16 Aug 2024 00:55
Replied by tommylight on topic Computer crashes after "Loading initial ramdisk"
Category: Installing LinuxCNC
"x86/cpu: VMX outside TXT) disabled by BIOS"
That is just a warning, not an issue.
Download and try to boot Linux Mint DE 6 (debian edition), and if that works, install, update, upgrade, then
sudo apt install linuxcnc-uspace
That should also install the required kernel and everything.
Does the PC have an NVIDIA graphic card?
if yes, at the GRUB screen (your second picture) press E, then add
nomodeset
in the same line and just after "quiet splash"
then boot with F10
  • CNC_Tinkerer
  • CNC_Tinkerer
16 Aug 2024 00:55
Cannot build 2.9.3, get "different exception specifier"
Looks like I had conflicts because I needed to remove
linux-image-4.19.0.9-rt-amd64
Now it builds as expected.
I thought I followed the upgrade instructions exactly, but either I missed that step or they did not mention it.
16 Aug 2024 00:48
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
Anyone tested the new kernels, 6.8 and up?
16 Aug 2024 00:46
Replied by tommylight on topic How to setup gearbox/reducer
Category: Basic Configuration
You did not give us enough info to be able to help:
-what is the motor driving
-how is that motor coupled to the machine
-how much does the machine move for one turn of the reduction
etc.
16 Aug 2024 00:42
Replied by tommylight on topic 7i97t with 7i84d connection problem
Category: Driver Boards
You would need a 7i74 to connect up to 8 SSerial boards, besides the one on the 7i97T.
If you can do some simple electronics, do as PCW suggested and get the chip he mentioned, that is much cheaper since you only need one more. If you end up needing more than one, get the 7i74, saves a lot of time and makes for a cleaner control box as it is very easy to wire in.
16 Aug 2024 00:11
16 Aug 2024 00:09
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Thought you couldn't read datasheets ?
DIMM or PCIe slots, great way to bump the price up.
  • CNC_Tinkerer
  • CNC_Tinkerer
16 Aug 2024 00:08
I upgraded to Debian 12 and LinuxCNC v2.9.3 and find I can no longer build.
Linux debian2 6.1.0-22-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.94-1 (2024-06-21) x86_64 GNU/Linux
Downloaded 2.9.3 tarball from git yesterday.
I kept pretty good notes on building with 2.8.x and can't find anything I previously encountered related to this. I can Make just my own code but when I do the full Make I get the following:
user1@debian2:~/linuxcnc-dev/src$ make
Reading 54/210 dependency files
Done reading dependencies
Reading 0/238 realtime dependency files
Done reading realtime dependencies
cp ../scripts/rtapi.conf ../tests/uspace/spawnv-root/rtapi.conf
Compiling rtapi/uspace_rtai.cc
In file included from rtapi/uspace_rtai.cc:10:
/usr/include/x86_64-linux-gnu/sys/io.h:38:12: error: declaration of ‘int iopl(int) noexcept’ has a different exception specifier
   38 | extern int iopl (int __level) __THROW;
In file included from /usr/include/rtai/rtai_lxrt.h:522,
                 from rtapi/uspace_rtai.cc:6:
/usr/include/rtai/asm/rtai_lxrt.h:170:38: note: from previous declaration ‘int iopl(int)’
  170 | #define rtai_iopl()  do { extern int iopl(int); iopl(3); } while (0)
/usr/include/rtai/rtai_lxrt.h:605:9: note: in expansion of macro ‘rtai_iopl’
  605 |         rtai_iopl();
make: *** [Makefile:288: objects/rtapi/uspace_rtai.o] Error 1
I'd appreciate if someone could suggest how to proceed. This doesn't seem to involve any code under my control.
  • rodw
  • rodw's Avatar
15 Aug 2024 23:52
Pi4b and Pi5 users - What should go in a 2.9.3 image
Curious, does the new .iso include a new Rpi firmware?
Yes, The Pi gets the most recent 6.6.44 kernel
  • rdtsc
  • rdtsc's Avatar
15 Aug 2024 23:36
  • phillc54
  • phillc54's Avatar
15 Aug 2024 23:27
Replied by phillc54 on topic Straight cut error
Straight cut error
Category: Plasmac
Normally you would get that message if you have offset probing enabled and are less than the Y axis offset distance from the Y axis maximum.
These settings are in the .prefs file.
[OFFSET_PROBING]
X axis = 0.0
Y axis = 0.0
If these values are correct could you post the backup file created from the BACKUP button on the SETTINGS tab.
  • cakeslob
  • cakeslob
15 Aug 2024 23:24
Replied by cakeslob on topic Remora for RP2040
Remora for RP2040
Hey Scott, about adding the encoders. The RP2040 W5500 firmware is similar to the STM32 W5500 firmware, in the sense that they both use the pingpong buffer thing. Ive been trying to add encoders/PWM to that firmware, but Im encountering an issue. I dont know where to send the data. There are examples for digital in/out and stepgen stuff, but there is no examples for PV/SP modules. Where ever its going, it should be similar for both firmwares.
Here is my initial attempt at encoders, but I cannot yet get it to compile
github.com/cakeslob/Remora-STM32F4xx-W55.../Src/modules/encoder
Here is what Drew and I were working on for PWM, it compiles, but doesnt yet work either.
github.com/cakeslob/Remora-STM32F4xx-W55...main/Src/modules/pwm
I was wondering if you could give me a few pointers? (pun intended)
But seriously, where do we send the data for PV/SP? The pointers are different than the other versions of remora, and I am stuck.
  • rthorntn
  • rthorntn
15 Aug 2024 22:18 - 15 Aug 2024 22:37
Just to reinforce how messed up this is, the MESA shipping costs for one board to Australia, what an absolute joke:
RIP you cool, clean, compact, integrated Mecanix board.
In other news, has anyone seen these Analog Crosspoint Switch Array ICs, thinking out loud if they could be useful...AD75019 is pricey but two MT8816 gets you to 16x16 for a lot less money, I ordered four PDIP MT8816 because I couldn't help myself?
Thinking out loud some more (it's what I'm best at, not so great at doing lol) is some kind of generic "slot" based expansion system the way to go, an FPGA backplane board with something like DIMM or MiniPCI slots for IO...jumper wires and ribbon cables be gone!
15 Aug 2024 22:14
I’ve installed ISE 14.7 on both Debian Bookworm & Mint 21, trick to get the installer going is to install libncurses5 and after the install to get a licence setup you need to rename your Ethernet port to eth0. To get a licence you need to register with Xilinx now AMD.
  • my1987toyota
  • my1987toyota's Avatar
15 Aug 2024 21:24
Replied by my1987toyota on topic Mostly 3D Printed CNC Foam cutter
Category: CNC Machines
here is a youtube video for I think is the originator of the design I based mine off of he also made a
program for generating the G-code to run the thing.  Pretty cool.
Displaying 23911 - 23925 out of 24345 results.
Time to create page: 0.447 seconds
