27 Jun 2024 14:36
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
I can do that in the morning, it’s just approaching half past midnight Down Under.
What I’ll do I’ll get everything together and put it on my github, schematics for my boards and everything I have on the FPGA, everything is a bit scattered ATM.
You realise if theory that the Mesa 7c81 and 7i90 could run the Spartan6 version of the rio firmware ? Both have SPI interfaces and the 7i90 when it was last in stock was about 50 USD plus delivery.
I’ve also got one the colorlight RV901T boards, spartan6 based I could test as well.
Seriously I’ve been struggling a bit with “chasing the black dog” recently but this has given me something to get my teeth into, once again many many thanks.
  • chrisfischer
  • chrisfischer
27 Jun 2024 14:33
Anyone figured out how to get Trinamic's TMC5160 drivers working with LinuxCNC?
Category: Driver Boards
I'm looking to see if anyone has used the trinamic drivers for stall guard to detect skipped steps during the cut but also to do sensorless homing. I'm surprised I don't see anyone mention this.
  • Lcvette
  • Lcvette's Avatar
27 Jun 2024 14:23
Replied by Lcvette on topic ProbeBasic backplot issue?
Category: QtPyVCP
Hello,
when I start the probe_basic_lathe simulation and change the view, I get an error in the file vtk_backplot.py.
I have installed the latest LCNC 2.9 ISO.
i can verify, taking a look! thanks for the report!
  • meister
  • meister
27 Jun 2024 14:09 - 27 Jun 2024 14:10
if you can send me more info's of this board (cant find any).
then i can complete the board-config (clock pin and crystal-speed).
and if you have the pinout's of your interface-board, i can build a simple config
with some stepper outputs and digital-IO's + SPI interface
27 Jun 2024 13:16
Replied by Cant do this anymore bye all on topic Ubuntu install
Ubuntu install
Category: Installing LinuxCNC
You can download the latest Linucnc image, write to a USB stick and then boot from it and run a Live session without having to install anything.
Later you can install it to the laptop.
Best way to install is from the Linuxcnc image written to a USB stick. When booting from it the opening menu will give you the option of running a Live session or installing Linuxcnc (this will install Debian Bookworm OS all setup for Linuxcnc), you'll find the installer is the Debian Bookworm installer. After the installation has run its course you'll have brand new installation of Debian Bookworm with the required kernel & Linuxcnc ready to go.
Whilst you can use one of the install ISO from Debian and do a plain vanilla install, then install Linuxcnc it's not the easiest route compared to the above mentioned method.
But. Here comes the advanced portion
Now if you are have some free space on the Ubuntu partition, say at least 16GB and can shrink the partition with gparted you can install Linuxcnc along side Ubuntu. To begin with I wouldn't install Debian from a Debian disk, I'd install it from the usb stick you have written the Linuxcnc image to..
The easiest way to shrink a partition is to use www.system-rescue.org/
Boot after you have written the image to s USB stick, type startx to start the gui, then run gparted to shrink the Ubuntu partition if there is the room. GParted is pretty intuitive and I've never had a failure, but it may be best to backup at least your home directory first if there is anything "mission critical".
Tho as has been said before Laptops aren't the best, not really recommended actually, for machine control. But to get an idea of how it works and even testing gcode via one of the simulation configs it will be fine.
  • meister
  • meister
27 Jun 2024 13:09
you are right, i see, but no panic :)
github.com/multigcs/riocore/blob/main/ri...boards/Spartan6.json
github.com/multigcs/riocore/blob/main/ri...an6/config-test.json
#:/usr/src/riocore$ PYTHONPATH=. python3 bin/rio-generator riocore/configs/Spartan6/config-test.json
loading: riocore/configs/Spartan6/config-test.json
loading board setup: Spartan6
writing gateware to: Output/Spartan6/Gateware
!!! gateware changed: needs to flash |||
loading toolchain ise
writing linuxcnc files to: Output/Spartan6/LinuxCNC
#:/usr/src/riocore/Output/Spartan6/Gateware$ clear ; make clean all
rm -rf rio.ngc rio.ngd rio.ncd parout.ncd rio.bit
cat debouncer.v toggle.v pwmmod.v rio.v > rio-modules.v
echo 'run -ifn rio-modules.v -ifmt Verilog -ofn rio.ngc -top rio -p xc6slx9-3tqg144 -opt_mode Speed -opt_level 1' | xst
Release 14.7 - xst P.20131013 (lin64)
Copyright (c) 1995-2013 Xilinx, Inc.  All rights reserved.
