  • BigDo
  • BigDo
05 Oct 2025 16:54 - 05 Oct 2025 16:55
Results of latency test, list of computers tested for use with LinuxCNC
  Mainboard Asus P5E3 Pro
i first tested it with NVIDIA GForce GT 620  - Unexpected realtime delay on task 0 with period 25000
and now with a old RV370 [Radeon X300] that makes the change.
LinuxCNC pc tests, version 20200930, started 05.10.2025 17:24:07
General info:
ASUSTeK Computer INC.,  System Product Name
Bios version 0504, dated 09/29/2009
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name    : Intel(R) Core(TM)2 Quad CPU    Q8300  @ 2.50GHz
cpu cores    : 4
stepping    : 10
cache size    : 2048 KB
RAM related data:
Maximum Memory Module Size: 2048 MB
Maximum Total Memory Size: 8192 MB
Maximum Capacity: 8 GB
Installed Size: 2048 MB (Double-bank Connection)
Enabled Size: 2048 MB (Double-bank Connection)
GPU related data:
product: RV370 [Radeon X300]
product: RV370 [Radeon X300 SE]
configuration: depth=32 driver=radeon latency=0 resolution=1920,1080
configuration: latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 6.1.0-30-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=2,3"
Cpu idle driver: acpi_idle
Kernel modules data:
Check if pcspkr is loaded: [0;32mNo, which is good![0m
Check if snd modules are loaded: [0;32mNo, which is good![0m
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : PixArt Lenovo USB Optical Mouse
Mice  attached to USB:
Lenovo M-U0025-O Mouse
Keyboards attached to USB:
Fujitsu Siemens Computers Fujitsu Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.9.6
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://www.youtube.com/watch?v=KUXGVfmrEN4&list=RDKUXGVfmrEN4&start_radio=1', WID
Command for latency test is:
su cnc -c  "latency-histogram --nobase  --sbinsize 1000 --nox 2>&1 | tee -a 1759677845.lat &"
Latency testing loop started So 5. Okt 17:24:22 CEST 2025,
should end after So 5. Okt 19:24:22 CEST 2025
[GFX1-]: Couldn't sanitize GL_RENDERER "ATI RV370"
Manual termination requested at 05.10.2025 18:28:50
Swap useage: prerun: 0, running: 0
CPU core temperatures:
[attachment=72110]Bildschirmfoto_2025-10-05_18-34-03.png[/attachment]
  • tlightus
  • tlightus
05 Oct 2025 16:54
Replied by tlightus on topic Potential All-in-One Single Board Computers
After a bit of tweaking I let it run overnite and got this:
  • PCW
  • PCW's Avatar
05 Oct 2025 16:45
Replied by PCW on topic 7i76eu connection issues
Having a field I/O fault is normal until LinuxCNC is running
(if nothing else, there will be a watchdog fault)
What does the command
ip a
return?
  • JackRay
  • JackRay
05 Oct 2025 16:29
Five-Axis RTCP Features: G43.4 and G43.5 Equivalents in LinuxCNC
Category: G&M Codes
Hello,I am very interested in your conversation because I am experiencing the same problems. I use NX Simen and, of course, no LinuxCNC post-processor. So I have to make do with a post-processor that is as close as possible to Fanuc. I have an XYZBC configuration. trt. and I can't get a compliant configuration. I use NX Builder to modify the post-processor, but some, such as G43.4, are not interchangeable.Thank you for your help.
  • heaven
  • heaven
05 Oct 2025 16:25
Recompiling the motmod modules to expose pos-cmd pins
This method uses simple_tp in teleop mode, so it doesn’t synchronize velocity and acceleration. I’m trying to hack it to work in coordinate mode instead. that way, we’ll be able to control LinuxCNC by sending continuous waypoints through HAL pins.
I don’t fully understand how coordinate mode works yet; I just discovered where the calculations take place in the code:
github.com/LinuxCNC/linuxcnc/blob/master...tion/control.c#L1332
  • Hakan
  • Hakan
05 Oct 2025 16:24
Replied by Hakan on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Remove "./" from the line
loadusr -W ./lcec_conf ethercat-conf.xml
  • MatthiasCNC
  • MatthiasCNC
05 Oct 2025 16:12 - 05 Oct 2025 16:19
Replied by MatthiasCNC on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Hello, thank you for your reply.
I think it has helped me a little.
I have rewritten my files and based them on “lcec_configgen.”
I found the problem.
