  • xlordofpainx
  • xlordofpainx
02 May 2025 18:26
Replied by xlordofpainx on topic Set static IP address for mesa 7i96s
i get command not found on many of the commands from the text tutorial :(
  • Henk
  • Henk
02 May 2025 18:26
Dual control setup - comms between 2 systems- 7i94 bin file?
Category: Driver Boards
Tomorrow I would like to get the 2 7i94ts to connect using a mesa uart connection. Not sure which firmware to flash. Had a look through the available ones but there isn't an obvious choice.
PCW, is there one available, if so which one?
Henk
  • PCW
  • PCW's Avatar
02 May 2025 18:17
Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Yes, in most cases, mesaflash is not needed as the installed firmware is sufficient.
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar
02 May 2025 18:04
Yes. Current stable version 2.9.4 ISO
I think that mesa and linuxcnc card experts may not have even noticed this. because they either knew where and how to download the updates without a problem. or they skipped this step altogether and did the configuration right away.
  • fery15sty
  • fery15sty
02 May 2025 18:00
Replied by fery15sty on topic Axis Position Logger
Category: AXIS
how to run lcnc_logger? what to add in .ini file?
  • Tntmold
  • Tntmold
02 May 2025 17:59
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
Thanks for the reply but I believe I made all those changes and it made no difference, did I do it wrong or is the problem something else?
  • besriworld
  • besriworld
02 May 2025 17:58
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
The HAW show shows that automatic tuning is not enabled.
What can I test? The problem I have is serious.
  • Aciera
  • Aciera's Avatar
02 May 2025 17:57
popup entry keyboard, no minus and decimal ?
Category: Plasmac
Changed topic title to something a little more verbose.
  • PCW
  • PCW's Avatar
02 May 2025 17:22
Yes, a fairly ancient version of mesaflash (3.4.9)  is included with the
LinuxCNC 2.9.4 ISO, this is supposedly fixed for later releases.
02 May 2025 17:14
  • Hakan
  • Hakan
02 May 2025 16:45
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
Same principle for the statusword. It is named statusword in ethercat-conf.xml not cia-statusword.
You can go over the names of all pins in ethercat-conf to see that they match the name in the hal file.
  • Hakan
  • Hakan
02 May 2025 16:40
Category: Plasmac
Pressed a little longer on the input field and a keypad showed up.
Unexpectedly helpful. But where is the "-" sign? And a "," or "." would be nice needed too.
As far as I can tell it is an integrated keyboard, not the external onboard.
  • xlordofpainx
  • xlordofpainx
02 May 2025 16:27
Replied by xlordofpainx on topic setting up 2 motors on one axis not working
thank you tommy. i will try adding home switches.
  • Roger S
  • Roger S
02 May 2025 15:15
Replied by Roger S on topic Using POSIX realtime
Category: EtherCAT
I need to reopen this topic. The installation went smoothly as described above. After reinstalling the system, I can no longer access the EK1100 (it worked before). I've spent hours searching for the error, but to no avail. What I noticed is that the EtherCAT master always has the status "Link DOWN."
Master0
  Phase: Waiting for device(s)...
  Active: no
  Slaves: 0
  Ethernet devices:
    Main: 80:ee:73:fd:0f:8b (waiting...)
      Link: DOWN
      Tx frames:   0
      Tx bytes:    0
      Rx frames:   0
      Rx bytes:    0
      Tx errors:   0
      Tx frame rate [1/s]:      0      0      0
      Tx rate [KByte/s]:      0.0    0.0    0.0
      Rx frame rate [1/s]:      0      0      0
      Rx rate [KByte/s]:      0.0    0.0    0.0
    Common:
      Tx frames:   0
      Tx bytes:    0
      Rx frames:   0
      Rx bytes:    0
      Lost frames: 0
      Loss rate [1/s]:          0      0      0
      Frame loss [%]:         0.0    0.0    0.0
  Distributed clocks:
    Reference clock:   None
    DC reference time: 0
    Application time:  0
                       2000-01-01 00:00:00.000000000
Could this also be the reason why no master is found when starting a test configuration?
The EK 1100 is powered and the network is connected. Is there something wrong with the network configuration?
  • Farzad
  • Farzad
02 May 2025 15:09 - 02 May 2025 15:13
Beginner Building a CNC - Questions About EtherCAT with Delta A2 and In
Hi Aciera,
Thanks for your reply!
I’m planning to machine cast iron and steels like CK45 or SPK, mainly for mold making.
When it comes to speed, I'm still new to the CNC world — I'm coming from 3D printers world — so I don’t really know what’s considered fast or slow here. But I’m not looking for anything extreme. I thing Something like 45 or 30 mm/s feed rate with 0.3 to 0.5 mm depth per pass would be okay
About the machine setup:
For now, 3 axes will do, but I’d like to add a small 5th axis later — just enough to work on parts like cylinders up to 10 cm radius and 20 cm height.
I want to build the frame from epoxy granite for better rigidity and vibration damping.
Planning to use 25 mm ball screws with 5 mm pitch, and 30 mm linear rails.
The spindle will be a 2.2 kW single-phase induction motor, belt-driven with a VFD.
I’m not going for an automatic tool changer just yet, but it’s definitely on the list for future upgrades.
Oh, and by the way — I recently found a Beckhoff EK1100 for only €95, which I think is a good price
But Unfortunately, motors with ethercat are expensive.
Displaying 16321 - 16335 out of 17148 results.
Time to create page: 2.301 seconds