TABLE OF CONTENTS
  1) Synthesis Options Summary
  2) HDL Parsing
  3) HDL Elaboration
  4) HDL Synthesis
       4.1) HDL Synthesis Report
  5) Advanced HDL Synthesis
       5.1) Advanced HDL Synthesis Report
  6) Low Level Synthesis
  7) Partition Report
  8) Design Summary
       8.1) Primitive and Black Box Usage
       8.2) Device utilization summary
       8.3) Partition Resource Summary
       8.4) Timing Report
            8.4.1) Clock Information
            8.4.2) Asynchronous Control Signals Information
            8.4.3) Timing Summary
            8.4.4) Timing Details
            8.4.5) Cross Clock Domains Report
*                      Synthesis Options Summary                        *
---- Source Parameters
Input File Name                    : "rio-modules.v"
Input Format                       : Verilog
---- Target Parameters
Output File Name                   : "rio.ngc"
Target Device                      : xc6slx9-3tqg144
---- Source Options
Top Module Name                    : rio
---- General Options
Optimization Goal                  : Speed
Optimization Effort                : 1
*                          HDL Parsing                                  *
Analyzing Verilog file "rio-modules.v" into library work
Parsing module <debouncer>.
Parsing module <toggle>.
Parsing module <pwmmod>.
Parsing module <rio>.
*                            HDL Elaboration                            *
Elaborating module <rio>.
WARNING:HDLCompiler:872 - "rio-modules.v" Line 94: Using initial value of ESTOP since it is never assigned
WARNING:HDLCompiler:1127 - "rio-modules.v" Line 98: Assignment to ERROR ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "rio-modules.v" Line 121: Assignment to tx_data ignored, since the identifier is never used
WARNING:HDLCompiler:634 - "rio-modules.v" Line 103: Net <rx_data[7]> does not have a driver.
*                           HDL Synthesis                               *
Synthesizing Unit <rio>.
    Related source file is "/usr/src/riocore/Output/Spartan6/Gateware/rio-modules.v".
        BUFFER_SIZE = 16'b0000000000101000
WARNING:Xst:647 - Input <sysclk_in> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:653 - Signal <rx_data<7>> is used but never assigned. This sourceless signal will be automatically connected to value GND.
    Summary:
    no macro.
Unit <rio> synthesized.
Found no macro
*                       Advanced HDL Synthesis                          *
Found no macro
*                         Low Level Synthesis                           *
Optimizing unit <rio> ...
Mapping all equations...
Building and optimizing final netlist ...
Found area constraint ratio of 100 (+ 0) on block rio, actual ratio is 0.
Final Macro Processing ...
Final Register Report
Found no macro
*                           Partition Report                            *
Partition Implementation Status
  No Partitions were found in this design.
*                            Design Summary                             *
Top Level Output File Name         : rio.ngc
Primitive and Black Box Usage:
# BELS                             : 1
#      GND                         : 1
# IO Buffers                       : 1
#      OBUF                        : 1
Device utilization summary:
Selected Device : 6slx9tqg144-3
Slice Logic Utilization:
Slice Logic Distribution:
 Number of LUT Flip Flop pairs used:      0
   Number with an unused Flip Flop:       0  out of      0
   Number with an unused LUT:             0  out of      0
   Number of fully used LUT-FF pairs:     0  out of      0
   Number of unique control sets:         0
IO Utilization:
 Number of IOs:                           2
 Number of bonded IOBs:                   1  out of    102     0%
Specific Feature Utilization:
Partition Resource Summary:
Timing Report
NOTE: THESE TIMING NUMBERS ARE ONLY A SYNTHESIS ESTIMATE.
