A Widescreen Blender-Style Interface
8 years 3 months ago #113650 by tommylight
Replied by tommylight on topic A Widescreen Blender-Style Interface
Lcvette wrote: Looks awesome KCJ!
I do concur!
The following user(s) said Thank You: KCJ
8 years 3 months ago - 8 years 3 months ago #113654 by BrendaEM
Replied by BrendaEM on topic A Widescreen Blender-Style Interface
Tool by Lcvette.
Last edit: 8 years 3 months ago by BrendaEM.
8 years 3 months ago - 8 years 3 months ago #113655 by BrendaEM
Lcvette, yes, I think it would be handy to sort them by machine Mill, Lathe, Torch?, then which type of tool. The [strike]idea[/strike] hope is that the user, having set up their machine will have a choice of tools they can flip through and/or include their own, or better yet, use the same image for more than one tool.
For the mill, perhaps the images should center on the bit itself, as there are several different collect and holding methods. One of my other mantras is: make one, use mostly.
The included LinuxCNC ones might have lower image numbers, and the user ones may use higher numbers.
Output size does matter a little for you, because you want to make your images large enough to endure the future. 2048 x 2048 pixels or dots would be a good size for this version, and the next. I can resize them. The finished display size is only 348 x 348 pixels, which is not a lot of dots for detail, but, I would like the user to be able to use enough images--without crashing their machine. Jpeg images may have a small file size, but, but as soon as they are loaded, they will take up more memory, and there may may be a lot of them.
In the end, transparent .png's may be a good source format, but it would be better for the program to deal something that does not have an extra 8-bit channel 32-bit vs 24-bit.
I suppose the tools can have shadows, though reflection may slow the user's eye. A sample image with some leader arrows would be cool. The drawings look excellent!
8 years 3 months ago #113676 by Lcvette
Replied by Lcvette on topic A Widescreen Blender-Style Interface
ok, I saved it with a white background and as a .png file direct inside the program, let me know if this is better? I can also save it as other formats, i made an image of the available formats below. please remember im very graphics and programming illiterate so i can help but only so far as instructed..lol
8 years 3 months ago - 8 years 3 months ago #113678 by Lcvette
I can remove shadows, when you say reflection do you mean the shiny tool finishes? or the reflective background? I have removed the reflective background and shadowed backgrounds for clarity purposes to simplify. and I can deshine the tools and make them more dull if you prefer. i kinda like the shiny but thats just me and I know everyone has their own preference on finish. just let me know and I am happy to make the changes!
also, if you prefer to not have the whole holder, I can just have the holder snout to show the tool stickout if preferred, may make it BIGGER in the window? just let me know!
Last edit: 8 years 3 months ago by Lcvette.
8 years 3 months ago - 8 years 3 months ago #113681 by KCJ
Replied by KCJ on topic A Widescreen Blender-Style Interface
Lcvette, those tools look absolutely awesome! Very nice modeling.
What version of SW are you using? I have 16-17 and 17-18. If you are willing to share the original models then others could build on them and hopefully a pretty good library could be built up reasonably quickly. Even though they are binary I have had pretty good luck keeping SW models on github.
I think ideally the source 2d drawings should be vectors. With vectors we can programmatically and dynamically change text in the image, for example tool dimensions! To make this possible all one would have to do is set the ID of the item in the SVG to the ID of the tool-table value it should display. This would make it pretty easy for people to make their own quick-n-dirty sketches in Inkscape and have them update with the tool table info, or use something as nice as Chris's models. Another advantage of using vectors is that all the tools could be held in different layers of the same file. Until we get a database based tooltable, the image to display could be specified in the comment section of the tooltable.
The result could be something like this, with the dimensions and tool number being dynamic:
As i recall it is a bit of a pain getting vectors from SW, but I have had good success doing it for drawings in technical reports. I think I exported as .tiff, and then converted that to .svg, but it's been years ..
Cheers,
Kurt
Last edit: 8 years 3 months ago by KCJ.
The following user(s) said Thank You: Lcvette
Time to create page: 0.144 seconds
