  • fabricated
  • fabricated's Avatar
07 Mar 2026 17:23
Looking for new or used Mesa 7i96S board for CNC lathe conversion
Category: Driver Boards
Anyone got info on when 7i96s will be in stock again? Been out of stock for a while at mesanet.com.
Cheers.
  • georgio
  • georgio
07 Mar 2026 17:04
Replied by georgio on topic MESA 7i76eu Firmware
Hi, I am a newbie and I am having the same issue. I tried the bundled package with debian 12 Linuxcnc 2.9.4 iso and installed it. After starting the pncconfig and trying to run the board I got errors with the limit/estop/probe input on TP6. I set those to not used and I could get pulses on the board for movement. If I try to reset those inputs I get the errors again. I am going to try Bendandsends idea of individual install of debian 12.13.0 and Linuxcnc 2.9.8 and see what happens. I do not understand what you mentioned Tommylight when you said already replied to that from Bendandsend. Thanks for all you help I am frustrated now and appreciate all of the help to get this solved
  • Hakan
  • Hakan
07 Mar 2026 16:43
Replied by Hakan on topic XHC WHB04B development?
I sat for some fifteen minutes and tried my best to make the xhc fail. The errorhandling branch.
It works fine. The movement I used to make it fail is now blocked. And for the rest I just works.
I tried things that takes a bit of time like switch screen that used to be a problem.
Not a proof it always works, but I am unable to make it fail.
  • hmnijp
  • hmnijp
07 Mar 2026 16:30 - 07 Mar 2026 16:51
Rover 336 retrofit – horizontal drills and tool offsets in LinuxCNC
In LinuxCNC, the XYZ tool offsets applied via G43 work correctly for the tool.
You can apply them inside M6 by executing G43 inside remap, or separately — it doesn't matter.
The error you are receiving indicates that you have changed the tool orientation (rotated the WCS). The post-processor checks whether your MachineConfig can perform an ABC coordinate system rotation, but you most likely have a standard 3x configuration.
However, to use drilling in planes other than XY (G17) without WCS rotation, you will need to change the post-processor logic in Fusion 360. The standard LinuxCNC-EMC2 post does not allow this. The standard 5x or 3+2 post will not work either as they rotate the coordinate system, which is unnecessary when drilling in a plane other than g17.
There are different ways to implement this:
1) Classic 5x/TCP rotates the coordinate system by controlling the AB axes and TCP activation codes — this is probably too complicated for your machine.
2) Allow tool vector orientation other than Z – this is often used for rotary/angle heads on milling machines.  To do this, you need to modify the postprocessor. See this topic for more information: forums.autodesk.com/t5/hsm-post-processo...n-stock/td-p/8911668
In this case, you do not need to select 'Tool orientation' in Fusion; WCS remains the same as in the setup.
3) The strange but common logic of posts for some furniture machining centers with drilling blocks that you can find looks like this: the g54 offset is defined for the XY machine plane, other offsets are used for side surfaces, and then the CNC recalculates. The control program looks like a cardboard box unfolded onto a plane. I don't think you'll want to use this strange proprietary logic.
I recommend adding mandatory checks:
In the post-processor:
- Check which tool numbers can be used in planes other than the XY plane.
- Check that side tools (T for the ZY plane) are only used for operations on the ZY work plane.
In the CNC:
- check that the XYZ tool offsets for side tools are not equal to 0 (this check can be performed inside M6).
07 Mar 2026 15:11
See if you can find something in Australia, otherwise Europe (Germany and Portugal) or USA.
Portugal uses DHL for all their shipping, so it is fast but will cost a bit more.
Portugal
www.eusurplus.com
Germany
www.welectron.com
USA
www.mesanet.com
www.mesaus.com
07 Mar 2026 15:08
Replied by tommylight on topic Installing Linux CNC on Spinner lathe
Category: Installing LinuxCNC
Yes, but not easy as it does require changing the PC and controllers and IO boards if any.
You can not just install LinuxCNC as the existing PC is probably to old and the controller will most probably not be able to communicate with LinuxCNC.
  • Hakan
  • Hakan
07 Mar 2026 13:16
Replied by Hakan on topic El5101 Config
El5101 Config
Category: EtherCAT
I had to make a component that handles the spindle.0.index-enable signal.
Here is how it is supposed to work from this component linuxcnc.org/docs/html/man/man9/encoder.9.html
The index-enable is I/O pin which isn't supported by EtherCAT, only I or O pins.
github.com/MetalMusings/MyOwnEtherCATDev...musings_encoder.comp
Three lines to connect it in the hal file
github.com/MetalMusings/MyOwnEtherCATDev.../linuxcnc/Turner.hal
For the EL5101 it looks like you need to work with the control and status words instead of the pins I used towards the device.
Hope it isn't too confusing.
