  • Aciera
  • Aciera's Avatar
26 Aug 2024 16:50
Replied by Aciera on topic durchmesser stimmt nicht
Category: Other User Interfaces
Bitte den ganzen config Ordner zippen und auch den Fehler posten.
  • TheRoslyak
  • TheRoslyak's Avatar
26 Aug 2024 16:22 - 26 Aug 2024 16:32
Replied by TheRoslyak on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
Again, please clarify which drive you ended up taking. Because a closed-loop drive is sold by the seller at a slightly higher price. This is probably due to the low-level firmware. They might have sent you a cheaper version.
www.rtelligentglobal.com/uploads/Rtellig...ies-User-Manual1.pdf
  • OT-CNC
  • OT-CNC
26 Aug 2024 16:01
Replied by OT-CNC on topic MCG Server Controller for 4th axis
Category: Driver Boards
Like jmelson suggested. Look also at docs for BE25A20 or similar from AMC.
I'm guessing your motor is brushed with encoder? This drive should run brushed or brushless. Set the 60 deg phasing switch for brushed and use phase1 and 2 for the motor. (check doc 1st)
You need to confirm the voltage class of the drive and set the current limit dip switches and pot to match your motor. Continuous current and peak.
Some things to look out for is the drive may not be isolated. AMC makes isolated and non isolated versions and I had trouble with noise on my machine. May or may not be an issue for your setup.
Also you will have to tune the drive 1st before hooking it up to linuxcnc. Ideally you'll need a function generator and scope to get it correct. If your motor is a good match, you may get lucky and can tune it close with the dip switches/gain pot and without the need of scope.
Linuxcnc's built in scope will reveal if your drive is not tuned correctly once hooked up to the machine.
  • karlhe
  • karlhe
26 Aug 2024 16:00
Replied by karlhe on topic durchmesser stimmt nicht
hallo,hier die gepackten dateien..viele Grüße  karlhe
  • Aciera
  • Aciera's Avatar
26 Aug 2024 15:51
Homing result in joint on limit switch error
Category: Basic Configuration
In the [JOINT_1] section try changing this:
HOME_OFFSET = -0.10
to this:
HOME_OFFSET =  0.10
  • vibram
  • vibram
26 Aug 2024 15:40 - 26 Aug 2024 15:40
Hello,
I keep getting the following erro: Joint on limit switch error on my lathe Z axis.
I have a signle switch for homing and Z max.
You can find attached my hal and ini files.here is the procedure:I click on homing Axis Z, the machine in moving against the tailstock, where the switch is, the switch is triggered, the machine comeback a little bit and go again against the switch at lower speed.
When the switch is triggered the second time, I get the joint limit error.maybe you can help me to spot the mistake in my INI file?
Thank you very much
  • RotarySMP
  • RotarySMP's Avatar
26 Aug 2024 15:12
Replied by RotarySMP on topic Is there an easy way to swap axes?
Hi Guys,
A bit of serious thread necro here :)
I have my Maho MH400E configured as a vertical mill, and am trying to set up a second INI and HAL with it configured to use the horizontal spindle. For this I need to switch Z and Y, and negate one.
I have something messed up, and spent a couple of evenings trying to trouble shoot it, but cant see the issue. The MH400E HAL and ini work fine, the Horizontal hal and Ini load without error, but cause a Y axis error as son as I push the start button.
I would appreciate if anyone can spot my (probably dumb) mistake. Thanks.
Cheers,
Mark
  • jmelson
  • jmelson
26 Aug 2024 14:50
Replied by jmelson on topic MCG Server Controller for 4th axis
This is a relabeled AMC analog servo amplifier. Probably quite similar to their BX25A20 model. If you look that up, you will see the OBVIOUS similarity. A number of companies sold AMC amps under their own label. This amp takes in analog -10 V to +10 V velocity command signals, and apparently generates a synthetic tach signal from the encoder A and B signals. You need a controller that provides an analog velocity command output. Pico Systems has their PPMC, and Mesa has suitable options, too. This is nothing like a step-direction drive system. An analog velocity command voltage is sent from the control, the servo amp delivers voltage to the proper motor windings to make the motor's speed match in proportion to the command, and the encoder provides position feedback to the control PC.
Jon
  • Aciera
  • Aciera's Avatar
26 Aug 2024 14:45
scarakins axis follow problem in -x and -y zone
You can try compiling the modified 'scarakins.c' using 'halcompile'
sudo halcompile --install <your_path>/scarakins.c
You will need the dev package for halcompile to be available.
sudo apt install linuxcnc-dev
If that does not compile then you will need to build LinuxCNC locally on your computer:
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
  • Aciera
  • Aciera's Avatar
26 Aug 2024 14:35
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
Brown means that it is a hal parameter.
linuxcnc.org/docs/devel/html/hal/halshow.html
  • AndyDM01
  • AndyDM01
26 Aug 2024 14:21 - 27 Aug 2024 11:52
what am I missing ? no movement! was created by AndyDM01
Category: EtherCAT
File Name: mpcnc_plas...8-26.hal
File Size:4 KB
File Name: mpcnc_plas...8-26.xml
File Size:6 KB
File Name: mpcnc_plas...8-26.ini
File Size:5 KB
can't get the axis to move
I don't get any errors
  • PCW
  • PCW's Avatar
26 Aug 2024 14:11
Erros: Unexpected realtime delay + 7i96s error finishing read
Category: Installing LinuxCNC
The m600 uses a Realtek MAC so likely needs the DKMS driver
(the built in Linux one is defective and has random 10 ms or greater hangs)
Take a look at this thread:
forum.linuxcnc.org/27-driver-boards/5323...resh-install?start=0
  • dabiaoge6699
  • dabiaoge6699
26 Aug 2024 14:11
Replied by dabiaoge6699 on topic BT-30 chinese spindle unmount
Category: Milling Machines
我觉得你可以去BiliBili这个网站上看看,有专门讲解这个的
  • besriworld
  • besriworld
26 Aug 2024 14:00
Replied by besriworld on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
Now I saw the device.
My idea was if there will be an error if the speed/acceleration is low.
  • cakeslob
  • cakeslob
26 Aug 2024 13:34 - 26 Aug 2024 13:35
Replied by cakeslob on topic Rpi4 + Mesa 7C80: how to power-off?
I have mine set up using 1 of 2 ways, both are setting in the RPi
1, using the BOOT pin on button, this way you can turn off RPi IO power and still boot from halt using a button
2. Boot using the one IO pin on the header, and boot with button
the 7C8x is still powered at 5v
Displaying 23206 - 23220 out of 24322 results.
Time to create page: 0.580 seconds
