  • jmp97
  • jmp97
13 Oct 2025 17:11
LinuxCNC installation + 7I96S was created by jmp97
Category: Installing LinuxCNC
Hello. I have installed the latest version of LinuxCNC. Everything seems to be correct, but I cannot see the jogs to control the motors on the interface and the red ‘X’ does nothing. I do not know what to do. I cannot find a way to continue. Thank you.
  • Todd Zuercher
  • Todd Zuercher's Avatar
13 Oct 2025 16:23
Replied by Todd Zuercher on topic AC Servo change to run
You should be able to take the oritinal working ini file and copy it into it's original configuration directory, Saving it with a new name .ini.
Then you without making any changes to the original ini file other than it's name start the configuration. It of course will still be the same but have a new name. Then start making small changes to the ini file. You need to be aware of any variable references to the ini file that the hal file(s) use, and if any of them refer to sections of the ini that you are changing you will need to address them. These are very common in the sections of hal code referring to the joints and axis. There is a good chance you will have to make a copy of the main hal file, rename, and make changes there to go along with your ini changes.
  • bassti
  • bassti
13 Oct 2025 15:58
Replied by bassti on topic ATC - Servo, Analog, Carousel
I was talking about the index from the motorencoder - the inductive sensor is seen only once per rev.
  • TimoK
  • TimoK
13 Oct 2025 14:40
ethercat verbindung zu bosch-rexroth HCS01 über eoe(ethernet over ethercat)
Category: Deutsch
Hi ruediger,
ich versuche gerade auch LinuxCNC mit IndraDrive CS HCS01.1E-W0028-A-03-B-ET-EC-NN-NN-NN-FW Treibern zu verbinden. Dafür verwende ich 2 Linearmotoren und und ein Standardservo. Ich bin erst recht neu in dem ganzen LinuxCnC Thematik. Ich habe bereits der Treiber auf CoE umgestellt, wodurch man diese dann ja nicht mehr im Indradrive finden kann bzw anpingen kann, was man dann ja über EoE beheben kann. Wie schwierig ist es die Treiber im LinuxCnC zum laufen zu bringen und wie bist du vorgegangen?
Gruß Timo
  • PCW
  • PCW's Avatar
13 Oct 2025 14:10
Replied by PCW on topic Erreur de jointure sur fraiseuse CNC
Category: Français
A following error can mean either that the motor does not move when its drive is
given an analog command or possibly that the encoder is no longer working.
I would first check if the encoder is reporting the position correctly. One way
to check is to manually move the X axis with the drive disabled and see if the
DRO position looks correct.
  • Dumitrus
  • Dumitrus's Avatar
13 Oct 2025 13:32 - 13 Oct 2025 13:51
Replied by Dumitrus on topic Stepper motor not moving :)
I removed ENA+ and ENA- connections and also in StepConfig I disabled P14 but still the stepper motor is not moving. Before I used the P14 as Amplifier Enable. Thank you!
  • Arnaud
  • Arnaud's Avatar
13 Oct 2025 13:21
Erreur de jointure sur fraiseuse CNC was created by Arnaud
Category: Français
Bonjour à tous,
J'ai un soucis depuis quelques jours, j'ai une fraiseuse CNC que j'ai retrofité il y a presque 2 ans avec une 6i25 et 7i77.
Celle ci fonctionnait bien jusqu'a aujourd'hui, je vais essayer de décrire mon probleme :
Une erreur jointure 0 qui apparait et coupe la puissance de la machine, avant que la coupure, la machine se stoppe dans l'axe x (ne bouge plus sur X), sur la visu de l'ecran cela bouge encore et d'un coup au bout de quelques secondes la puissance se coupe, j'imagine que le moteur envoi le signal qu'il n'avance plus, a quoi est du cette erreur ?
merci à vous
  • JT
  • JT's Avatar
13 Oct 2025 12:22
Replied by JT on topic FlexGui QDoubleSpinBox HAL_IO
Category: Flex GUI
Found the bug and fixed it, thanks for the report.