There was a second hal file in which it was hidden.
cia402.hal:16: insmod for lcec failed, returned -1HAL: ERROR: pin 'lcec.0.3.out-01' not found
Now I always get this error.Debug file information:Note: Using POSIX realtime./ethercat.hal:15: execv(./lcec_conf): No such file or directory./ethercat.hal:15: waitpid failed ./lcec_conf lcec_conf./ethercat.hal:15: ./lcec_conf exited without becoming ready2729Stopping realtime threadsUnloading hal componentsNote: Using POSIX realtime
File Name: cia402_2025-10-05.ini
File Size:4 KB
File Name: ethercat-c...0-05.xml
File Size:7 KB
File Name: ethercat.hal
File Size:5 KB
File Name: Log.txt
File Size:2 KB
​​​​​​​What could be the reason for this? Thank you
  • Ayden25
  • Ayden25
05 Oct 2025 15:49
Replied by Ayden25 on topic 7i76eu connection issues
Okay I looked around and saw that the card should run without feild power all together. I have setup a static ip for 10.10.10.1/24
I can ping 10.10.10.10 with success but if I run up addr it still isnt visible. Maybe that's usual. Still on the linux cnc end of things with the updated 10.10.10.10 address for the card I am still getting it as unreachable
  • Ayden25
  • Ayden25
05 Oct 2025 15:18
Alright, I have done some further digging here and realized I'm a jackass lmao. I have the cr11 led on which according to the manual is a feild io falt. I have been reading the wrong ip address I'm not establishing connection to the card I am assuming due to these power issues.
I am powering the card with 12v which according to there documentation is acceptable. I am getting 12v where I should be everything seems to be a go there. The jumper for setting feild i/o as vin input is in the correct position. I have unplugged everything unessisary from the card.
  • rasmus
  • rasmus
05 Oct 2025 14:50
Replied by rasmus on topic Retrofitting HURCO BMC30
Category: Milling Machines
So i have come some way on the BMC30, adjusted the PID:s a lot and the controller on the Servos as well, where certain I had some balls in the ball nuts where cracked but now I think  it was just the PID:s that were set way to stiff.
But know it seems to work quite good for the moment at leas good enough to progress to the ATC.
I have chosen to go with Probe basic as UI and now i struggle to understand the setup.
My machine that has a 24 pocket carousel ATC that is using a pneumatic motor for the tool changer and grey code encoder. The encoder is a 10 bit encoder which I have hooked up all the bits for and now I am trying to figure out how to digitally connect these to the software but I am not certain how to do this.
Anybody that has any experience how to setup such a ATC or can point me in some kind of direction?
  • PCW
  • PCW's Avatar
05 Oct 2025 14:45
Replied by PCW on topic Verkabelung 7i96s
Verkabelung 7i96s
Category: Deutsch
Yes, you can run all field I/O on the 7I76UE at 12 V instead of the more common 24V
Note that this means all field inputs and outputs will run at 12V
Also note that for direct connection to field inputs, proximity sensors must be PNP (sourcing) mode.
NPN sensors require an added pullup resistor.
  • juergen-home
  • juergen-home
05 Oct 2025 14:01 - 05 Oct 2025 14:05
toggle2nist hangs when pressing an other button at the same time
Category: HAL
To illustrate my issue with toggle2nist a bit more I have made a simple hal file.
The hal file makes no other sens as to show problem easily for testing yourself.
1. If I comment in
net net-mist-off  => halui.program.stop
Linux runs as I expect. I can toggle the nist2 in halshow with set and clear.
If mist is switched off, a running program stops. I can start again and so on.
1. If I comment in
net net-mist-on  => halui.program.stop
I can toggle the nist2 in halshow with set and clear only once.
If mist is switched on, a running program stops and the tog2nist.on LED is yellow all the time.
Is this working as expected?
# with this 2 lines each coolant shows a checkbox in the axis ui
# this is normaly part of the machine.hal / here only for test in the SIM-HAL-AXIS
#net coolant-mist      <=  iocontrol.0.coolant-mist
#net coolant-flood     <=  iocontrol.0.coolant-flood
#  start and stop the coolant.
loadrt toggle2nist names=tog2nist0
addf tog2nist0 servo-thread
net net-mist.is-on tog2nist0.is-on <= halui.mist.is-on
net net-mist-off tog2nist0.off  => halui.mist.off
net net-mist-on tog2nist0.on  => halui.mist.on
#net net-mist-off  => halui.program.stop
#net net-mist-on  => halui.program.stop
  • 2tinker
  • 2tinker
05 Oct 2025 11:47 - 05 Oct 2025 11:48
Replied by 2tinker on topic Verkabelung 7i96s
Verkabelung 7i96s
Category: Deutsch
Mal eine ganz dumme Frage...
Wenn ich den IO-Bereich einer 7i76eu mit 12V versorge, darf ich dann auch auf die Input's die ca.12V eines Näherungssensors geben?
  • Hakan
  • Hakan
05 Oct 2025 10:02
Undefined Reference to hal_export_funct Linker Error in LinuxCNC HAL Component
Category: Installing LinuxCNC
Look at the exact line that is executed to link the application.
You should be able to see the exact command with all values that are actually used.
Troubleshoot that line first. If that's wrong, fix the makefile.
  • takgu
  • takgu
Displaying 11641 - 11655 out of 14147 results.
Time to create page: 0.437 seconds
