08 Jan 2025 02:43
Replied by tommylight on topic New installation only boot with "nomodeset"
Search the Debian forums, should be plenty of results there.
From what i recall, that is always graphic card related, probably older blacklisted 915 or 945 models.
Try an old graphic card, preferably not NVIDIA as they tend to mess the latency badly.
Or use the older version of LinuxCNC ISO, and you really should if you plan to use the parallel port, try Wheezy version.
08 Jan 2025 02:35
Replied by tommylight on topic PcConfig my mesa board is not listed.
Category: Installing LinuxCNC
What Mesa card ??????????????????????????????????????????????
  • Jdolecki
  • Jdolecki
08 Jan 2025 02:25
PcConfig my mesa board is not listed. was created by Jdolecki
How do I add my board to PcConfig. It’s not listed in the dropdown menu.
I see there is support software on the product page.
A pop up window appeared saying to add files to hm2 folder but I can’t find that?
  • blazini36
  • blazini36
08 Jan 2025 01:59
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
I suppose I hit some different circumstances since I'm trying to do something with a touchscreen rather than something like Axis, couple of things I ran across.....
I don't even bother adding a MenuBar, but I would like to use a pushbutton to open halshow, etc....Any way to do that?
I also noticed there's no good binary indicators in qt5's standard set of widgets, like LEDs or even a button that changes appearance on input. The only thing I've found is hal labels, but even then I think they are only actually good for displaying numeric values. If set to "bit" type input, they just display true or false. I don't see any way to make a text string appear or disappear at least. Looking for something that can just indicate a fault.
If something like this is already there just point it out, I'm good at missing things.
  • blazini36
  • blazini36
08 Jan 2025 01:12
Replied by blazini36 on topic Building and configuring a stmbl v5
Category: Driver Boards
Sure, I have many of them.......but that's not the point.
There are very few "open-source" things that actually wind up being cheaper than the cheaper thing it's replacing.....but I can't run a DMM off of Smart Serial. The 2 options on a standard drive are (not really) RS232, step+direction, and analog.....but the analog input has issues on these.  Modbus/rs485 is a custom drive.
  • jst
  • jst
08 Jan 2025 00:41
Replied by jst on topic Building and configuring a stmbl v5
There you go: github.com/jstjst
But after looking at the prices for the DMM servo drives, I think they are in the same price range (if not cheaper) then a stmbl
  • PCW
  • PCW's Avatar
08 Jan 2025 00:41
Replied by PCW on topic PC for Mesa 5i25T
PC for Mesa 5i25T
Yeah, a shorted analog output is going to drag the (relatively weak) local
power supply down.
  • PCW
  • PCW's Avatar
08 Jan 2025 00:34
Replied by PCW on topic LinuxCNC on Raspberry Pi 5
If you did not cause more extensive damage, you (or someone local with the right equipment)
should be able to replace the ISL32174 that's fried...
  • PCW
  • PCW's Avatar
08 Jan 2025 00:30
Where are the stepper direction pins hiding in 7196S HAL?
Category: Basic Configuration
You can look at the associated GPIO pin:
IO Connections for TB1/TB2 -> 7I96_1
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
TB1-2,3                17   IOPort       StepGen          0        Step/Table1     (Out)
TB1-4,5                18   IOPort       StepGen          0        Dir/Table2      (Out)
TB1-8,9                19   IOPort       StepGen          1        Step/Table1     (Out)
TB1-10,11              20   IOPort       StepGen          1        Dir/Table2      (Out)
TB1-14,15              21   IOPort       StepGen          2        Step/Table1     (Out)
TB1-16,17              22   IOPort       StepGen          2        Dir/Table2      (Out)
TB1-20,21              23   IOPort       StepGen          3        Step/Table1     (Out)
TB1-22,23              24   IOPort       StepGen          3        Dir/Table2      (Out)
TB2-2,3                25   IOPort       StepGen          4        Step/Table1     (Out)
TB2-4,5                26   IOPort       StepGen          4        Dir/Table2      (Out)
TB2-7,8                27   IOPort       QCount           0        Quad-A          (In)
TB2-10,11              28   IOPort       QCount           0        Quad-B          (In)
TB2-13,14              29   IOPort       QCount           0        Quad-IDX        (In)
TB2-16,17              30   IOPort       SSerial          0        RXData0         (In)
TB2-18,19              31   IOPort       SSerial          0        TXData0         (Out)
Internal-TXEn          32   IOPort       SSerial          0        TXEn0           (Out)
Internal               33   IOPort       SSR              0        AC Ref          (Out)
So GPIO 20 for stepgen 1's direction pin
  • phillc54
  • phillc54's Avatar
08 Jan 2025 00:22
Replied by phillc54 on topic Cut Recovery Not Consistently Triggering
Category: Plasmac
This should now be fixed:
github.com/LinuxCNC/linuxcnc/commit/5928...ae29d5ddb741c6456856
Although if you are using Bookworm and relying on buildbot2 then you will need to wait until it begins build again, the latest there is 24 Oct.
