  • andypugh
  • andypugh's Avatar
13 May 2025 11:58
Replied by andypugh on topic Need help with Linux 2.5 on a CNC lathe
Sorry for the very late reply to what seems like an urgent issue.
It looks like this is not a conventional lathe?
Also, it seems that the config is doing wierd things to handle gantry homing?
eg
# we will need the inverse of the direction signals for our logic, so run it through a not gate
net ydir => not.2.in
net ydir-inv => not.2.out
# we need to determine if the home switch for each motor is tripped while the direction line is
# moving the motor towards the switch
# for both y-axis motors, we will prevent the step signal from passing to the motor
# if the motor is moving towards the switch and the switch is tripped
# so "or" the inverted direction signals and the inverted home switches
net ydir => and2.3.in0
net switches-y1 => and2.3.in1
net doh1 <= and2.3.out
net doh1 => not.3.in
net doh1-inv => not.3.out
net ydir => and2.4.in0
net switches-y2 => and2.4.in1
net doh2 <= and2.4.out
net doh2 => not.4.in
net doh2-inv => not.4.out
# if the step generator is trying to send a step (ystep signal) and either the motor is moving
# away from the switch or the switch is not tripped, then pass the step signal to the motor
net ystep => and2.1.in0
net doh1-inv => and2.1.in1
net ystep1 <= and2.1.out
net ystep => and2.2.in0
net doh2-inv => and2.2.in1
net ystep2 <= and2.2.out
But, if the home-button is greyed out then I suspect that it's nothing to do with all this.
Have you tried clicking the "ignore limits" checkbox?
I wonder if you can home the system through halui to bypass the GUI button (I wouldn't expect so...)
Open a terminal window and
halcmd setp halui.home-all 1
halcmd setp halui.home-all 0
and see if anything happens.
You could also try setting "NO_FORCE_HOMING" in the INI file so that you can run the system without homing it, as a workaround. (manually position all axes at home first...)
linuxcnc.org/docs/stable/html/config/ini...tml#sub:ini:sec:traj
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • stenly
  • stenly
13 May 2025 11:33
Replied by stenly on topic Deckel-Maho DMU 50T
Deckel-Maho DMU 50T
Category: Milling Machines
Hello, Str8jacket,
would you mind sharing which US based company you ordered the encoder adapters from? I am looking to retrofit a Deckel Maho DMU 50M (very similar to your 50T, but with LS486 encoders instead of LS486C). I too am currently wondering how to convert the signal to TTL properly. It's looking like the only tried and tested solution is the Heidenhain IBV 600, but they are obscenely expensive, I may as well change the entire encoders.
I also found those Aikron adapters and am wondering if they'll do the job. Are they the ones you ended up going with?
Thanks.
  • Todd Zuercher
13 May 2025 11:06
Replied by Todd Zuercher on topic LinuxCNC Dual-Head Gantry Setup Assistance Request
No, the heads were mounted on a fixed spacing in the X direction (15 inches.)
It is a complex configuration with a lot going on, including HMI integration for the onscreen buttons to enable/disable each of the heads. I posted the link for you to try to see what it takes to slave an extra joint to an axis.
I also have posted configs for some two head machines that are set up as XYZW control. These have the ability to be ran using independent Z and W commands. While they still are configured using fixed spacing between the Z and W heads, they do also have the option of programmatically slaving the W head to the Z head so the machine can run on XYZ code with the Z and W performing the same movements. This is accomplished using a few custom M-codes, some g-code subroutines and a bit of hal trickery. (I'll have to try to dig up a link to where it's posted.)
A basic system with XYZUW axis would not be that hard to set up and not need to be very complex and use the ordinary standard Trivkins kinematics. If set up where X and U are simple absolute position commanded from a single fixed origin. However if you wanted the U axis to command the spacing between the Z and W heads, That would require a custom kinematics program, but I don't think it would be a completely unique one. I believe this type of arrangement has been used for some knee mill configurations. (Not sure I've seen example configurations posted though, but there is a good chance there are some out there.)