  • Hakan
  • Hakan
07 Mar 2026 12:42
The crashes I got was after removing the assert() in setupAsynchTransfer().
When that condition happened, the code waited three seconds and tried to to re-establish
communication. I then got a segv crash from within libusb forum.linuxcnc.org/38-general-linuxcnc-q...ment?start=90#343894
I tried on two different computers and got the same crashes on both. Both debian 12.13, gcc 12.
When i upgraded to debian 13 and gcc 14, there are no more crashes.
I also don't get that debug message from libusb about destroying device.
"Only" changing the gcc compiler version did change things to the better.
My way of get the xhc component to fail is to increase the loops to 100 in hal.h,
start G1X-200F100 in MDI and once that is slowly running, I spin the wheel very fast in the Z direction,
or any direction, but Z is safe.
With default value of loops it takes some tries to get it to fail, and with loops 10 it is almost impossible to get it to fail.
After it fails it usually restarts after a few seconds. Unless the libusb crashes it with segv as it did with gcc 12.
I did try your component yesterday for a short time and it never failed.
  • Hannes
  • Hannes
07 Mar 2026 11:53 - 07 Mar 2026 12:03
Replied by Hannes on topic XHC WHB04B development?
So, it should be solved. Ready for testing.
In the case libusb_submit_transfer() returned an error and you remove the assert, the whole xhc-whb04b-6 module would just do nothing any more. I think that's what you observed.
I tested it by pretending an error happens, so not 100% what you have:
int r;
static int i;
i++;
if(i==30){
  r=-1;
  i=0;
}else{
  r = libusb_submit_transfer(inTransfer);
  • DerKlotz
  • DerKlotz
07 Mar 2026 11:50
Wiring Leadshine DM856 Ena+ and ENA- -> Mesa 7i76e
Category: Milling Machines
Great and thanks for your quick replay. I´ll check
  • Marcos DC
  • Marcos DC's Avatar
07 Mar 2026 11:24
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
Hi @NWE,
Sorry for the late reply — I was a bit busy the last days.
The CiA402 semantic layer is now running in simulation using a HAL drive stub and the core parts are behaving as expected (PDS state machine, controlword ownership, homing supervision, etc.).
The next step is integrating it with real hardware via lcec.
I don't currently have EtherCAT hardware locally, so the plan is to prepare a configuration for your two drives and let you try it when convenient.
I also made the repository public so you can see the current architecture. It is still experimental and not finished yet, but the simulation layer is already working.
Repo:
github.com/MarcosDuqueCesar/linuxcnc-cia402-layer
  • Hannes
  • Hannes
07 Mar 2026 10:58
I found an other issue while trying to test the error handling. Please wait with testing.
  • meister
  • meister
07 Mar 2026 10:14
Hi kostas,
it's possible, there are already generated parts to drive the boards without linuxcnc (from Python/C, over MQTT / JS / ROS).
there is no generator for a microcontroller master, but it's not so hard to use the C client as an template for that.
But if you want to drive motors in Position mode, you need an PID controller inside the microcontroller, not so hard, but you need to write one.
Olli
  • Hannes
  • Hannes
07 Mar 2026 09:54 - 07 Mar 2026 09:55
That WHB component is somewhat a rabbit hole... I tried to do proper error handling, can you test it?
github.com/hdiethelm/linuxcnc-fork/tree/...fix-v2-errorhandling
The proper way of testing would be:
1. Get this version to fail reliably: github.com/hdiethelm/linuxcnc-fork/tree/xhc-whb04b-6-fix-v2
2. Now test this version: github.com/hdiethelm/linuxcnc-fork/tree/...fix-v2-errorhandling
Otherwise, you can never be sure the change made any difference. I now that is often not that easy.
Looking at the code, just removing the assert() probably can result in segfaults in libusb as long as the error is not handled properly.
Note that even with my changes, it is not really how you would do it in a nice way but it should work I think. I am not able to reproduce your issue, so I can just guess and try to do better error handling.
@rodw: Jogging in manual mode is fine. My machine can not jog in teleop mode due to I have two Y axis servo motors. The only thing the WHB component does after my PR is:
- Change to teleop mode if not homed (which fails on my machine but on others, it will do that) -> You can jog before homing any special action
- Change to manual mode if homed AND program is idle -> You can jog after homing without any special action
  • elkhan039
  • elkhan039
07 Mar 2026 09:47
Installing Linux CNC on Spinner lathe was created by elkhan039
Hi everyone,
i have 2006 Spinner TC65MC lathe machine with Sinumerik810D, i cant use this machine becaus i dont know Shopturn and only CAM progrmming with small using . Can i change it to Linux CNC ? If yes how i can do this ?
Displaying 4456 - 4470 out of 14029 results.
Time to create page: 0.547 seconds