JT
  • DerKlotz
  • DerKlotz
13 Oct 2025 12:08
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
THANK YOU VERY MUCH
After a little bit testing and understanding i got the output to work
  • Dumitrus
  • Dumitrus's Avatar
13 Oct 2025 11:55
Stepper motor not moving :) was created by Dumitrus
Hello!
I installed LinuxCNC 2.9.4 on a Dell optiplex 790 PC. I attached a parallel port card to the PCI slot and connected a BOB to it. I attached a single  DM556 driver and a 57BYGH76-8 Nema 23 stepper motor to the X axis following the recommendations for the wiring(attached photos) but the stepper motor is not moving. The motor is powered (it's impossible to turn it by hand when the power supplies are connected). I tried to remove the GPU (Gigabyte NVIDIA GeForce GTX 660) but the stepper is still not working but the OS is running better (before this when I tried to do a Latency Test the OS crashed a several times).
Do you have any suggestions?
Thank you,
Adrian
  • Twitchy88
  • Twitchy88
13 Oct 2025 11:45 - 13 Oct 2025 11:46
Replied by Twitchy88 on topic INI and HAL files
INI and HAL files
Thank you!
I got carousel and looked through it quick.
So my understanding is the machine has a main INI file and HAL file.  The INI file pulls in the HAL files that are to be used.  HAL files connect real world things to hardware, hardware to hardware and anything virtual?
What file actually dictates how the machine moves for carousel, and what language would it be programmed with?  Im an industrial electrician that programs with ladder.
  • Gartenzwerg
  • Gartenzwerg
13 Oct 2025 11:14
Replied by Gartenzwerg on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Danke für die weiteren Infos!
Raspi ist da, der Rest im Zulauf.
Die aktuelle .hal und .ini habe ich mal angehängt.
Die Fräse hatte bei Kauf eine interessante Ansteuerung - ein Windows 95 Laptop der per Windows Software (..hab den Namen nicht mehr im Kopf) über eine serielle Leitung einen i386 "Industriecomputer" in einem kleinen PC-Gehäuse, der dann mit einem DOS Programm über die LPT Schnittstelle die Fräse gesteuert hat. Dazwischen hing dann noch eine kleine Schaltung die mit 2 Potis die Spindel steuert.
Da der Laptop schon meine dxf Dateien nicht lesen konnte, war der Umstieg auf was modernes keine schwere Entscheidung.
Aber alles gut genug dokumentiert, so dass ich relativ problemlos das Verbindungskabel zu LinuxCNC basteln konnte.
Die Spindeldrehzahl wird immer noch von der kleinen Platine mit den 2 Potis gesteuert, ein/ausschalten kann ich aber im LinuxCNC.
Im Idealfall gibt das Netzteil der Spindelsteuerung auch 5V aus, dann brauche ich da zumindest nichts weiteres besorgen.
Habe ich das mit der Konfig der mesa Karten richtig verstanden, dass ich zuerst herausfinden muss wieviele Ein- und Ausgänge ich brauche um dann die passende Konfig auf die Karte zu spielen?
In das generelle Setup der mesa Karte habe ich mich etwas eingelesen, eine Netzwerk-Verbindung sollte ich schaffen (..berühmte letzte Worte..)
  • DerKlotz
  • DerKlotz
13 Oct 2025 10:15
  • Hakan
  • Hakan
13 Oct 2025 10:04
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
Then at least part of the problem is with the Realtek network adapter.
There are two things you can try
1. Install the realtek-dkms drivers and use them instead of the default realtek drivers. Search in the forum for info, many people has done that.
2. Install a PCIe Intel network adapter.
  • shaying526
  • shaying526
13 Oct 2025 09:25 - 13 Oct 2025 09:26
Category: EtherCAT
# lspci
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Displaying 12376 - 12390 out of 13404 results.
Time to create page: 1.209 seconds
