  • acondit
  • acondit
20 Aug 2024 19:55
Replied by acondit on topic Converting a 7i76e config to 7c81/7i76 pair
Now I get an error message on "hm2_7c81.0.7i76.0.0.output-00" that this pin doesn't exist.
it works on the 5i25 board and the 7i76e board.
hm2_5i25.0.7i76.0.0.output-00
hm2_7i76e.0.7i76.0.0.output-00
Any suggestions?
  • RLA
  • RLA
20 Aug 2024 19:39
Replied by RLA on topic Open Configuration tool issue
Category: Configuration Tools
Thanks so much.....finally got it!! ... Now on to a million other things to do.
  • aDm1N
  • aDm1N's Avatar
20 Aug 2024 19:32 - 20 Aug 2024 19:59
Hello
I have an NVEM v5. The stlink is to be delivered tomorrow. I think after everything I've read here, I'll be able to flash the firmware. I am currently building a small lathe into CNC. The spindle drive becomes an AC servo. I still have to see that I get it connected with step/dir, should be feasible. Then the machine gets another MPG, no problem either. But I still have an encoder only with a/b without index. Do I have any connections left for this? Does thread cutting work with it?
Encoder:
de.aliexpress.com/item/1005006363767037....gatewayAdapt=glo2deu
Servo:
de.aliexpress.com/item/1005006659782702....gatewayAdapt=glo2deu
  • PCW
  • PCW's Avatar
20 Aug 2024 18:43
Replied by PCW on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
Category: Driver Boards
There is a bug in MesaCT that does not connect the PID output
to the PWM value pin.  You could try updating to the latest
MesaCT or patch the hal file.
Check out this thread:
forum.linuxcnc.org/49-basic-configuration/53561-7i97t-retrofit
  • PCW
  • PCW's Avatar
20 Aug 2024 18:06
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
OK so it either did not work or you rebooted between
running:
sudo ethtool -C enp0s25 rx-usecs 0
and
sudo ethtool -c enp0s25
  • AndyDM01
  • AndyDM01
20 Aug 2024 18:05
is there some basic list to build the net ?
Category: EtherCAT
I would be very happy if someone could point me to a list of standard net to build stuff from ...
like : net x-home or net x-limit or net torch-on .... stuff like this
OR I don't have to care and i can just create whatever i want?
I want to use most of the IO on my card that has 16 inputs and 16 outputs ...
before i had a usb-bob for mach3 and had 4 inputs and 4 outputs
  • RMJ fabrication
  • RMJ fabrication
  • greg23_78
  • greg23_78
20 Aug 2024 17:41
Replied by greg23_78 on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
I've just tested with a multimeter to find an analog voltage, I put jog speed on high and did a jog (I modified the f error to be able to do it over a long period) and I can't find any voltage.
HAL
File Name: main.hal
File Size:9 KB
File Name: io.hal
File Size:0 KB
INI
File Name: cnc_samua.ini
File Size:3 KB
  • PCW
  • PCW's Avatar
20 Aug 2024 17:25
Replied by PCW on topic Open Configuration tool issue
You update firmware with mesaflash, something like
mesaflash --device 7i96s --addr [mesa_card_ip_addr] --write 7i96s_5abobd.bin --reload
Where [mesa_card_ip_addr]  is 192.168.1.121 or 10.10.10.10 depending on how
you have the 7I96S configured
  • AndyDM01
  • AndyDM01
20 Aug 2024 17:22
Replied by AndyDM01 on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
I saw that the ECR60 and ECR86 share the same software.
but when i enter type="ECR60" or "ECR86" ... I only get error messages
I have to do something else ?
maybe you can share some more info how to get stuff working ?
  • PCW
  • PCW's Avatar
20 Aug 2024 17:06
Driver NUM GEC MK2S
Can you post your hal/ini files?
  • AndyDM01
  • AndyDM01
20 Aug 2024 16:36 - 20 Aug 2024 16:37
Ethercat installation from repositories - how to step by step
Category: EtherCAT
so, the moment of victory was very short. i followed the instructions to the letter, did some corrections when needed and had the first signs of a lcnc-ethercat system coming alive (that was last week) yesterday i wanted to continue but i only got the error screen from linuxcnc telling me that it closed down because some pin doesn't exist ... cia402 pin... wanted to share xml and hal and ini and screenshot but after writing the reply at work with all attachments ... it refused to submit... waited half hour to submit... nothing happened.
so, here's what i have for hardware :
1 rtec IO 1616
1 rtec ECR86 for X
1rtec ECR86 for Y
2 wantai nema 34 steppers (60V-3.5Amp) {these steppers eat almost 6 amps in real-life}
had every sign that the install was complete last week ... saw a lot of lcec pins in the halmeter. actually was able to turn on an output on the IO card. yesterday nothing . no lcec pins, only error screen about this cia402 pin does not exist...
of course i already tried to do everything possible ... reload this, reconfig that, recompile this... for some reason i can't the lcec pins back like i had last week...
  • greg23_78
  • greg23_78
20 Aug 2024 16:34
Driver NUM GEC MK2S
I think it works, the motor turns in 1 direction very slowly.
now my problem is with the analog, i don't get any response from my drivers when i jog.
I've tried reversing the wire but nothing changes.
this is the driver repairer's notes, sorry it's in french.
i think i've connected my 7i97t and my driver correctly.
pin 3 (7I97T) -) pin 19 (driver)
pin 4 (7i97T) -) pin 20 (driver)
  • RLA
  • RLA
20 Aug 2024 16:29
Hi...I am not sure how to update firmware..have it downloaded but not sure how to make available to choose in pncconfig....
Thanks for any help!!
  • PCW
  • PCW's Avatar
20 Aug 2024 16:16
Category: Plasmac
Possibly the executable path is different for root so ethtool is not found unless you use sudo
so maybe try:
to see if IRQ coalescing is disabled
Displaying 23596 - 23610 out of 24349 results.
Time to create page: 0.459 seconds
