  • RotarySMP
  • RotarySMP's Avatar
01 Aug 2026 15:05
Replied by RotarySMP on topic Lathe macros - Facing bug?
Category: Turning
Thanks. I added the message, which displayed, so that is the .ngc being loaded.
I had just run a facing cut which had a taper. Ran it after adding that msg, and had no taper. I will need to see what the error correlates with.
  • PCW
  • PCW's Avatar
01 Aug 2026 14:15
Replied by PCW on topic 7i80db16 7i85s only one stepgen out
Category: Driver Boards
Ahh that's a pin file error, I'll fix that today or tomorrow.
  • dlv
  • dlv
01 Aug 2026 14:13 - 01 Aug 2026 14:14
Replied by dlv on topic Hole Spotting
Hole Spotting
Category: Fusion 360
Thanks Rod.  Fusion has cut profiles.  The approach would be similar to the layers you mention I think.  Select the holes to be spotted in one cut profile and the rest of the part sans the small holes in another.  Perhaps a bit more "one click" in Sheetcam but it's really no trouble in Fusion.  Then from the two profiles I post two different NC files so I can change my torch amps between spotting and cutting (I have to do that manually, no fancy Hypertherm for me!).
I will look into writing a gcode filter take small holes and replace with the spotting commands I have in my test code.  That's the approach I've been thinking of anyway.  Was wondering if anyone had already done that.  If there are examples out there of gcode filters anyone can point me at I'd appreciate it.  I've got decent C and Python skills.
Tommy I looked at the feature I think you're referring to and from what I read QtPlasmaC will take a gcode command to only run the pierce operations it finds in the file and no cut ops.  I guess I'd use the cut profile approach above with just the holes in it and set the lead in to put the torch in the hole center for the pierce.  Like 2mm holes with a 1mm 90deg lead in.  Then use this:
Insert #<pierce-only> = 1 into your G-code file prior to the initial cut command to switch the mode on for that specific program run
 So yeah that would be ok if I wanted to actually pierce the hole centers.  I like the "center punch" dimples I'm getting with the M3 command test above but this certainly would be a solution to try and I will.  Might work better on thicker steel.  So far I'm just testing on aluminum sheet.
tuxcnc I'll check out dxf2gcode.  I can export a DXF and post process that.  You're not wrong, Fusion is a beast.  But I'm really quite comfortable on the design side and for the most part I like working with it.  That said since I'm learning the CAM side I am definitely open to trying some alternatives especially if they're open source.
Thanks guys!
  • 5280
  • 5280
01 Aug 2026 14:10
Ver 10 NEW install was created by 5280
Ver 10 NEW install
Good Day CnC's
I am a "TOTAL" new bee to Linux and to LinuxCnC trying to get the new Ver. 10 to run with the help of AI and maybe 5-6 hours installing on my  Zorin 18.1 Linux computer.
I managed to get it installed only to get an terminating error on opening the program it says to create a report file which i did but can not find the report and don't know how to send it to someone if i did find it. so I seem to need some help if some one can provide some guidance
here is a cut and paste of the error. it will not be hooked to any machine at this time. Just would like to get the program to run for right now
Tks if anyone would like to tackle this. if not I'll understand.
5280 (ken)
Print file information:
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/ken/linuxcnc-dev/bin
LINUXCNC_TCL_DIR=/home/ken/linuxcnc-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/ken/linuxcnc-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/ken/linuxcnc-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0~pre1
Machine configuration directory is '/home/ken/linuxcnc-dev/configs/by_machine/cooltool'
Machine configuration file is 'Basic540_3axes.ini'
INIFILE=/home/ken/linuxcnc-dev/configs/by_machine/cooltool/Basic540_3axes.ini
VERSION=1.1
PARAMETER_FILE=stepper.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
HALBRIDGE=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Can't execute server program linuxcncsvr
Debug file information:
Stopping realtime threads
Unloading hal components
rtapi_app: exit received while not running
  • Aciera
  • Aciera's Avatar
01 Aug 2026 14:03 - 01 Aug 2026 14:06
Replied by Aciera on topic Lathe macros - Facing bug?
Category: Turning
I don't see anything in 'facing.ngc' that could cause a simultaneous move in X and Z.
Could you put a debug message inside of your 'facing.ngc' and run that macro again. Just to be sure that that is the actual file being executed (You should see a info message popup in the gmoccap gui).
Something like adding '(MSG, Executing facing.ngc)' to the start of the sub:
;Facing
O<facing> sub
  • RotarySMP
01 Aug 2026 13:03
Category: Turning
Hi Andy,
Sorry for the slow response. I dropped the ball on this as I was doing wood working .
This is the facing.ngc file I am using. I have not modified it at all. I just noticed I have both a "lathemacro.ini" and a "lathemacros.ini" (plural) in my machine directory. Could that be the issue?
Cheers,
Mark
  • andypugh
  • andypugh's Avatar
01 Aug 2026 12:40
Replied by andypugh on topic Horizontal Z axis for Qtvcp ui
Category: Qtvcp
Most UIs allow you to adjust the view direction.
linuxcnc.org/docs/html/gui/qtvcp-widgets...idgets:gcodegraphics
Seems to suggest using the _view property in the handler code.
  • andypugh
  • andypugh's Avatar
01 Aug 2026 12:24
Replied by andypugh on topic Looking for STLs for 3 axis vismach model
I have a good model of my lathe, but the mill model is rather lacking.
There are a few milling machine models on Thingiverse / Printables etc.
