  • CFE
  • CFE
27 Aug 2024 04:45
M67 - Issue was created by CFE
M67 - Issue
Hi all,
We have a plasma cutter running QtPlasmaC which behaves somewhat strange. I have attached a video of the plasma cutter doing a contour without the torch turned on. The G-code contains M67 code to reduce the feedrate in the fillets and 100% feedrate on the straight lines. Except, the machine doesn't do that, it is "stuck" on 60% feedrate but suddenly, on the last leg of the contour is runs at 100% feedrate (as it should).
This problem arises randomly on other parts, sometimes it runs at 60% feedrate for half of a long straight line and then all of a sudden it jumps to 100% feedrate, which causes all kinds of issues. But strangely the vast majority of programs do not see this problem.
Has anybody experienced this and is there a solution for it ? Any help is greatly appreciated, it has got us stumped.
Cheers, Peter
  • cakeslob
  • cakeslob
27 Aug 2024 04:31 - 27 Aug 2024 04:32
I've also had no luck with an out of the box STLinkV2. But ColdTurkey has got it to work
pyocd.io/docs/debug_probes.html
"Recent STLink firmware versions will only allow access to STM32 targets. If you are using a target from a silicon vendor other than ST Micro, please use a different debug probe."
If you have a couple of probes you can always flash one with the following firmware.
github.com/scottalford75/Remora-RT1052/tree/main/CMSIS-DAP
ok, so pyocd, CMSIS-DAP firmware, stlink
give me some more notes, im trying to do a docs thing
github.com/cakeslob/Remora-docs/blob/mas.../Ethernet/rt1052.rst
  • CFE
  • CFE
27 Aug 2024 03:56
Replied by CFE on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
Hi Phil,
Thank you. I checked the HAL pins and it looks like the feed reduction pin is connected to the motion pin. I will bring it up in advanced configuration, hopefully that gives us some clarity.
Love your work !
Cheers, Peter
  • phillc54
  • phillc54's Avatar
27 Aug 2024 03:47
Replied by phillc54 on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
Hmmm, I don't understand what is going on. This is what you should see:
Warning: Spoiler!
It may be worth asking in a different forum section as a M67 issue, either Basic Configuration or Advanced Configuration as more folk will probably notice it. I am fairly certain that there is nothing we do which would affect M67 operations. In the meantime I will keep experimenting but not being able to replicate the issue makes it difficult.
  • CFE
  • CFE
27 Aug 2024 03:34
Category: Plasmac
Hi Phil,
Same result on the motion.analog-out-03 pin.
Cheers, Peter
  • phillc54
  • phillc54's Avatar
27 Aug 2024 03:21
Category: Plasmac
The feed-reduction pin should be directly connected to motion.analog-out-03 which should be switched by the M67 E3 Qn g-code commands.
Could you look at motion.analog-out-03 with HAL Meter and see what it does.
They do change state correctly here.
  • CFE
  • CFE
27 Aug 2024 03:12
Category: Plasmac
Hi Phil,
I had a chance to make up a video with HAL Meter and the feed reduction stays at 60% except for the last leg.
Cheers, Peter
  • hmnijp
  • hmnijp
27 Aug 2024 03:06 - 27 Aug 2024 03:12
Replied by hmnijp on topic Is there an easy way to swap axes?
could you use Switchable kinematics ?
for example you can run the millturn configuration - it rotates the Z axis on 90 degrees.
linuxcnc.org/docs/html/motion/switchkins.html
linuxcnc.org/docs/html/man/man9/millturn.9.html
  • cmorley
  • cmorley
27 Aug 2024 02:27 - 27 Aug 2024 02:30
Replied by cmorley on topic QTDragon spindle raise issues
Category: Qtvcp
Could try this change and remove the resume (line 21).
I might need to make a separate resume pin for you for this case.
or add some logic to convert the pause/resume pins to one pin that is true for pause and false for resume.
  22 net pdnt.program.pause   whb.halui.program.pause  QtDragon.external-pause
  • gardenweazel
  • gardenweazel's Avatar
27 Aug 2024 01:36
Replied by gardenweazel on topic QTDragon spindle raise issues
Category: Qtvcp
The halui.pause nad halui.resume are coming from the xhc-whb04b-6.hal file.
I'm not sure how to change those entries.
17 # program related signals
  18 net pdnt.program.is-idle                  whb.halui.program.is-idle             halui.program.is-idle
  19 net pdnt.program.is-paused                whb.halui.program.is-paused           halui.program.is-paused
  20 net pdnt.program-is-running               whb.halui.program.is-running          halui.program.is-running
  21 net pdnt.program.resume                   whb.halui.program.resume              halui.program.resume
  22 net pdnt.program.pause                    whb.halui.program.pause               halui.program.pause
  23 net pdnt.program.run                      whb.halui.program.run                 halui.program.run
  24 net pdnt.program.stop                     whb.halui.program.stop                halui.program.stop
  • dabiaoge6699
  • dabiaoge6699
27 Aug 2024 01:28
Replied by dabiaoge6699 on topic EtherCAT IO设置
EtherCAT IO设置
Category: EtherCAT
谢谢,已经研究明白了
  • spumco
  • spumco
27 Aug 2024 01:12 - 27 Aug 2024 01:25
Replied by spumco on topic Is there an easy way to swap axes?
Mark - you're running a LCNC version pre-joint/axis?
EDIT:
I'm not familiar with pre-joint/axis configs, but one thing I noticed in your HAL files is that it looks like there's a mismatch between the INI and HAL axis numbers.
Vertical:
INI - Y is axis_1
INI - Z is axis_2
HAL - Y is axis_1
HAL - Z is axis_2
Horizontal
INI - Z is axis_1
INI - Y is axis_2
HAL - Z is axis_2
HAL - Y is axis_1
Make sense?
  • phillc54
  • phillc54's Avatar
27 Aug 2024 01:02
Replied by phillc54 on topic Override set_default_blending
Category: Plasmac
It is looking a bit ugly but it seems to do what you need:
Warning: Spoiler!
  • onceloved
  • onceloved's Avatar
27 Aug 2024 00:36
Replied by onceloved on topic EtherCAT IO设置
EtherCAT IO设置
Category: EtherCAT
加我QQ:304394405我远程给你配置
  • cmorley
  • cmorley
26 Aug 2024 23:38
Category: Qtvcp
Do you have halui.pause or resume pin connected somewhere?
from the docs:
If using the Spindle lift option, HALUI can not be used to pause/resume the program. There is a pin, QtDragon.external-pause available to pause/resume from an external source. You must also enable external offsets. In the setting tab check use external offsets
also for qtdragon_hd line 41 should be un commented
Displaying 23161 - 23175 out of 24322 results.
Time to create page: 0.477 seconds
