  • PCW
  • PCW's Avatar
07 Mar 2025 21:42
Replied by PCW on topic 7i96s Watchdog Ethernet
Category: Deutsch
Not sure whats going on, possibly a hardware issue on the PC?
Does dmesg show anything?
Reboot,  LinuxCNC untill you get an error and then:
sudo dmesg > log.txt
and post log.txt here
  • red97corvette
  • red97corvette
07 Mar 2025 21:28
Remora - Panucatt Re-Arm was created by red97corvette
Hi!  I have been looking to upgrade from my existing cheap parallel port BOB and while reading the docs on the amazing Remora firmware was surprised to see mention of the Panucatt Re-Arm board as "Under Test" as I just happen to have one of those lying around.  Is there any status update or additional docs available on using Remora with these boards?  I believe I was able to get my board flashed with the LPC1768 firmware from github, at least after boot firmware.bin was renamed to firmware.cur.
What are my next steps?  I have the ethernet widget for the board, but the link light only flashes, it never maintains a solid link.  I have an available RPi 4 and 5 so I believe SPI should be an option, but right now I'm just guessing on the pinout.  Then I will need a step/dir config and again kinda guessing on the pin names.
Any documentation available that I might have missed or am I better off going a different direction for driving my 3 axis CNC mill?
Thanks for any input!
  • JTknives
  • JTknives's Avatar
07 Mar 2025 21:10
updating to QtPlasmac, copying setting from plasmaC?
Category: Plasmac
I'm starting over with a fresh install of the new QtPlasmaC on a new HD. I'm wondering if there is a way to just copy over my config data as its been so long that all these questions in the pncconf are greek now. Here is my old file
# Generated by PNCconf at Sun Jan 10 18:01:51 2021
# Using LinuxCNC version:  2.8
# overwritten when you run PNCconf again
[EMC]
MACHINE = IMPERIAL_PLASMAC
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/jtknives/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i76e.0
[HAL]
HALUI = halui
HALFILE = machine.hal
HALFILE = plasmac.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES =  XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 0.83
MAX_LINEAR_VELOCITY = 8.3300
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 8.3333333
MAX_ACCELERATION = 150.0
MIN_LIMIT = -60.0
MAX_LIMIT = .001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0c
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 8.33333333
STEPGEN_MAXVEL = 10.42
STEPGEN_MAXACCEL = 187.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 1940.17
MIN_LIMIT = -60.0
MAX_LIMIT = .001
HOME_OFFSET = 0.0
[AXIS_Y]
MIN_LIMIT = -26.0
MAX_LIMIT = .001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
MIN_LIMIT = -0.26.0
MAX_LIMIT = .001
HOME_OFFSET = 0.0
[AXIS_Z]
MAX_VELOCITY = 16.666
MAX_ACCELERATION = 300.0
MIN_LIMIT = -.001
MAX_LIMIT = 4.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 6400.0
MIN_LIMIT = -.001
MAX_LIMIT = 4.0
HOME_OFFSET = 0.0
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
  • rodw
  • rodw's Avatar
07 Mar 2025 21:00
Replied by rodw on topic Hurricane Milton
Hurricane Milton
What a fizzer. after days of talking it up, sending us home, cancelling freight services and public transport, Alfred headed north away from us and degenerated into a tropical low in the last hour or so.
Youtube seems to enforce a 12 hour streaming limit so I had to change the URL a few times when it timed out.  Then I found a weather setting so its still up!
www.youtube.com/live/KwGRpF-Cvp8?si=mQuM5AUsBVTC3fVe
Notes on the tech:
My Reolink doorbell camera is managed by a Synology NAS with a bunch of other cameras (10 all up). Synology Surveilance Station allows you to stream to YouTube so it was an interesting learning curve if nothing else. The Reolink is my only wifi camera because it was impossible to get a network cable to it. Instead, I tucked a 24v power supply under the tiles above the door and used the existing wiring to power the camera. There is a chime unit which plugs into a power point inside. (I still have the horrors when I remember running 24 network cables through a 2 story house 12 years ago). I have a PoE switch in the ceiling space for the cameras mounted in the eaves.
The Synology also connects the cameras to Home Assistant running on a Raspberry Pi 4b powered by a PoE hat. That is another story.
I recently retired my first Synology NAS after about 12 years. I had replaced 2 out of 5 x 3 Tb hotswappable drives in it in the last couple of years. I replaced it with another Synology with 2 x 16 Tb mirrored drives as the number of cameras overpowed the old NAS. Sold the old one for $450 AUD!
  • Lehmeier
  • Lehmeier
07 Mar 2025 20:59
Ist Linuxcnc kompatibel mit anderen CNC-Sprachen?