      FOR ACCURATE TIMING INFORMATION PLEASE REFER TO THE TRACE REPORT
      GENERATED AFTER PLACE-and-ROUTE.
Clock Information:
No clock signals found in this design
Asynchronous Control Signals Information:
No asynchronous control signals found in this design
Timing Summary:
Speed Grade: -3
   Minimum period: No path found
   Minimum input arrival time before clock: No path found
   Maximum output required time after clock: No path found
   Maximum combinational path delay: No path found
Timing Details:
All values displayed in nanoseconds (ns)
Cross Clock Domains Report:
Total REAL time to Xst completion: 4.00 secs
Total CPU time to Xst completion: 3.96 secs
Total memory usage is 361140 kilobytes
Number of errors   :    0 (   0 filtered)
Number of warnings :    6 (   0 filtered)
Number of infos    :    0 (   0 filtered)
ngdbuild -p xc6slx9-3tqg144 -uc pins.ucf rio.ngc
Release 14.7 - ngdbuild P.20131013 (lin64)
Command Line: /data/opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64/unwrapped/ngdbuild -p
Reading NGO file "/usr/src/riocore/Output/Spartan6/Gateware/rio.ngc" ...
Gathering constraint information from source properties...
Done.
Annotating constraints to design from ucf file "pins.ucf" ...
Resolving constraint associations...
Checking Constraint Associations...
Done...
Checking expanded design ...
NGDBUILD Design Results Summary:
  Number of errors:     0
  Number of warnings:   0
Writing NGD file "rio.ngd" ...
Total REAL time to NGDBUILD completion:  2 sec
Total CPU time to NGDBUILD completion:   2 sec
Writing NGDBUILD log file "rio.bld"...
NGDBUILD done.
map -detail -pr b rio.ngd
Release 14.7 - Map P.20131013 (lin64)
Using target part "6slx9tqg144-3".
Mapping design into LUTs...
Writing file rio.ngm...
Running directed packing...
Running delay-based LUT packing...
Updating timing models...
INFO:Map:215 - The Interim Design Summary has been generated in the MAP Report
   (.mrp).
Running timing-driven placement...
Total REAL time at the beginning of Placer: 3 secs
Total CPU  time at the beginning of Placer: 3 secs
Phase 1.1  Initial Placement Analysis
Phase 1.1  Initial Placement Analysis (Checksum:1f2fb3a9) REAL time: 3 secs
Phase 2.7  Design Feasibility Check
Phase 2.7  Design Feasibility Check (Checksum:1f2fb3a9) REAL time: 3 secs
Phase 3.31  Local Placement Optimization
Phase 3.31  Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 3 secs
Phase 4.2  Initial Placement for Architecture Specific Features
(Checksum:1f2fb3a9) REAL time: 4 secs
Phase 5.36  Local Placement Optimization
Phase 5.36  Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 6.30  Global Clock Region Assignment
Phase 6.30  Global Clock Region Assignment (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 7.3  Local Placement Optimization
Phase 7.3  Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 8.5  Local Placement Optimization
Phase 8.5  Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 9.8  Global Placement
Phase 9.8  Global Placement (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 10.5  Local Placement Optimization
Phase 10.5  Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 11.18  Placement Optimization
Phase 11.18  Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 12.5  Local Placement Optimization
Phase 12.5  Local Placement Optimization (Checksum:1f2fb3a9) REAL time: 4 secs
Phase 13.34  Placement Validation
Phase 13.34  Placement Validation (Checksum:1f2fb3a9) REAL time: 4 secs
Total REAL time to Placer completion: 4 secs
Total CPU  time to Placer completion: 3 secs
Running post-placement packing...
Writing output files...
