = gsl_multifit_nlinear_trs_dogleg; solve_system(x, &fdf, &fdf_params); fdf_params.trs = gsl_multifit_nlinear_trs_ddogleg; solve_system(x, &fdf, &fdf_params); fdf_params.trs = gsl_multifit_nlinear_trs_subspace2D; solve_system(x, &fdf, &fdf_params); gsl_vector_free(f); gsl_vector_free(x); return 0;