  • RNJFAB
  • RNJFAB
13 May 2025 10:38 - 13 May 2025 11:00
Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
I'll try and get a video of this and upload it.
www.youtube.com/shorts/b2f-urW5Wb4
So, load file - no worries.
preview opens a long way from 0,0
cuts in location
frames where preview is shown.
Could it be the post processor??
  • Esaber
  • Esaber
13 May 2025 10:23
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
The project started  before qtplasmac came out and I kept the plasmac config I did with Tommy a while back. I would like to get the machine working nicely as is before any software upgrades. If moving to qtplasmac will help with optimizing stuff I can give it a try. Next step is tuning the height control (Z) movement. Right now the Z is moving up and down only when sensing the metal sheet and then when the cut is finished. And if the metal sheet is slightly curved the Z does not account for that and we end up with a welded torch tip !
  • akim14
  • akim14
13 May 2025 10:01
Just a heads-up for anyone wrestling with the XHC-WHB04B-6 like I was: relax, it's easier than it looks! Turns out, it's mostly a copy-paste job. My mistake was overthinking it. Make sure your drivers are good to go, create that xhc-whb04b-6.hal file, and pop HALFILE = xhc-whb04b-6.hal into your INI. Then, grab everything from raw.githubusercontent.com/LinuxCNC/linux...ple-configuration.md and paste it in. Tidy it up by removing what you don't need, and if LinuxCNC complains about a line, just delete it until it's happy. Hopefully, this saves someone else the headache!
  • Aciera
  • Aciera's Avatar
13 May 2025 09:44
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
RE: Toolchange position:
The issue is due to different G7/G8 status for tool changes in the example program. This is solved by forcing 'G8' in the tool change macro.
So change './remap_subs/m6remap.ngc' to this:
o<m6remap>sub
M66 L0 E0
M428
G8
G53 G0 X500 Y300 Z900
G53 G0 B-90
G53 Z500
M66 L0 E0
M6
G53 Z900
G53 X200
o<m6remap>endsub
m2
Note that this macro is really only a rough sketch as it is, there are likely to be other issues.
Also note that this issue points out that the cgode program needs to set 'G7/G8' _after_ the tool change or, for a fancier solution, for the toolchange macro to restore the 'G7/G8'.
  • Aciera
  • Aciera's Avatar
13 May 2025 09:02 - 13 May 2025 09:03
Re: the Z-180 after homing:
Seems your config homes at joint position 200 rather than 0, which is new.
i.e. Z axis travel of 1065mm and home at zero. But after starting and homing z is automatically at -180mm.
Could you attach the ini file? (I notice that you have changed the z-offset to 0)
Re: Toolchange position.
I see this now. I'll need to investigate.
  • Z3rni3
  • Z3rni3
13 May 2025 08:52 - 13 May 2025 08:57
Replied by Z3rni3 on topic hal functions
hal functions
Following this but it seems the same problem has come up again.
Might I be missing a crucial step?
Everything is working as intended, until the encoder come into play...
FYI: Encoders Scale is (1000PPR*4mm/rev)/4=1000
  • rodw
  • rodw's Avatar
13 May 2025 08:48
G-code file loading at G53 instead of G54
Category: Qtvcp
Great! You got it working! I was thinking maybe you had copied files from a CD or something so they could not be written to. But I was in the right area!
  • hermann1976
  • hermann1976's Avatar
13 May 2025 08:42
Replied by hermann1976 on topic LinuxCNC compatible industrial PC
I installed an ASRock N100DC-ITX and am very happy with it. It already includes a processor and has the advantage of running on a laptop power supply.
Recommendation from talla83:
I can confirm the stated latency times.
Regards Hermann
  • meister
  • meister
13 May 2025 08:00
Replied by meister on topic Issues Homing 6 DOF Robot arm
Category: Basic Configuration
i need to set some axis to non Zero values to prevent the kinematics failure,
try to set the 4. and 5. joint to 0.01 and check if the error is gone
  • unknown
  • unknown
13 May 2025 08:00
Replied by unknown on topic LinuxCNC compatible industrial PC
Mostly it's a "bang for buck" issue.
I can argue for & against it.
Displaying 16111 - 16125 out of 16358 results.
Time to create page: 1.679 seconds