Design Summary:
Number of errors:      0
  Number of Slice Registers:                     0 out of  11,440    0%
  Number of Slice LUTs:                          0 out of   5,720    0%
  Number of occupied Slices:                     0 out of   1,430    0%
  Number of MUXCYs used:                         0 out of   2,860    0%
IO Utilization:
  Number of bonded IOBs:                         2 out of     102    1%
    Number of LOCed IOBs:                        2 out of       2  100%
  Number of RAMB16BWERs:                         0 out of      32    0%
  Number of RAMB8BWERs:                          0 out of      64    0%
  Number of BUFIO2/BUFIO2_2CLKs:                 0 out of      32    0%
  Number of BUFIO2FB/BUFIO2FB_2CLKs:             0 out of      32    0%
  Number of BUFG/BUFGMUXs:                       0 out of      16    0%
  Number of DCM/DCM_CLKGENs:                     0 out of       4    0%
  Number of ILOGIC2/ISERDES2s:                   0 out of     200    0%
  Number of IODELAY2/IODRP2/IODRP2_MCBs:         0 out of     200    0%
  Number of OLOGIC2/OSERDES2s:                   0 out of     200    0%
  Number of BSCANs:                              0 out of       4    0%
  Number of BUFHs:                               0 out of     128    0%
  Number of BUFPLLs:                             0 out of       8    0%
  Number of BUFPLL_MCBs:                         0 out of       4    0%
  Number of DSP48A1s:                            0 out of      16    0%
  Number of ICAPs:                               0 out of       1    0%
  Number of MCBs:                                0 out of       2    0%
  Number of PCILOGICSEs:                         0 out of       2    0%
  Number of PLL_ADVs:                            0 out of       2    0%
  Number of PMVs:                                0 out of       1    0%
  Number of STARTUPs:                            0 out of       1    0%
  Number of SUSPEND_SYNCs:                       0 out of       1    0%
Average Fanout of Non-Clock Nets:                0.00
Peak Memory Usage:  650 MB
Total REAL time to MAP completion:  4 secs
Total CPU time to MAP completion:   4 secs
Mapping completed.
See MAP report file "rio.mrp" for details.
par -w rio.ncd parout.ncd rio.pcf
Release 14.7 - par P.20131013 (lin64)
Constraints file: rio.pcf.
Loading device for application Rf_Device from file '6slx9.nph' in environment /data/opt/Xilinx/14.7/ISE_DS/ISE/.
   "rio" is an NCD, version 3.2, device xc6slx9, package tqg144, speed -3
Initializing temperature to 85.000 Celsius. (default - Range: 0.000 to 85.000 Celsius)
Initializing voltage to 1.140 Volts. (default - Range: 1.140 to 1.260 Volts)
INFO:Par:282 - No user timing constraints were detected or you have set the option to ignore timing constraints ("par
   -x"). Place and Route will run in "Performance Evaluation Mode" to automatically improve the performance of all
   internal clocks in this design. Because there are not defined timing requirements, a timing score will not be
   reported in the PAR report in this mode. The PAR timing summary will list the performance achieved for each clock.
   Note: For the fastest runtime, set the effort level to "std".  For best performance, set the effort level to "high".
Device speed data version:  "PRODUCTION 1.23 2013-10-13".
Device Utilization Summary:
IO Utilization:
Overall effort level (-ol):   Standard
Router effort level (-rl):    High
Starting initial Timing Analysis.  REAL time: 2 secs
Finished initial Timing Analysis.  REAL time: 2 secs
WARNING:Par:288 - The signal sysclk_in_IBUF has no load.  PAR will not attempt to route this signal.
Starting Router
Phase  1  : 1 unrouted;      REAL time: 2 secs
Phase  2  : 1 unrouted;      REAL time: 2 secs
Phase  3  : 0 unrouted;      REAL time: 3 secs
Phase  4  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Updating file: parout.ncd with current fully routed design.