Category: Deutsch
Ich habe habe beruflich mit CNC zu tun und würde gern mal meine Fähigkeiten in Sachen Programmierung ausbauen.
Leider habe ich fast fast nur mit Sinumeric ( Drehen ) und Heidenhain ( Fräsen ) zu tun, da sich diese dort fast als Standard etabliert haben. Pal ist die Sprache die in de rAusbildung gelehrt wird und die auch die Basis für die Sinumeric ist.
Es wäre schön wenn es klappen würde.
Ansonsten ein Dankeschön für deinen Einblick, vielleicht was ja jemand nochmehr dazu zu sagen.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 20:46
Replied by andypugh on topic Lathe spindle index only?
Category: Basic Configuration
There is a whole thread on this subject on CNCzone, here is a description of my solution.
www.cnczone.com/forums/mini-lathe/63621-cnc.html#post509784
But it was a long time ago and all the images have bitrotted...
There are some pics of the machine here, but not the critical ones:
photos.app.goo.gl/nwM9Ze59j3zi5TB77
The basic idea is to have a T2.5 pulley small enough to fit under the cross-slide, and next to that a needle roller bearing running on a plain section of the ballscrew. Then the thrust control is handled much closer to the operator, in the micrometer dial housing, with a pair of angular contact bearings, where there is a lot more diameter to play with.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 20:12
CINCINATTI MILACRON ARROW 500 (BDS4 + VFS5) WITH MESA 7i77 + 6i25 WITH LINUXCNC
Category: Milling Machines
What command and feedback method do the drives and axes require/provide?
You might want to look at the "HD" cards too, such as the 6i24 as those have rather more pins. For example 6i24 + 7i36. The 7i36 can connect one smart-serial board for GPIO, and then you could add a 7i44 if one sserial board isn't enough.
Look at the 7i43 to simplify the control panel wiring too.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 20:03
Advanced Lube pump timing and memory for oil mist spindles
You might want to consider adding this to the "Contributed Components" on wiki.linuxcnc.org
  • andypugh
  • andypugh's Avatar
07 Mar 2025 19:59
Replied by andypugh on topic question of Homing
question of Homing
Category: EtherCAT
LinuxCNC expects the encoder counts to be zeroed at the index. (then LinuxCNC uses the small number of remaining counts that accumulate as the axis comes to a stop to calculate the exact index position).
If your ethercat encoder counters don't do this then you will see the behaviour you describe. And, also, your home position will be wildly inconsistent.
If you have good homing switches you may be able to just not use home-to-index. Alternatively some HAL magic might be used to latch the C phase to look like the edge of a switch (and2 with the actual switch).
Reset on index might be a configurable option in the encoder counter.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 19:53
Replied by andypugh on topic python hal glade
python hal glade
Category: GladeVCP
You may have cut off the most important part of the error chain, the real problem is likely to be near the bottom.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 19:50
Replied by andypugh on topic Devuan, RPi5 & Linuxcnc Image
Category: Installing LinuxCNC
Which libgpiod?
  • royka
  • royka
07 Mar 2025 19:42 - 07 Mar 2025 19:45
Just to let you know, that the SPI connection (generic) also works with the Orange Pi 5 and the TangNano9k.
Great work meister!
By the way I think that supporting Mesa boards would be beneficial for many, since it's much easier to adjust the functions of the pins.
  • ErwinCNC
  • ErwinCNC
07 Mar 2025 19:41 - 07 Mar 2025 19:51
Replied by ErwinCNC on topic 7i96s Watchdog Ethernet
Category: Deutsch
Die Mesa Karte ist direkt über ein Netzwerkkabel mit dem PC verbunden. Das Kabel habe ich schon ausgetauscht - keine Änderung.
Die Spannungsversorgung erfolgt über ein 5V Hutschienen Netzteil 5V 3A
Aktuell ist außer der Stromversorgung nichts an der Mesa Karte angeschlossen.
​​​​​​Den Ping Befehl habe ich jetzt noch mit 10 Minuten ausgeführt. Die Werte sind praktisch identisch zur letzten Messung (1 Minute)
Der Fehler tritt zufällig auf. Manchmal nach wenigen Sekunden manchmal erst nach 20 Minuten.
Unabhängig davon ob das gmoccapy Fenster maximiert, klein oder im Hintergrund ist.
  • PCW
  • PCW's Avatar
07 Mar 2025 19:33
Category: Deutsch
Not sure what's wrong, that's a 31 ms delay!
Displaying 18091 - 18105 out of 18523 results.
Time to create page: 0.840 seconds