  • automata
  • automata
01 Aug 2026 12:15 - 01 Aug 2026 12:19
Replied by automata on topic LinuxCNC S-Curve Accelerations
github.com/mika4128/liscio/tree/main
new trajectory/gcode compressor for the future trajectory planner, testers wanted, feed your gcode to it, check the SVG output
Hi grandixximo and mika4128 (Yang Yang),
Curve smoothing is the correct and best way to tackle Jerk that is normal to the motion path. This is reflected in the curve smoothing features from the large CNC controller brands referenced in the Liscio documentation.
I put the liscio library through an AI based analysis for integration into linuxcnc.
This is the analysis it has come up with.
Let me know how we can progress on this topic and the eventual jerk limitation implementation.
-automata
Library facts (verified in source, not the README):
- 6 `.c` files + 1 internal header + 1 public header; MIT licensed, single author (Yang Yang
  `This email address is being protected from spambots. You need JavaScript enabled to view it.` — the same upstream author as the already-vendored `cruckig`).
- Exactly one `calloc` (create) and one `free` (destroy); zero allocation afterward. No printf/assert/
  globals in library paths. Context is ~148 KB (91% of it a 64-slot arc-merge buffer); fitter stack
  worst case ~25–30 KB (bounded recursion, depth 8).
- `liscio_pose_t` is layout-identical to `EmcPose` — nine consecutive doubles x,y,z,a,b,c,u,v,w
  ([emcpos.h:19-23](../src/emc/nml_intf/emcpos.h), liscio.h:44-50). Add a `static_assert(sizeof)` in the
  adapter as cheap insurance.
- Emit is a synchronous callback invoked inside `add_*`/`flush` calls.### Known library defects and gaps (must be addressed before starting integration)| # | Defect | Evidence (liscio clone) |
| L1 | `liscio_reset()` does not clear `arc_buf_n` — arcs buffered before an abort are emitted into the **next program** | src/liscio.c:1437-1444 |
| L2 | No runtime tolerance setter — cfg is copied at `liscio_create`; G64 P/Q changes mid-program have no cheap path | src/liscio.c:108-131, liscio.h:285-309 |
| L3 | XYZ-collinear LINE fast path skips the ABC/UVW linearity gate — interior rotary nonlinearity silently discarded | src/liscio.c:540-561 |
| L4 | No `isnan`/`isfinite` anywhere; tolerance gates are `if (dev > tol)` so **NaN passes** | grep of src/ |
| L5 | F-word changes are absorbed silently (first-F-wins, plus an off-by-one via the flush reseed) | src/liscio.c:669-676, 1302-1311 |
| L6 | `liscio_emit_stop(pos=NULL)` emits zero poses despite header docs claiming last-known-position | src/liscio.c:1402-1407 vs liscio.h:363-367 |
| L7 | `liscio_add_arc` validates nothing (unit normal, radius/center consistency, type field) — caller trust | src/liscio.c:1181-1239 |
| L8 | Corner/discontinuity detection is XYZ-only — pure-rotary reversals never split the window | src/liscio.c:687-709, 736-752 |
| L9 | Struct doc mentions a `turn` field that does not exist (direction+wrap live in signed `arc_angle`) | liscio.h:98-105 |
| L10 | Independent verifier (`test_verify`) and fuzzer are XYZ-only / add_line-only — 9D fidelity is not regression-gated upstream | test/test_verify.c:53-62, test/test_fuzz.c |
L1 and L3 are correctness bugs; L2 is a hard integration blocker; the rest are adapter obligations.
  • Ismacr63
  • Ismacr63
01 Aug 2026 12:07
Bearing replacement advice for PM-25MV mill (spindle and pulley shaft)
Category: Milling Machines
The original bearings are 6209 2RS and 6009 2RS; they don't have "C3" stamped on them, so they are likely CN (standard clearance). They are press-fitted without any additional clamping.
  • andypugh
  • andypugh's Avatar
01 Aug 2026 11:57
You only need C3 if the bearing is an interference fit in the housing and on the shaft.
What are the original bearings? If they are C3 it will say on them.
  • andypugh
  • andypugh's Avatar
01 Aug 2026 11:54
Replied by andypugh on topic Unable to Jog When HAL_ToggleBtn Active
Open a halmeter and see what the mode flags show:
linuxcnc.org/docs/stable/html/gui/halui.html#_mode
mode.is-manual needs to be true for jogging to work, it seems possible that something is changing mode.
Are you keyboard jogging, or using handwheels? It might just be a UI focus problem, with the key presses being "captured" by the button itself.
But check the mode first.
  • andypugh
  • andypugh's Avatar
01 Aug 2026 11:37
Successful Raspberry Pi 4 Trixie LinuxCNC install.
Category: Installing LinuxCNC
You ought to be able to update straight to 2.9.10 now that you have a working install.
What interfaces / motors does the current setup use? Is it a stepper machine or servos?
If it's a simple stepper machine you could make a start using the hal_gpio module and Pi GPIO pins, but you will need some level-shifting protection as the existing logic is almost cetainly 5V (or 24V) rather than the 3.3V of the Pi GPIO pins.
  • andypugh
  • andypugh's Avatar
01 Aug 2026 11:32
Replied by andypugh on topic VMC Bridgeport 760 22 Retrofit Project
Category: CNC Machines
Are you planning to retain the existing drives?
I tink that where you choose to make the cut between old and new would depend on where the electronics failures are happening.
But it is generally best to keep the original motors and often (but by no means always) best to keep the original motor drivers.
  • andypugh
  • andypugh's Avatar
01 Aug 2026 11:29
Replied by andypugh on topic Colchester 4000L retrofit
Category: Turning
Doesn't the 4000L have the carriage handwheel MPGs? I would think that those make a pendant superflous.
Displaying 1921 - 1935 out of 12540 results.
Time to create page: 0.237 seconds