Phase  5  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Phase  6  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Phase  7  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Phase  8  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Phase  9  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Phase 10  : 0 unrouted; (Par is working to improve performance)     REAL time: 3 secs
Total REAL time to Router completion: 3 secs
Total CPU time to Router completion: 3 secs
Generating "PAR" statistics.
INFO:Par:459 - The Clock Report is not displayed in the non timing-driven mode.
Timing Score: 0 (Setup: 0, Hold: 0)
Generating Pad Report.
All signals are completely routed.
WARNING:Par:283 - There are 1 loadless signals in this design. This design will cause Bitgen to issue DRC warnings.
Total REAL time to PAR completion: 3 secs
Total CPU time to PAR completion: 3 secs
Peak Memory Usage:  602 MB
Placer: Placement generated during map.
Routing: Completed - No errors found.
Number of error messages: 0
Number of warning messages: 3
Number of info messages: 2
Writing design to file parout.ncd
PAR done!
#bitgen -w -g StartUpClk:CClk -g CRC:Enable parout.ncd rio.bit rio.pcf
bitgen -w -g StartUpClk:jtagclk -g CRC:Enable parout.ncd rio.bit rio.pcf
Release 14.7 - Bitgen P.20131013 (lin64)
Opened constraints file rio.pcf.
Thu Jun 27 15:03:00 2024
Running DRC.
DRC detected 0 errors and 0 warnings.
Creating bit map...
Saving bit stream in "rio.bit".
Bitstream generation is complete.
cp -v hash_new.txt hash_compiled.txt
'hash_new.txt' -> 'hash_compiled.txt'
27 Jun 2024 12:59
Just had a quick look, seems vivado doesn't support Spartan6, so I guess I'll have to load everything into XISE and create ucf (pin file so suit), hopefully shouldn't be too much trouble. But that's tomorrow's task.
  • B.Reilly01
  • B.Reilly01
27 Jun 2024 12:57 - 27 Jun 2024 12:58
Replied by B.Reilly01 on topic G54 ON START UP
G54 ON START UP
Category: AXIS
Do you have G54 in the startup G-Code in the INI file? I also suspect since it's not zero'd yet, the machine is in G53 until it finds home - it doesn't actually know where it is for certain, so G54 isn't relevent yet. I may be reading your post incorrectly...  Could you post your HAL and INI files? G54 goes here:
[RS274NGC]
RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P0.001 G80 G90 G91.1 G92.1 G94 G97 G98
  • B.Reilly01
  • B.Reilly01
27 Jun 2024 12:53
Replied by B.Reilly01 on topic 1990s Millport CNC Vertical Mill Revival
Category: Show Your Stuff
I work on a late-80's Bridgeport EZTrak 286 machine that runs off a floppy. Sometimes the path of least resistance is NOT the retrofit. Congrats on getting an old beast up and chip slinging. Ultimately, isn't that the goal of all of us?
27 Jun 2024 12:19
Now that's interesting, the daughter boards I made were designed to match a DB25 config, ie can be used with std PPort BoBs or Mesa DB25 daughter cards. ATM I've been using the XISE toolchain on Linux. That would also give me the option of Ethernet as well. And use the RPi5.
Here's a link to what I've been doing, has 5v to 3.3v level shifting on board. Really need bufferes to drive anything that requires current but then each pin can be used as an input or output. I took a lot of inspiration from the 7c81 schematics.
forum.linuxcnc.org/show-your-stuff/51142...tan-6-fpga-card-9d60
Thanks, (I think my energy is being renewed!) I'll give this a good look into cos ATM I've only got the option of SPI using my RP-400 or EPP using a PC, and I really was hoping to use the RPi5 via SPI but no driver.
So same hardware, RIO bit files & Ethernet vi the module I have floating around.
  • wellingtoncsouza
  • wellingtoncsouza
27 Jun 2024 12:06
Replied by wellingtoncsouza on topic CNC lathe help
CNC lathe help
Category: Turning
Did you manage to run it?
  • wellingtoncsouza
  • wellingtoncsouza
27 Jun 2024 11:58
Replied by wellingtoncsouza on topic ATC: carousel.comp with Servo drive
any news about this?