buildbot2.highlab.com/debian/dists/bookw...inary-amd64/?C=M;O=D
  • JimS
  • JimS
08 Jan 2025 00:21
Strange error after stopping file and adjusting part zero
Zeroed machine and did part zero.  Started program and saw that my x was off before tool reached the part.  (path is a ramp around the part so I could see the part outline before the tool started cutting.  Stopped the program and adjusted x part zero.  Now the program gives immediate error even if I reset x zero to original location.  The travel display shows the previous moves even when I reload the file.  It seems like LinuxCNC still has the movement captured somehow.  I could shut it all down and start over but would rather not zero the machine and relocate the part.  Is there a way to clear this without loosing my positioning?  The display shows Axis 2.7.4.  Maybe a newer version has fixed this if it's a bug?
  • resmond
  • resmond
08 Jan 2025 00:13
Replied by resmond on topic LinuxCNC on Raspberry Pi 5
I just accidentally swapped the 24v output port on one of my RTelligent Drivers for the drive-stepper input ports and blew up at least one of the 6 stepper outputs (likely two) on my 7i95T.
Once I get past suicidal thoughts I will shift all my joints over to check the possibly that I may have only blown two step-gens. Each pair of two step-gens share the IC that smoked so I'm betting 0 and 1 are gone but if 2-5 are still viable I might be able to limp along and continue to make some progress on the router which is XYYZ configuration.
Ironically, I was just going back through all the wiring straightening it all out and zip-tying everything. I just happened to swap two identically looking plugs and poof 'magic smoke'.
Bit of trivia... the digital aspects of the 7i95 seem to have remain unharmed. Led's report no errors on start and LinuxCNC connects right up and thinks nothings wrong.
Worse than the cost, it took me six weeks to get that board from Mesa, so I Guess I had better order a new one before Trump's Tariff plans kick in.
  • blazini36
  • blazini36
07 Jan 2025 23:48
Email isn't in your profile, didn't see it in your github bio either
  • NotAllThere
  • NotAllThere's Avatar
07 Jan 2025 23:25
Replied by NotAllThere on topic Simple Z touch off generating empty error [SOLVED]
D'oh!  Figured it out.  In case anyone else is as slow as I am...
In the ini file, my comm "MDI_COMMAND=0 <z_touch> CALL" was the 15th item in the HALUI list (starting with 0).  So my custom_postgui.hal file should have been:
net ztouch halui.mdi-command-15 <= pyvcp.ztouch
All good now.  Just need to measure offsets and we're running!
  • gardenweazel
  • gardenweazel's Avatar
07 Jan 2025 23:07
Replied by gardenweazel on topic QTDesigner PATH issue
Designer used to  run error free. I had a uspace install that I didn't realize existed. I suspect that once I removed
the uspace install, it may have impacted my RIP install.
I saw mention of QT needing some of the files that were in the DEB's.
I actually hard coded am abspath and that allowed me to get past the path issue.
However once I tried it from the local term I got these errors which don't exist, again the path and files don't exist:
Qtvcp python plugin found: /home/andy/.designer/plugins/python/qtvcp_plugin.py
[DEFAULT.QTVCP.WIDGETS.IMAGE_SWITCHER][DEBUG]  No Path: /usr/share/qtvcp/images/applet-critical.png (image_switcher.py:102)
  File "/home/andy/linuxcnc-dev/lib/python/qtvcp/plugins/nurbs_editor_plugin.py", line 27, in createWidget
    return NurbsEditor(parent)
  File "/home/andy/linuxcnc-dev/lib/python/qtvcp/widgets/nurbs_editor.py", line 71, in __init__
    self.instance = uic.loadUi(self.filename, self)
  File "/home/andy/.local/lib/python3.11/site-packages/PyQt5/uic/__init__.py", line 241, in loadUi
    return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
  File "/home/andy/.local/lib/python3.11/site-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
    return self.parse(filename, resource_suffix)
  File "/home/andy/.local/lib/python3.11/site-packages/PyQt5/uic/uiparser.py", line 1020, in parse
    document = parse(filename)
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 1218, in parse
    tree.parse(source, parser)
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 569, in parse
    source = open(source, "rb")
FileNotFoundError: [Errno 2] No such file or directory: '/usr/share/qtvcp/widgets_ui/nurbs_editor.ui'
Where are the files coming from in /usr/share/qtvcp???
Displaying 20386 - 20400 out of 21739 results.
Time to create page: 0.393 seconds
