  • PCW
  • PCW's Avatar
07 Feb 2026 15:22 - 07 Feb 2026 15:23
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
You have basic7i97.hal in your .ini file but I think
you wanted main. hal there instead.
That's why you get this error:
CANNOT FIND FILE FOR:basic7i97.hal
  • djdock99
  • djdock99
07 Feb 2026 14:56
Replied by djdock99 on topic Maho mh800w retrofit
Category: Milling Machines
inputs and outputs
  • djdock99
  • djdock99
07 Feb 2026 14:37
Help me please????I have spent 3 days trying to get linuxcnc to power on the Maho with no success.Where i am at. With linuxcnc open and the machine released from estop i can manually latch relay 19k1 by holding on the contactor with a screw driver. When i do this the whole machine powers up and everything is working perfectly. the drives are enabled the linear scales are reading correctly. the door open closed switches are all working correctly but the x and z servos are rotating slowly but smoothly. Then when i update the hal file to electronically latch 19k1 with f2 it will not hold and drops relays straight away.
  • mooser
  • mooser
07 Feb 2026 14:24
Adding Feed Rate (IPM or IPR) to the lathe screen
Category: AXIS
Is there an easy way to get the feed rate to show up on the screen somewhere? (old 2.7x version)
For various reasons (I use some css and when it's working well I'd like to know what combination of rpm and feed it's actually using) I'd like to see the actual feed the z-axis is on my lathe as it cuts whatever given diameter. I've got a add-on panel showing the actual spindle RPM so although not as straight forward there should be a way of showing the actual FEED of whatever axis. Since somewhere in there should be the pulse rate of the stepper I think it might be available or would I need to have an encoder on that motor/ballscrew and calculate out the feed that way ???
Mooser
  • Nkbhvid
  • Nkbhvid
07 Feb 2026 13:54
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
File Name: linuxcncreport.txt
File Size:5 KB
I think my voltage spikes seemed to disappear when I connected the board.So now im ready for the next step in my "simple retrofit machine"
  • only one motor standing on the table waiting for action
    • enable directly to the Rexroth DKC11.3 drive
able to jog x motor in Axis.Unfortunately it didnt workWhen starting the configuration in Linuxcnc i get the message:
Note: Using POSIX realtime2573Stopping realtime threadsUnloading hal componentsNote: Using POSIX realtimeI have tried several things but now it seems that im stuck with this message.Any ideas?I attach report, hal and ini
File Name: homagretrofit.ini
File Size:3 KB
File Name: io.hal
File Size:0 KB
File Name: main.hal
File Size:3 KB
File Size:3 KB
File Name: main.hal
File Size:3 KB
File Name: io.hal
File Size:0 KB
File Size:5 KB
  • Hakan
  • Hakan
07 Feb 2026 13:52
Replied by Hakan on topic XHC WHB04B development?
Ok, I continue with the 10 I have guessed and set.
Seeing that you understand pretty well what is going on, what will you do different with a new driver?
  • DerKlotz
  • DerKlotz
07 Feb 2026 13:37 - 07 Feb 2026 13:51
Probe Basic many error messages at first start -> Newbie
Category: QtPyVCP
That makes sense... today i did a new clean install using Debian 12 Bookworm and Linuxcnc 2.9.0~pre1+git20230208.f1270d6ed7
Still get some errors -> attached picture
kcjengr.github.io/probe_basic/machine_config.html
  • Jugo2
  • Jugo2
07 Feb 2026 12:26
Replied by Jugo2 on topic StepperOnline A6 Servo
Category: EtherCAT
Hey Guys, I’m pretty new here.
 I have a little Problem with configuring my Stepper online A6 Servo Drive. I want to use torque homing but I can not Figure Out wich Parameters I need to set in the Drive.
And I also Think that my Linux CNC Config is wrong. Can maybe someone with more experience then me help me
Liebe Grüße
  • Finngineering
  • Finngineering
07 Feb 2026 12:01
Replied by Finngineering on topic XHC WHB04B development?
I believe I have 10, but can't verify until tomorrow or Monday. I have only tried the one value, which was an educated guess and seemed to work.
The total delay can be loops * timeout, i.e. 60 * 5 ms = 300 ms with the default values. In practice it can become longer because of how the delay is made and how the kernel schedules the task. I would imagine that as long as the delay is more than a few servo cycles, it should work. So probably it would work even with loops set to 1. But I have not tested. Nor do I think it would solve all issues that I experience.
  • Marcos DC
  • Marcos DC's Avatar
07 Feb 2026 11:48 - 07 Feb 2026 11:49
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
By the way, after re-reading your post I realized this was for a medical product line. When I mentioned sheet/panel materials (plastics, laminates, composites, etc.) I meant it in a very generic sense. I’d be really interested to know what kind of materials you were actually processing (e.g. medical-grade films, technical fabrics, multilayer laminates, polymers, etc.), since the combination of a heat press laminator and an ultrasonic cutter suggests a quite specialized process.
  • rodw
  • rodw's Avatar
07 Feb 2026 11:43
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
Well if you think about it, the delta winch drum is really the same as a pinion drive in relation to motor analysis,
So no cutting forces, 2 kg axis weight (actually that's way wrong as the print head has 3 wires supporting it) but it did not make much difference.
I have no real idea here but if you want speed, grab a 48 volt 10 amp power supply (for 3 motors) a 2:1 reduction gearbox and a 60mm diameter winch drum, and you are good for 37,000 m/min!
The limiting factor here was the voltage and this needed 46 volts. if they had a drive good for 72-80 volts like rtelligent you might crack 40 m/min  revised Report attached. Some early runs did not get past 12 m/min until I started tweakimg drums and gearing.
I'll be very interested to see how you go as I thought seriously about making one to but had no experence. Beckhoff have some interesting modi;e to read the cool stuff printers need!
  • amanker
  • amanker
07 Feb 2026 11:00
I was testing new remora-eth from ben-jacobson repository. With the suggestions from you was able to make it work on SPI3, with TMC5160 drivers on remora-spi.
But now I am testing remora-eth from same repo. Can you help me in this?. I have edited ldscript for octopus pro with ethernet. But I can't ping w5500.
  • Muecke
  • Muecke's Avatar
07 Feb 2026 10:06
Umstieg von LinuxCNC + Mesa auf EtherCAT (Leadshine EL8 / Beckhoff) – Erfahrunge
Category: Deutsch
Das ist das aktuelle Bild meiner Erprobungsmaschine.
Mit einer MESA Electronics 7i95.
  • Hakan
  • Hakan
07 Feb 2026 09:19
What number do you use for loops? Is any number "best"?
  • Mr. Mass
  • Mr. Mass's Avatar
07 Feb 2026 09:12
Replied by Mr. Mass on topic asd-a2-e ... lcec driver?
Category: EtherCAT
I also use version 5.5, it seems to be a firmware issue.
Displaying 5746 - 5760 out of 14030 results.
Time to create page: 1.406 seconds