  • Donb9261
  • Donb9261's Avatar
27 Jun 2024 11:53
Replied by Donb9261 on topic Position vs Velocity mode
Category: EtherCAT
For the super nerdy, you can read all about it in the ISO standards for Geometric Accuracy by looking up CSN ISO 230-1(Linear Accuracy) and CSN 230-7(Rotary Accuracy). Or simply save the money it costs and wait for me to tell you about the ISO's and how to actually test them. There are other accuracy tests but they are expensive to test and as long as the above is satisfied, you can forego them and still have a solid .025mm total accuracy tolerance as long as your backlash is small. Usually within .075mm/per axis is ideal. Then, a compensation can be be properly made in the control to account for that .075mm/per axis.
  • Donb9261
  • Donb9261's Avatar
27 Jun 2024 11:35
Category: EtherCAT
A possible scenario to locate the mechanics of your 2 motors would be to do the following.
Home the 2 motors with zero offsets. Then measure your square determine the difference. Say 3mm out of square. Choose an appropriate motor to adjust. Place an indicator on that chosen motors frame to read the travel. Release the motor coupling and rotate the ball screw amount required to square the 2 sides +-.150mm or .007~.008" then lock the coupling. Rehome the tandem axis. Then measure and adjust the home offset parameters to complete the setup until your square is within .005~.025mm based on your acceptable tolerance. Then, to ensure that the reversal timing is aligned, once the homes are "squared" move the axis until at least 1 home switch activates. Then move the inactive switch until it makes at the same place. This will eliminate racking at reversal which will over time cause wear and issues that are preventable.
I only use compression type motor couplings. Keyed couplings cannot be used for the above alignment for obvious reasons.
The same would apply for rack and pinion designs as far as the connection type using compression couplings and the procedure listed above.
Remember that .001" out of square on the gantry axis will be exponential as the perpendicular axis(if X is your tandem axis then Y would be the P axis) axis moves from it's reference position. Meaning that over a 10" travel the tool tip will not be .001" out of position or CL of expected location, it will the rise of the triangle out. Here possibly .0025 or so. At 20", even more. Ideally you want the tandem square to be zero in perpendicularity to the P axis. This will also help with concentricity when interpolation of holes is performed.
I may do a post on using ISO standards of machine tool squareness and how the ISO describes the measurement of the parallelism, perpendicularity, and total square of the full cartesian coordinate system for both 3+2 and true 5x machines soon. I think it would be helpful for those unlike me who have 30+ years of nerding on CNC at the highest levels to understand how to get the most out your equipment and save themselves from many many headaches. Give me a week or 2 to put the documents and graphics together. After following the course, you will be able to have a machine that is aligned to ISO standards. It may sound trivial to do so, but doing so saves businesses annually well over $10B in maintenance and production loss costs. As you already know, the parts for CNC are not cheap. And time is money.
I was asked recently why I would just freely give away trade secrets. The answer is clear. The world has slowly stop making things and economic growth is showing that net effect. I am hoping that in sharing my experience, a flower will open up and a new manufacturing business will contribute to the equation driving economic growth in market economies. This benefits every single living being. Any notion otherwise, would be ill advised. Lol. I am a charitable guy, but I am also a strong capitalist.
Kinda nerdy, but I hope that helps.
  • cncproject2024
  • cncproject2024
27 Jun 2024 11:34
Replied by cncproject2024 on topic Ubuntu install
Ubuntu install
Hi, I am really struggling to install LinuxCNC. I am currently running Ubuntu, but this will change to Debian next week. For installing to Ubuntu am I able to download LinuxCNC directly to my laptop, or will I need to download the image to a USB stick and boot it all from there (and is it the same on Debian)? I have been trying to install it directly to my laptop, but am having no success. Any help/advice would be greatly appreciated.
Displaying 25711 - 25725 out of 25749 results.
Time to create page: 0.500 seconds
