  • anfänger
  • anfänger's Avatar
14 Aug 2024 08:33
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
I never managed to keep Hal show on top and didn't have problems.
Once everything runs I might reduce them but while developing it really helps so see all states while running some routines.
Just saw halshow got some nice updates maybe now it keeps on top of probe basic.
  • Limo
  • Limo
14 Aug 2024 08:32
Replied by Limo on topic Remora for RP2040
Remora for RP2040
I have looked through the remora documentation and there are software encoders mentioned with a frequency up to 30kHz. If I get close to that number with a rp2040 I am fine with that. That would result in theoretical encoder resolution to roughly 360ppr with 5k rpm and 30kHz max input frequency. It is just the question if the pi2040 is up to the task of handling these things
  • arijitdutta
  • arijitdutta
14 Aug 2024 05:44 - 14 Aug 2024 05:45
Replied by arijitdutta on topic PnCConf USB Jogging Problem
Category: PnCConf Wizard
Bump.
Any solutions to this?
I have done the add device rule a bunch of times and the wireless controller was detected, but only once the "test device" window got populated with the pins and was responding to the buttons on my controller. Rest of the times I couldn't get it to populate and remained totally blank. Also there is the problem of the Pncconfwiz freezing up and needs restart.
  • Mecanix
  • Mecanix
14 Aug 2024 05:29
Data transfer LinuxCNC to / from custom board - Solved
The correct names joint.xx.count, joint.xx.enable and so forth. Open axis and look at the hal configuration menu.
I personally would never, under no circumstance, ever attempt jogging an un-homed machine-tool (again). Don't ask me why's that, too shy to explain. Great info none the less. Suspected it was something related to the net/name or something.
14 Aug 2024 04:54
Replied by Cant do this anymore bye all on topic Data transfer LinuxCNC to / from custom board - Solved
axis is for jogging an axis, which needs to be homed.
joint is for jogging a joint which doesn't need to be homed.
I think these were some of the major changes from 2.8.xx to 2.9.xx
  • Benb
  • Benb's Avatar
14 Aug 2024 01:50
Replied by Benb on topic 7i77 watch dog catch 22
Category: Driver Boards
From PCW response, if any peripheral card such as 7i77 watchdog HAS bit, the main power supply must be turned off.For implementation since 7i77 does not have a dedicated digital output. One way is to dedicate one preferable two of the 7i77 digital outputs to signal to the main power supply circuit to cut the power to the machine. I will update the schematic when I get chance.Good night, folks
  • PCW
  • PCW's Avatar
14 Aug 2024 01:17
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
OK so ethtool is not installed
sudo apt-get install ethtool
  • Mecanix
  • Mecanix
14 Aug 2024 00:43
This is like a century ago I forgot but was it in the naming of the nets that defines whether you can jog with and/or without homing?
axis.x.jog-enable -vs- axis.joint0.jog-enable
An HAL expert would know...
14 Aug 2024 00:41
Replied by tommylight on topic help with installation
Category: Installing LinuxCNC
What project would you recommend to me to work with 4 to 6 axes?
3 axis!
Start with 3, never ever start with more. That makes the learning process much more enjoyable.
Starting with 6 will almost always end up in defeat and abandoned projects.
14 Aug 2024 00:17
You can jog without homing if add jogging, enable & counts for each joint.
  • RMJ fabrication
  • RMJ fabrication
  • Lcvette
  • Lcvette's Avatar
14 Aug 2024 00:09
Replied by Lcvette on topic probe basic OpenGL Error
Category: QtPyVCP
Your pc is to old, see the requirements at the top of the installation docs, it states the minimum opengl requirements for vtk which is the backplotter used in probe basic and qtpyvcp uis. Can use a graphics card to resolve or a newer pc.
  • Lcvette
  • Lcvette's Avatar
14 Aug 2024 00:06
Category: QtPyVCP
The user tabs are predefined ui's, you should be able to copy and paste to them. The latest version uses the var files for all parameters so they are callable from toolchange remap, same for all probe paramaters so they work if called from gcode etc.
Qtdragon is a good option too, more flavors is a good thing. As for leds for IO, I had that in there at one point but it caused some issues on faster machines and some computers, it slowed the non realtime layer down for some reason so I removed. But all that is available with halshow.
  • Mecanix
  • Mecanix
14 Aug 2024 00:05
Awesome, did you use any opto-couplers/digital isolators, are the nine 16-pin IC's only level-shifters?
Well spotted, correct, those 9 parts are indeed the level shifting. Features digital isolation also, all in one part. I apologize for omitting the schematic for now, once I have it cleaned up and arranged I'll put it up. I'd like to test the board prior though. Regardless, here's a visual below of how it's arranged (ten inputs). Additionally, I'm getting us an ultra-low ripple Isolated 12V Supply done for that board. Plugs right on the main. If we are to isolate this FPGA/Motion Control thing, might as well isolate it true & properly!!
Here's the cool visuals:
  • phillc54
  • phillc54's Avatar
14 Aug 2024 00:01
Category: Plasmac
please let me know where to find instructions on how to start a cut in the middle of the file so at least cut recovery is simpler.
  Run From Line allows starting from almost anywhere in a cut file.
Displaying 23926 - 23940 out of 24447 results.
Time to create page: 0.475 seconds
